Running Eclipse Marketplace leads to error message [message #1829960] |
Tue, 14 July 2020 17:05  |
I'm running Eclipse 0620-03 under Linux Mint 19 on a Dell Lattitude E6420.
It doesn't have WindowBuilder installed.
I google searched "WindowBuilder" and started to follow the directions. That is to say, I clicked on "Help --> Eclipse Marketplace."
When I did, I got the following error message:
MarketplaceDiscoveryStrategy failed with an error
Cannot complete request to https://marketplace.eclipse.org/api/p?client=org.eclipse.epp.mpc.core&client.version=1.8.2.v20200210-1402&os=linux&ws=gtk&nl=en_US&java.version=11.0.4&product=org.eclipse.epp.package.java.product&product.version=4.15.0.I20200305-0155&runtime.version=3.17.100.v20200203-0917&platform.version=4.15.0.v20200305-0155: Unable to read repository at https://marketplace.eclipse.org/api/p?client=org.eclipse.epp.mpc.core&client.version=1.8.2.v20200210-1402&os=linux&ws=gtk&nl=en_US&java.version=11.0.4&product=org.eclipse.epp.package.java.product&product.version=4.15.0.I20200305-0155&runtime.version=3.17.100.v20200203-0917&platform.version=4.15.0.v20200305-0155.
Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
I recently posted another problem that I have that involves WindowBuilder, this one with Eclipse 2020-06, so I don't want to upgrade until this other issue is resolved. (Then again, for all I know, 2020-06 may have this issue too, but I'd prefer to remain safe.)
One of the problems here is that this involves Eclipse's internal tables, which are VERY poorly documented. And YES I WILL WRITE THE STUFF IF YOU DEEM IT NECESSARY.
Is it worth it to install WindowBuilder or has the latest version of Eclipse deprecated it? What tools are currently used to edit a GUI? Regardless of these issues, what is causing the error that I'm getting?
Thank you for your time; I look forward to your response(s).
Re: Running Eclipse Marketplace leads to error message [message #1830222 is a reply to message #1830213] |
Tue, 21 July 2020 02:03  |
If you've downloaded the installer and it runs sufficiently so to bring up the UI and complain that it can't load the catalog, then there is nothing wrong with what you've downloaded, i.e., it's not corrupted, so redownloading that is highly unlikely to produce different behavior. The application is trying to download https://www.eclipse.org/setups/setups.zip and that's failing. Cached versions of what the installer downloads are stored in ~/.eclipse/org.eclipse.oomph.setup/cache and it it were successful, the files https___www.eclipse.org_setups_setups.zip and https___www.eclipse.org_setups_setups.zip.etag would exist in that folder.
I suggested running with "eclipse-inst -vmargs -Doomph.setup.ecf.trace=true" on the command line because this produces a detailed trace of the part of the framework that is downloading the catalog (setups.zip). With that information I would likely better understand what is going wrong. The installer also uses the configuration folder as the "workspace", so if some problem is logged, there will be a log file in <installer-folder>/configuration/.metadata/.log. There might be clues here has well.
Without some clues, I don't know what could be wrong in your particular case.
FUDForum. Page generated in 0.03363 seconds
