| Re: What does letter R mean in installer name? [message #1830833 is a reply to message #1830818] | Tue, 04 August 2020 23:34   |  |
| Eclipse User  |  |  |  |  | I'm not sure what you mean by it's called 'Eclipse Installer 2020-06 R' .    Do you mean the path from which it's downloaded, e.g.,  oomph/epp/2020-06/R/eclipse-inst-win64.exe?
 If you look on this folder, all the current and older versions of the installer are available:
 https://download.eclipse.org/oomph/epp/
 And there is an index file of them:
 https://download.eclipse.org/oomph/epp/installer-index.xml
 The R versions are the released versions.    There can be M and RC versions as well,  for the milestones and release candidates before the final release.  There might also be an Ra, or an Rb version if I needed to respin the release for some reason.
 Oh, maybe you mean on this page?
 https://www.eclipse.org/downloads/packages/installer
 This page is generated from the installer-index.xml mentioned above.
 In any case, all these installers are "restricted" to install only products/packages for that corresponding release of Eclipse (when used in simple mode).   Whereas the following ones are unrestricted and can install any version of Eclipse even in simple mode:
 https://wiki.eclipse.org/Eclipse_Installer
 The installer itself is self-updating, so you don't actually need to download a new one each time, but rather update it; updating it removes the restrictions...
FUDForum. Page generated in 0.39632 seconds
