Unable to connect using SSH in JGit [message #1829533] |
Mon, 06 July 2020 05:31  |
I am trying to connect to github.com using SSH and JGit. This is the code I am trying:-
public static void gitClone(File gitDirectoryPath) throws Exception {
SshSessionFactory sshSessionFactory = new JschConfigSessionFactory() {
protected void configure(OpenSshConfig.Host host, Session session) {
session.setUserInfo(new UserInfo() {
public String getPassphrase() {
return "";
public String getPassword() {
return null;
public boolean promptPassword(String message) {
return false;
public boolean promptPassphrase(String message) {
return true;
public boolean promptYesNo(String message) {
return false;
public void showMessage(String message) {
Git.cloneRepository().setTransportConfigCallback(new SshTransportConfigCallback()).setURI("git@github.com:agarwalvipul/core-java-template.git")
.setDirectory(gitDirectoryPath).call();
private static class SshTransportConfigCallback implements TransportConfigCallback {
private final SshSessionFactory sshSessionFactory = new JschConfigSessionFactory() {
protected void configure(OpenSshConfig.Host hc, Session session) {
session.setConfig("StrictHostKeyChecking", "no");
public void configure(Transport transport) {
SshTransport sshTransport = (SshTransport) transport;
sshTransport.setSshSessionFactory(sshSessionFactory);
I am getting the following exception:-
Exception in thread "main" org.eclipse.jgit.api.errors.TransportException: git@github.com:agarwalvipul/core-java-template.git: Auth fail
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:252)
at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:306)
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:200)
at com.lm.expertfees.Github.gitClone(Github.java:60)
at com.lm.expertfees.Test.main(Test.java:10)
Caused by: org.eclipse.jgit.errors.TransportException: git@github.com:agarwalvipul/core-java-template.git: Auth fail
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:182)
at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:140)
at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:280)
at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:170)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:137)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:123)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1269)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:241)
... 4 more
Caused by: com.jcraft.jsch.JSchException: Auth fail
at com.jcraft.jsch.Session.connect(Session.java:519)
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:136)
... 11 more
Can anyone help me in this context?
FUDForum. Page generated in 0.03924 seconds
