Re: 2020-06 "dependencies " errors [message #1830780 is a reply to message #1829971] |
Mon, 03 August 2020 19:40 |
Joel Adams Messages: 2 Registered: August 2020 |
Hi Ed,
After running into this same issue when trying to install CDT 9.11.1 on Eclipse 2020-06, I came across your response here, which put me on the track to resolving the issue.
The snag I ran into is that since the current version of OpenJDK is 14.x, I began by installing that and then trying to install CDT. Unfortunately, this produced very similar errors for me--references to missing Java 11 components.
So I uninstalled OpenJDK 14, installed OpenJDK 11, and CDT then installed as it should.
Is the dependency on Java 11 hardwired into CDT? If so, it seems like that ought not to be--it ought to be 11 or later...
-Joel.
FUDForum. Page generated in 0.10075 seconds
