Eclipse IDE for RCP (2020-06) hangs opening build.xml files [message #1829488] |
Sat, 04 July 2020 23:55 |
Hernán González Messages: 5 Registered: July 2020 |
I've been using Eclipse IDE for RCP since 2008. Latest version exhibits many freezing problems. I've experienced frequent and fatal IDE freezes when opening ANT buildfiles.
The following steps don't reproduce the total freeze I experience in my development environment, but anyway a lag is noticeable, and they trigger "UI freeze" warnings and other ugly message in the logs - and this, mind you, starting from a total clean installation.
My environment : Windows-7, Java 1.8.0_231, 64 bits.
I download eclipse-rcp-2020-06-R-win32-x86_64.zip , unpack, and run in with a new workspace (previously I removed %USERPROFILE%/.eclipse, just in case)
I create a new empty Java project, from the wizard. I generate a build.xml file (via "Export -> Ant buildfile"). (again, just in case, I close Eclipse, remove any .log file in workspace, and open it again).
I click to open build.xml
A noticeable lag occurs. Finally the Ant editor opens.
Logs in WORSKPACE/metadata/.log show "MESSAGE UI freeze" with different warnings in different run.
I attach several examples
Attachment: .log1
(Size: 35.67KB, Downloaded 136 times) -
Attachment: .log2
(Size: 40.66KB, Downloaded 120 times) -
Attachment: .log3
(Size: 13.62KB, Downloaded 123 times) -
Attachment: .log4
(Size: 25.33KB, Downloaded 130 times)
FUDForum. Page generated in 0.03636 seconds
