Re: Workspace corrupted - Eclipse GUI not coming up anymore [message #1828731 is a reply to message #1828713] |
Wed, 17 June 2020 19:20 |
Michael Moser Messages: 64 Registered: October 2012 Location: Zürich, Switzerland |
Member |
Thanks for responding to both!
> Just to make sure the issue comes from the workspace's state: does replacing the current workspace by a "cleaner" one actually solve the issue and allows Eclipse IDE to start again?
Yes - it did.
> If this is the cause you've likely installed a plugin before...
Yes - I had tried a plugin, which didn't work (turned out it was mean't for 32-Bit versions of Eclipse only - do these still exist?) and so I uninstalled it again. Could have to do with that workspace corruption. But even then that shouldn't happen.
> It might also help to delete .metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi if there is some problem with the workbench's persisted state.
With the -clean I would have expected that Eclipse does exactly that and removes (or ignores) ALL previously persisted state. I thought that EXACTLY THAT was the purpose to overcome precisely such cases. Or what else is that option for, then?
[Updated on: Wed, 17 June 2020 19:21] Report message to a moderator
FUDForum. Page generated in 0.04427 seconds
