Home » Eclipse Projects » Eclipse Scout » LDAPAuthenticator - example
| LDAPAuthenticator - example [message #1828672] |
Tue, 16 June 2020 06:45  |
This is PoC version, it has been functionally tested (mostly). Performance and stability has not been tested.
This was created as part of my Scout research. Any comments are welcomed.
Disclaimer: some use of Scout name in this post is not part of Scout framework. Probably I should have named it differently... sorry for that.
My requirements for this LDAPAuthenticator were:
* current security features (StartTLS, configurable: protocol (TLS1.3), ciphers, PKCS12 keystore and TrustManager)
* connection pool
* some flexibility on the LDAP schema
* querying LDAP is done on fixed account (bind_dn), and not on user accounts (regular users have minimal access - they are not authorized to lookup LDAP objects)
* authentication based not only on username/password, but also on group membership (only members of specified group are allowed to authenticate)
* optional caching for group members. Group membership do not change that often (at least in my environment)
* LDAP bypass admin account (superadmin)
Tested against OpenLDAP (osixia docker-openldap)
Below used LDAP structure. Each application has its own account for LDAP communication (in ou=services). Each application has its own set of groups (in ou=groups) that will be mapped to roles.
dc=example,dc=net
ou=groups
ou=scout
cn=admin
cn=login
cn=simple_user
cn=power_user
ou=services
uid=scout
ou=users
uid=bolek
uid=user1
uid=user2
dependencies:
<!-- https://mvnrepository.com/artifact/org.slf4j/slf4j-ext -->
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-ext</artifactId>
<version>${version.slf4j.ext}</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.apache.commons/commons-collections4 -->
<dependency>
<groupId>org.apache.commons</groupId>
<artifactId>commons-collections4</artifactId>
<version>${version.commons.collections4}</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.apache.directory.api/api-all -->
<dependency>
<groupId>org.apache.directory.api</groupId>
<artifactId>api-all</artifactId>
<version>${version.apache.ds}</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.bouncycastle/bcpkix-jdk15on -->
<dependency>
<groupId>org.bouncycastle</groupId>
<artifactId>bcpkix-jdk15on</artifactId>
<version>${version.bouncycastle}</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.apache.commons/commons-pool2 -->
<dependency>
<artifactId>commons-pool2</artifactId>
<version>${version.commons.pool2}</version>
</dependency>
properties:
### LDAP configuration
scout.auth.ldap.host=192.168.0.1
scout.auth.ldap.port=389
# local admin account, to bypass LDAP as a last resort workaround
# if LDAP authentication fails, it is extra checked against following user/pass
scout.auth.ldap.superadmin=1
scout.auth.ldap.superadmin.login=superadmin
scout.auth.ldap.superadmin.password=changeit
# 0 - no security (TODO)
# 1 - StartTLS
# 2 - LDAPS (TODO)
# https://docs.oracle.com/en/java/javase/11/docs/specs/security/standard-names.html#sslcontext-algorithms
# https://docs.oracle.com/en/java/javase/11/docs/specs/security/standard-names.html#jsse-cipher-suite-names
scout.auth.ldap.connection.type=1
scout.auth.ldap.connection.protocol=TLSv1.3,TLSv1.2
scout.auth.ldap.connection.ciphers=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
scout.auth.ldap.connection.timeout=10000
scout.auth.ldap.connection.pool.maxtotal=10
scout.auth.ldap.connection.pool.minidle=2
# LDAP authentication
# simple - anonymous - (TODO)
# unauthenticated - (TODO)
# user/pass authenticated - (provide bind_DN and bind_password)
# SASL-External - SASL External (TODO)
scout.auth.ldap.auth=simple
# LDAP credentials for simple LDAP authentication
scout.auth.ldap.bind_dn=uid=scout,ou=services,dc=example,dc=net
scout.auth.ldap.bind_password=pass1234
# LDAP client side certificate
scout.auth.ldap.security.keystore.type=PKCS12
scout.auth.ldap.security.keystore.provider=SUN
scout.auth.ldap.security.keystore.file=src/main/resources/ks.p12
scout.auth.ldap.security.keystore.password=pass123
scout.auth.ldap.security.keystore.cert.alias=scout_test
scout.auth.ldap.security.keystore.cert.password=pass345
scout.auth.ldap.security.truststore.type=PKCS12
scout.auth.ldap.security.truststore.provider=SunJSSE
scout.auth.ldap.security.truststore.file=src/main/resources/ts.p12
scout.auth.ldap.security.truststore.password=pass678
# TODO
# 0 - trust any
# 1 - exact certificate match required
# 2 - trust all certificates from included CA
scout.auth.ldap.security.truststore.trustlevel=0
# OCSP certificate validation (TODO)
# 0 - OCSP query disabled
# 1 - OCSP query mandatory
# 2 - OCSP query only if present in certificate details
scout.auth.ldap.security.truststore.ocsp=0
# Only members can authenticate (if empty - anyone can authenticate - TODO)
scout.auth.ldap.user_group=cn=login,ou=scout,ou=groups,dc=example,dc=net
# attribute name for group members
scout.auth.ldap.group_fields=member,uniqueMember,memberUid
# uid or cn ?
scout.auth.ldap.user.uid_attr=uid
# where are users
scout.auth.ldap.user.dn=ou=users,dc=example,dc=net
# 0 - disabled, number - time in minutes to keep cache values
scout.auth.ldap.cache.groups=60
# future
scout.auth.ldap.group_classes=groupOfUniqueNames,groupOfNames
scout.auth.ldap.base_dn=ou=user,dc=example,dc=net
scout.auth.ldap.group_mapping=ScoutAdminGroup=cn=admin,ou=scout,ou=groups,dc=example,dc=net|\
ScoutPowerUserGroup=cn=power_user,ou=scout,ou=groups,dc=example,dc=net|\
ScoutSimpleUserGroup=cn=simple_user,ou=scout,ou=groups,dc=example,dc=net
In shared module
package io.poc.scout.ldap;
import org.eclipse.scout.rt.platform.service.IService;
import org.eclipse.scout.rt.shared.TunnelToServer;
@TunnelToServer
public interface ILDAPAuthService extends IService {
public int verify(String username, char[] password);
In ui.html module:
import java.io.IOException;
import java.util.concurrent.Callable;
import javax.security.auth.Subject;
import org.eclipse.scout.rt.client.context.ClientRunContexts;
import org.eclipse.scout.rt.platform.BEANS;
import org.eclipse.scout.rt.platform.context.RunContext;
import org.eclipse.scout.rt.platform.security.ICredentialVerifier;
import org.eclipse.scout.rt.platform.security.SimplePrincipal;
import org.eclipse.scout.rt.platform.util.StringUtility;
import org.slf4j.ext.XLogger;
import org.slf4j.ext.XLoggerFactory;
public class LDAPCredentialVerifier implements ICredentialVerifier {
private static final XLogger LOG = XLoggerFactory.getXLogger(LDAPCredentialVerifier.class);
public int verify(String username, char[] password) throws IOException {
LOG.entry(username, "***");
int result = AUTH_FORBIDDEN;
LOG.debug("Attempting LDAP authentication for user: {}", username);
if ( StringUtility.isNullOrEmpty(username) || password == null || password.length == 0 ) {
result = AUTH_CREDENTIALS_REQUIRED;
} else {
Subject subject = new Subject();
subject.getPrincipals().add( new SimplePrincipal("system_ldap_auth") );
subject.setReadOnly();
RunContext runContext = ClientRunContexts.copyCurrent(true).withSubject(subject);
result = runContext.call(new Callable<Integer>() {
public Integer call() throws Exception {
return BEANS.get(ILDAPAuthService.class).verify(username, password);
} // else
return LOG.exit(result);
In ui.html module alter class org.eclipse.scout.apps.helloworld.ui.html.UiServletFilter to use the LDAPCredentialVerifier.class
public void init(FilterConfig filterConfig) throws ServletException {
LOG.entry();
m_trivialAccessController = BEANS.get(TrivialAccessController.class).init(new TrivialAuthConfig()
.withExclusionFilter(filterConfig.getInitParameter("filter-exclude")).withLoginPageInstalled(true));
m_formBasedAccessController = BEANS.get(FormBasedAccessController.class)
.init(new FormBasedAuthConfig().withCredentialVerifier(BEANS.get(LDAPCredentialVerifier.class)));
m_developmentAccessController = BEANS.get(DevelopmentAccessController.class).init();
LOG.exit();
Principal "system_ldap_auth" needs to have following permission.
In server module alter org.eclipse.scout.apps.helloworld.server.security.ServerAccessControlService add:
permissions.add(new RemoteServiceAccessPermission("io.poc.scout.ldap.ILDAPAuthService", "verify"), PermissionLevel.ALL);
In server module:
import java.security.Security;
import org.bouncycastle.jce.provider.BouncyCastleProvider;
import org.eclipse.scout.rt.platform.exception.VetoException;
import org.eclipse.scout.rt.security.ACCESS;
import io.poc.scout.ldap.ILDAPAuthService;
public class LDAPAuthServiceImpl implements ILDAPAuthService {
private static final XLogger LOG = XLoggerFactory.getXLogger(LDAPAuthServiceImpl.class);
public LDAPAuthServiceImpl() {
LOG.entry();
// enable security without restrictions
Security.setProperty("crypto.policy", "unlimited");
// register Bouncy Castle security provider
Security.addProvider( new BouncyCastleProvider() );
LOG.exit();
public int verify(String username, char[] password) {
int result = ICredentialVerifier.AUTH_FORBIDDEN;
// AUTH_OK
// AUTH_FORBIDDEN
// AUTH_FAILED
// AUTH_CREDENTIALS_REQUIRED
LDAPConnectorMK2 ldap_connector = BEANS.get(LDAPConnectorMK2.class);
if ( ldap_connector.authenticate(username, password) ) {
result = ICredentialVerifier.AUTH_OK;
LOG.info("LDAP authentication OK for user: {}", username);
} else {
result = ICredentialVerifier.AUTH_FAILED;
LOG.info("LDAP authentication FAILED for user: {}", username);
package io.poc.scout.ldap.property;
import org.eclipse.scout.rt.platform.config.AbstractIntegerConfigProperty;
import org.eclipse.scout.rt.platform.config.AbstractStringConfigProperty;
public final class LDAPProperties {
public static final String AUTH_LDAP_PROPERTIES_NS = "scout.auth.ldap";
// not used
public static final String AUTH_LDAP_PROPERTY = AUTH_LDAP_PROPERTIES_NS;
public static final String AUTH_LDAP_PROPERTY_DESC = "Enable LDAP authentication";
public static final String AUTH_LDAP_PROPERTY_DEFAULT = "0";
public static final String AUTH_LDAP_HOST_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".host";
public static final String AUTH_LDAP_HOST_PROPERTY_DESC = "LDAP hostname or IP";
public static final String AUTH_LDAP_PORT_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".port";
public static final String AUTH_LDAP_PORT_PROPERTY_DESC = "LDAP server port number";
public static final Integer AUTH_LDAP_PORT_PROPERTY_DEFAULT = Integer.valueOf(389);
public static final String AUTH_LDAP_SUPERADMIN_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".superadmin";
public static final String AUTH_LDAP_SUPERADMIN_PROPERTY_DESC = "Enable local superadmin account";
public static final String AUTH_LDAP_SUPERADMIN_PROPERTY_DEFAULT = "0";
public static final String AUTH_LDAP_SUPERADMIN_LOGIN_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".superadmin.login";
public static final String AUTH_LDAP_SUPERADMIN_LOGIN_PROPERTY_DESC = "Superadmin account name";
public static final String AUTH_LDAP_SUPERADMIN_PASS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".superadmin.password";
public static final String AUTH_LDAP_SUPERADMIN_PASS_PROPERTY_DESC = "Superadmin account password";
public static final String AUTH_LDAP_CONNECTION_TIMEOUT_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".connection.timeout";
public static final String AUTH_LDAP_CONNECTION_TIMEOUT_PROPERTY_DESC = "Connection timeout";
public static final Integer AUTH_LDAP_CONNECTION_TIMEOUT_PROPERTY_DEFAULT = Integer.valueOf(1000);
public static final String AUTH_LDAP_CONNECTION_TYPE_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".connection.type";
public static final String AUTH_LDAP_CONNECTION_TYPE_PROPERTY_DESC = "Connection type to LDAP server: 0 - insecure, 1 - StartTLS, 2 - LDAPS";
public static final String AUTH_LDAP_CONNECTION_TYPE_PROPERTY_DEFAULT = "1";
public static final String AUTH_LDAP_CONNECTION_TYPE_INSECURE = "0";
public static final String AUTH_LDAP_CONNECTION_TYPE_STARTTLS = "1";
public static final String AUTH_LDAP_CONNECTION_TYPE_LDAPS = "2";
public static final String AUTH_LDAP_CONNECTION_PROTOCOL_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".connection.protocol";
public static final String AUTH_LDAP_CONNECTION_PROTOCOL_PROPERTY_DESC = "Connection security protocol";
public static final String AUTH_LDAP_CONNECTION_PROTOCOL_PROPERTY_DEFAULT = "TLSv1.3,TLSv1.2";
public static final String AUTH_LDAP_CONNECTION_CIPHERS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".connection.ciphers";
public static final String AUTH_LDAP_CONNECTION_CIPHERS_PROPERTY_DESC = "Connection allowed ciphers";
public static final String AUTH_LDAP_CONNECTION_CIPHERS_PROPERTY_DEFAULT = "TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,TLS_DHE_RSA_WITH_AES_256_GCM_SHA384";
public static final String AUTH_LDAP_CONNECTION_POOL_MAXTOTAL_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".connection.pool.maxtotal";
public static final String AUTH_LDAP_CONNECTION_POOL_MAXTOTAL_PROPERTY_DESC = "LDAP connection pool maxtotal";
public static final Integer AUTH_LDAP_CONNECTION_POOL_MAXTOTAL_PROPERTY_DEFAULT = Integer.valueOf(10);
public static final String AUTH_LDAP_CONNECTION_POOL_MINIDLE_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".connection.pool.minidle";
public static final String AUTH_LDAP_CONNECTION_POOL_MINIDLE_PROPERTY_DESC = "LDAP connection pool minidle";
public static final Integer AUTH_LDAP_CONNECTION_POOL_MINIDLE_PROPERTY_DEFAULT = Integer.valueOf(2);
public static final String AUTH_LDAP_AUTH_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".auth";
public static final String AUTH_LDAP_AUTH_PROPERTY_DESC = "LDAP server authentication method: simple | SASL_External";
public static final String AUTH_LDAP_AUTH_PROPERTY_DEFAULT = "simple";
public static final String AUTH_LDAP_BIND_DN_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".bind_dn";
public static final String AUTH_LDAP_BIND_DN_PROPERTY_DESC = "Bind dn to authenticate against";
public static final String AUTH_LDAP_BIND_PASS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".bind_password";
public static final String AUTH_LDAP_BIND_PASS_PROPERTY_DESC = "Password for bind DN object";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_TYPE_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.keystore.type";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_TYPE_PROPERTY_DESC = "Keystore type";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_TYPE_PROPERTY_DEFAULT = "PKCS12";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_PROVIDER_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.keystore.provider";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_PROVIDER_PROPERTY_DESC = "Keystore provider";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_FILE_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.keystore.file";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_FILE_PROPERTY_DESC = "Keystore file location";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_PASS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.keystore.password";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_PASS_PROPERTY_DESC = "Keystore password";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_CERT_ALIAS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.keystore.cert.alias";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_CERT_ALIAS_PROPERTY_DESC = "Alias of the certificate used for identity";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_CERT_PASS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.keystore.cert.password";
public static final String AUTH_LDAP_SECURITY_KEYSTORE_CERT_PASS_PROPERTY_DESC = "Password for the private key";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_TYPE_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.truststore.type";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_TYPE_PROPERTY_DESC = "Truststore type";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_TYPE_PROPERTY_DEFAULT = "PKCS12";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_PROVIDER_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.truststore.provider";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_PROVIDER_PROPERTY_DESC = "Truststore provider";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_TRUSTLEVEL_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.truststore.trustlevel";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_TRUSTLEVEL_PROPERTY_DESC = "Truststore trustlevel";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_TRUSTLEVEL_PROPERTY_DEFAULT = "0";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_OCSP_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.truststore.ocsp";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_OCSP_PROPERTY_DESC = "Truststore ocsp";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_OCSP_PROPERTY_DEFAULT = "0";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_FILE_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.truststore.file";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_FILE_PROPERTY_DESC = "Truststore file location";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_PASS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".security.truststore.password";
public static final String AUTH_LDAP_SECURITY_TRUSTSTORE_PASS_PROPERTY_DESC = "Truststore password";
// You need to be authorized to be authenticated
public static final String AUTH_LDAP_USER_GROUP_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".user_group";
public static final String AUTH_LDAP_USER_GROUP_PROPERTY_DESC = "LDAP group of authorized to login accounts";
public static final String AUTH_LDAP_GROUP_CLASSES_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".group_classes";
public static final String AUTH_LDAP_GROUP_CLASSES_PROPERTY_DESC = "LDAP object classes of a group";
public static final String AUTH_LDAP_GROUP_CLASSES_PROPERTY_DEFAULT = "groupOfUniqueNames,groupOfNames";
public static final String AUTH_LDAP_GROUP_FIELDS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".group_fields";
public static final String AUTH_LDAP_GROUP_FIELDS_PROPERTY_DESC = "LDAP object classes of a group member";
public static final String AUTH_LDAP_GROUP_FIELDS_PROPERTY_DEFAULT = "member,uniqueMember,memberUid";
public static final String AUTH_LDAP_USER_UID_ATTR_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".user.uid_attr";
public static final String AUTH_LDAP_USER_UID_ATTR_PROPERTY_DESC = "LDAP atribute name to verify login against";
public static final String AUTH_LDAP_USER_UID_ATTR_PROPERTY_DEFAULT = "uid";
public static final String AUTH_LDAP_USER_DN_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".user.dn";
public static final String AUTH_LDAP_USER_DN_PROPERTY_DESC = "Location of user objects in LDAP";
public static final String AUTH_LDAP_BASE_DN_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".base_dn";
public static final String AUTH_LDAP_BASE_DN_PROPERTY_DESC = "LDAP base dn";
public static final String AUTH_LDAP_GROUP_MAPPING_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".group_mapping";
public static final String AUTH_LDAP_GROUP_MAPPING_PROPERTY_DESC = "Mapping of security groups between LDAP and Scout";
public static final String AUTH_LDAP_CACHE_GROUPS_PROPERTY = AUTH_LDAP_PROPERTIES_NS + ".cache.groups";
public static final String AUTH_LDAP_CACHE_GROUPS_PROPERTY_DESC = "cache LDAP groups (in minutes)";
public static final Integer AUTH_LDAP_CACHE_GROUPS_PROPERTY_DEFAULT = Integer.valueOf(0);
private LDAPProperties() {}
public static class AuthLDAPHostProperty extends AbstractStringConfigProperty {
public String getKey() {
return AUTH_LDAP_HOST_PROPERTY;
public String description() {
return AUTH_LDAP_HOST_PROPERTY_DESC;
public static class AuthLDAPPortProperty extends AbstractIntegerConfigProperty {
return AUTH_LDAP_PORT_PROPERTY;
return AUTH_LDAP_PORT_PROPERTY_DESC;
public Integer getDefaultValue() {
return AUTH_LDAP_PORT_PROPERTY_DEFAULT;
public static class AuthLDAPSuperadminProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SUPERADMIN_PROPERTY;
return AUTH_LDAP_SUPERADMIN_PROPERTY_DESC;
public String getDefaultValue() {
return AUTH_LDAP_SUPERADMIN_PROPERTY_DEFAULT;
public static class AuthLDAPSuperadminLoginProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SUPERADMIN_LOGIN_PROPERTY;
return AUTH_LDAP_SUPERADMIN_LOGIN_PROPERTY_DESC;
public static class AuthLDAPSuperadminPasswordProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SUPERADMIN_PASS_PROPERTY;
return AUTH_LDAP_SUPERADMIN_PASS_PROPERTY_DESC;
public static class AuthLDAPConnectionTimeoutProperty extends AbstractIntegerConfigProperty {
return AUTH_LDAP_CONNECTION_TIMEOUT_PROPERTY;
return AUTH_LDAP_CONNECTION_TIMEOUT_PROPERTY_DESC;
return AUTH_LDAP_CONNECTION_TIMEOUT_PROPERTY_DEFAULT;
public static class AuthLDAPConnectionTypeProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_CONNECTION_TYPE_PROPERTY;
return AUTH_LDAP_CONNECTION_TYPE_PROPERTY_DESC;
return AUTH_LDAP_CONNECTION_TYPE_PROPERTY_DEFAULT;
public static class AuthLDAPConnectionProtocolProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_CONNECTION_PROTOCOL_PROPERTY;
return AUTH_LDAP_CONNECTION_PROTOCOL_PROPERTY_DESC;
return AUTH_LDAP_CONNECTION_PROTOCOL_PROPERTY_DEFAULT;
public static class AuthLDAPConnectionCiphersProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_CONNECTION_CIPHERS_PROPERTY;
return AUTH_LDAP_CONNECTION_CIPHERS_PROPERTY_DESC;
return AUTH_LDAP_CONNECTION_CIPHERS_PROPERTY_DEFAULT;
public static class AuthLDAPConnectionPoolMaxtotalProperty extends AbstractIntegerConfigProperty {
return AUTH_LDAP_CONNECTION_POOL_MAXTOTAL_PROPERTY;
return AUTH_LDAP_CONNECTION_POOL_MAXTOTAL_PROPERTY_DESC;
return AUTH_LDAP_CONNECTION_POOL_MAXTOTAL_PROPERTY_DEFAULT;
public static class AuthLDAPConnectionPoolMinidleProperty extends AbstractIntegerConfigProperty {
return AUTH_LDAP_CONNECTION_POOL_MINIDLE_PROPERTY;
return AUTH_LDAP_CONNECTION_POOL_MINIDLE_PROPERTY_DESC;
return AUTH_LDAP_CONNECTION_POOL_MINIDLE_PROPERTY_DEFAULT;
public static class AuthLDAPAuthProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_AUTH_PROPERTY;
return AUTH_LDAP_AUTH_PROPERTY_DESC;
return AUTH_LDAP_AUTH_PROPERTY_DEFAULT;
public static class AuthLDAPBindDNProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_BIND_DN_PROPERTY;
return AUTH_LDAP_BIND_DN_PROPERTY_DESC;
public static class AuthLDAPBindPasswordProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_BIND_PASS_PROPERTY;
return AUTH_LDAP_BIND_PASS_PROPERTY_DESC;
public static class AuthLDAPSecurityKeystoreTypeProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_KEYSTORE_TYPE_PROPERTY;
return AUTH_LDAP_SECURITY_KEYSTORE_TYPE_PROPERTY_DESC;
return AUTH_LDAP_SECURITY_KEYSTORE_TYPE_PROPERTY_DEFAULT;
public static class AuthLDAPSecurityKeystoreProviderProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_KEYSTORE_PROVIDER_PROPERTY;
return AUTH_LDAP_SECURITY_KEYSTORE_PROVIDER_PROPERTY_DESC;
public static class AuthLDAPSecurityKeystoreFileProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_KEYSTORE_FILE_PROPERTY;
return AUTH_LDAP_SECURITY_KEYSTORE_FILE_PROPERTY_DESC;
public static class AuthLDAPSecurityKeystorePasswordProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_KEYSTORE_PASS_PROPERTY;
return AUTH_LDAP_SECURITY_KEYSTORE_PASS_PROPERTY_DESC;
public static class AuthLDAPSecurityKeystoreCertAliasProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_KEYSTORE_CERT_ALIAS_PROPERTY;
return AUTH_LDAP_SECURITY_KEYSTORE_CERT_ALIAS_PROPERTY_DESC;
public static class AuthLDAPSecurityKeystoreCertPasswordProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_KEYSTORE_CERT_PASS_PROPERTY;
return AUTH_LDAP_SECURITY_KEYSTORE_CERT_PASS_PROPERTY_DESC;
public static class AuthLDAPSecurityTruststoreTypeProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_TRUSTSTORE_TYPE_PROPERTY;
return AUTH_LDAP_SECURITY_TRUSTSTORE_TYPE_PROPERTY_DESC;
return AUTH_LDAP_SECURITY_TRUSTSTORE_TYPE_PROPERTY_DEFAULT;
public static class AuthLDAPSecurityTruststoreProviderProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_TRUSTSTORE_PROVIDER_PROPERTY;
return AUTH_LDAP_SECURITY_TRUSTSTORE_PROVIDER_PROPERTY_DESC;
public static class AuthLDAPSecurityTruststoreTrustlevelProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_TRUSTSTORE_TRUSTLEVEL_PROPERTY;
return AUTH_LDAP_SECURITY_TRUSTSTORE_TRUSTLEVEL_PROPERTY_DESC;
return AUTH_LDAP_SECURITY_TRUSTSTORE_TRUSTLEVEL_PROPERTY_DEFAULT;
public static class AuthLDAPSecurityTruststoreOcspProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_TRUSTSTORE_OCSP_PROPERTY;
return AUTH_LDAP_SECURITY_TRUSTSTORE_OCSP_PROPERTY_DESC;
return AUTH_LDAP_SECURITY_TRUSTSTORE_OCSP_PROPERTY_DEFAULT;
public static class AuthLDAPSecurityTruststoreFileProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_TRUSTSTORE_FILE_PROPERTY;
return AUTH_LDAP_SECURITY_TRUSTSTORE_FILE_PROPERTY_DESC;
public static class AuthLDAPSecurityTruststorePasswordProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_SECURITY_TRUSTSTORE_PASS_PROPERTY;
return AUTH_LDAP_SECURITY_TRUSTSTORE_PASS_PROPERTY_DESC;
public static class AuthLDAPUserGroupProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_USER_GROUP_PROPERTY;
return AUTH_LDAP_USER_GROUP_PROPERTY_DESC;
public static class AuthLDAPGroupClassesProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_GROUP_CLASSES_PROPERTY;
return AUTH_LDAP_GROUP_CLASSES_PROPERTY_DESC;
return AUTH_LDAP_GROUP_CLASSES_PROPERTY_DEFAULT;
public static class AuthLDAPGroupFieldsProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_GROUP_FIELDS_PROPERTY;
return AUTH_LDAP_GROUP_FIELDS_PROPERTY_DESC;
return AUTH_LDAP_GROUP_FIELDS_PROPERTY_DEFAULT;
public static class AuthLDAPUserUidAttrProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_USER_UID_ATTR_PROPERTY;
return AUTH_LDAP_USER_UID_ATTR_PROPERTY_DESC;
return AUTH_LDAP_USER_UID_ATTR_PROPERTY_DEFAULT;
public static class AuthLDAPUserDNProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_USER_DN_PROPERTY;
return AUTH_LDAP_USER_DN_PROPERTY_DESC;
public static class AuthLDAPBaseDNProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_BASE_DN_PROPERTY;
return AUTH_LDAP_BASE_DN_PROPERTY_DESC;
public static class AuthLDAPGroupMappingProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_GROUP_MAPPING_PROPERTY;
return AUTH_LDAP_GROUP_MAPPING_PROPERTY_DESC;
public static class AuthLDAPBruteforcePreventionProperty extends AbstractStringConfigProperty {
return AUTH_LDAP_BRUTEFORCE_PREVENTION_PROPERTY;
return AUTH_LDAP_BRUTEFORCE_PREVENTION_PROPERTY_DESC;
return AUTH_LDAP_BRUTEFORCE_PREVENTION_PROPERTY_DEFAULT;
public static class AuthLDAPBruteforceLockoutProperty extends AbstractIntegerConfigProperty {
return AUTH_LDAP_BRUTEFORCE_LOCKOUT_PROPERTY;
return AUTH_LDAP_BRUTEFORCE_LOCKOUT_PROPERTY_DESC;
return AUTH_LDAP_BRUTEFORCE_LOCKOUT_PROPERTY_DEFAULT;
public static class AuthLDAPCacheGroupsProperty extends AbstractIntegerConfigProperty {
return AUTH_LDAP_CACHE_GROUPS_PROPERTY;
return AUTH_LDAP_CACHE_GROUPS_PROPERTY_DESC;
return AUTH_LDAP_CACHE_GROUPS_PROPERTY_DEFAULT;
import org.eclipse.scout.rt.platform.config.IConfigurationValidator;
import org.eclipse.scout.rt.platform.exception.InitializationException;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class LDAPPropertyValidator implements IConfigurationValidator {
private static final Logger LOG = LoggerFactory.getLogger(LDAPPropertyValidator.class);
public boolean isValid(String key, String value) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_PROPERTY) ) {
if (value != null && value.length() == 1 && "01".indexOf(value) >= 0) {
LOG.debug("Property: [{}] value: [{}] is valid", key, value);
return true;
} else {
LOG.error("Incorrect value for property: {}", key);
throw new InitializationException("Incorrect value for property: " + key);
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_HOST_PROPERTY) ) {
LOG.debug("Property: [{}] value: [{}]", key, value);
return true;
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_PORT_PROPERTY) ) {
return true;
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SUPERADMIN_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SUPERADMIN_LOGIN_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SUPERADMIN_PASS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_CONNECTION_TYPE_PROPERTY) ) {
if (value != null && value.length() == 1 && "012".indexOf(value) >= 0) {
return true;
} else {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_CONNECTION_PROTOCOL_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_CONNECTION_CIPHERS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_AUTH_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_BIND_DN_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_BIND_PASS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_KEYSTORE_TYPE_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_KEYSTORE_PROVIDER_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_KEYSTORE_FILE_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_KEYSTORE_PASS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_KEYSTORE_CERT_ALIAS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_KEYSTORE_CERT_PASS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_TRUSTSTORE_TYPE_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_TRUSTSTORE_PROVIDER_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_TRUSTSTORE_FILE_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_TRUSTSTORE_PASS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_TRUSTSTORE_TRUSTLEVEL_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_SECURITY_TRUSTSTORE_OCSP_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_USER_GROUP_PROPERTY) ) {
if (value != null) {
return true;
} else {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_GROUP_CLASSES_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_GROUP_FIELDS_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_USER_UID_ATTR_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_USER_DN_PROPERTY) ) {
return true;
} else {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_BASE_DN_PROPERTY) ) {
if ( key.equalsIgnoreCase(LDAPProperties.AUTH_LDAP_GROUP_MAPPING_PROPERTY) ) {
return false;
import org.eclipse.scout.rt.platform.config.CONFIG;
import io.poc.scout.ldap.property.LDAPProperties;
public class LDAPConnectorProperties {
private static final XLogger LOG = XLoggerFactory.getXLogger(LDAPConnectorProperties.class);
private String conn_type = null;
private String conn_protocol = null;
private String conn_ciphers = null;
private Integer conn_timeout = null;
private String conn_host = null;
private Integer conn_port = null;
private String conn_auth = null;
private Integer conn_pool_maxtotal = null;
private Integer conn_pool_minidle = null;
private String conn_bind_dn = null;
private String conn_bind_pass = null;
private String ks_type = null;
private String ks_provider = null;
private String ks_file = null;
private String ks_pass = null;
private String ks_cert_alias = null;
private String ks_cert_pass = null;
private String ts_type = null;
private String ts_provider = null;
private String ts_file = null;
private String ts_pass = null;
private String ts_trustlevel = null;
private String ts_ocsp = null;
private String superadmin = null;
private String superadmin_login = null;
private String superadmin_pass = null;
private String user_group = null;
private String group_classes = null;
private String group_fields = null;
private String user_uid_attr = null;
private String user_dn = null;
private String base_dn = null;
private String group_mapping = null;
private Integer cache_groups = null;
public LDAPConnectorProperties() {
LOG.entry();
conn_type = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPConnectionTypeProperty.class);
conn_protocol = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPConnectionProtocolProperty.class);
conn_ciphers = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPConnectionCiphersProperty.class);
conn_timeout = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPConnectionTimeoutProperty.class);
conn_host = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPHostProperty.class);
conn_port = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPPortProperty.class);
conn_auth = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPAuthProperty.class);
conn_pool_maxtotal = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPConnectionPoolMaxtotalProperty.class);
conn_pool_minidle = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPConnectionPoolMinidleProperty.class);
conn_bind_dn = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPBindDNProperty.class);
conn_bind_pass = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPBindPasswordProperty.class);
ks_type = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityKeystoreTypeProperty.class);
ks_provider = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityKeystoreProviderProperty.class);
ks_file = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityKeystoreFileProperty.class);
ks_pass = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityKeystorePasswordProperty.class);
ks_cert_alias = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityKeystoreCertAliasProperty.class);
ks_cert_pass = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityKeystoreCertPasswordProperty.class);
ts_type = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityTruststoreTypeProperty.class);
ts_provider = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityTruststoreProviderProperty.class);
ts_file = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityTruststoreFileProperty.class);
ts_pass = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityTruststorePasswordProperty.class);
ts_trustlevel = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityTruststoreTrustlevelProperty.class);
ts_ocsp = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSecurityTruststoreOcspProperty.class);
superadmin = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSuperadminProperty.class);
superadmin_login = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSuperadminLoginProperty.class);
superadmin_pass = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPSuperadminPasswordProperty.class);
user_group = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPUserGroupProperty.class);
group_classes = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPGroupClassesProperty.class);
group_fields = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPGroupFieldsProperty.class);
user_uid_attr = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPUserUidAttrProperty.class);
user_dn = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPUserDNProperty.class);
base_dn = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPBaseDNProperty.class);
group_mapping = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPGroupMappingProperty.class);
cache_groups = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPCacheGroupsProperty.class);
LOG.debug("conn_type: {}", conn_type);
LOG.debug("conn_protocol: {}", conn_protocol);
LOG.debug("conn_ciphers: {}", conn_ciphers);
LOG.debug("conn_timeout: {}", conn_timeout.intValue());
LOG.debug("conn_host: {}", conn_host);
LOG.debug("conn_port: {}", conn_port.intValue());
LOG.debug("conn_auth: {}", conn_auth);
LOG.debug("conn_pool_maxtotal: {}", conn_pool_maxtotal.intValue());
LOG.debug("conn_pool_minidle: {}", conn_pool_minidle.intValue());
LOG.debug("conn_bind_DN: {}", conn_bind_dn);
LOG.debug("conn_bind_pass: {}", conn_bind_pass);
LOG.debug("ks_type: {}", ks_type);
LOG.debug("ks_provider: {}", ks_provider);
LOG.debug("ks_file: {}", ks_file);
LOG.debug("ks_pass: {}", ks_pass);
LOG.debug("ks_cert_alias: {}", ks_cert_alias);
LOG.debug("ks_cert_pass: {}", ks_cert_pass);
LOG.debug("ts_type: {}", ts_type);
LOG.debug("ts_provider: {}", ts_provider);
LOG.debug("ts_file: {}", ts_file);
LOG.debug("ts_pass: {}", ts_pass);
LOG.debug("ts_trustlevel: {}", ts_trustlevel);
LOG.debug("ts_ocsp: {}", ts_ocsp);
LOG.debug("superadmin: {}", superadmin);
LOG.debug("superadmin_login: {}", superadmin_login);
LOG.debug("superadmin_pass: {}", superadmin_pass);
LOG.debug("user_group: {}", user_group);
LOG.debug("group_classes: {}", group_classes);
LOG.debug("group_fields: {}", group_fields);
LOG.debug("user_uid_attr: {}", user_uid_attr);
LOG.debug("user_DN: {}", user_dn);
LOG.debug("base_DN: {}", base_dn);
LOG.debug("group_mapping: {}", group_mapping);
LOG.debug("cache_groups: {}", cache_groups);
LOG.exit();
public String getConn_type() {
return conn_type;
public String getConn_protocol() {
return conn_protocol;
public String getConn_ciphers() {
return conn_ciphers;
public Integer getConn_timeout() {
return conn_timeout;
public String getConn_host() {
return conn_host;
public Integer getConn_port() {
return conn_port;
public String getConn_auth() {
return conn_auth;
public Integer getConn_pool_maxtotal() {
return conn_pool_maxtotal;
public Integer getConn_pool_minidle() {
return conn_pool_minidle;
public String getConn_bind_dn() {
return conn_bind_dn;
public String getConn_bind_pass() {
return conn_bind_pass;
public String getKs_type() {
return ks_type;
public String getKs_provider() {
return ks_provider;
public String getKs_file() {
return ks_file;
public String getKs_pass() {
return ks_pass;
public String getKs_cert_alias() {
return ks_cert_alias;
public String getKs_cert_pass() {
return ks_cert_pass;
public String getTs_type() {
return ts_type;
public String getTs_provider() {
return ts_provider;
public String getTs_file() {
return ts_file;
public String getTs_pass() {
return ts_pass;
public String getTs_trustlevel() {
return ts_trustlevel;
public String getTs_ocsp() {
return ts_ocsp;
public String getSuperadmin() {
return superadmin;
public String getSuperadmin_login() {
return superadmin_login;
public String getSuperadmin_pass() {
return superadmin_pass;
public String getUser_group() {
return user_group;
public String getGroup_classes() {
return group_classes;
public String getGroup_fields() {
return group_fields;
public String getUser_uid_attr() {
return user_uid_attr;
public String getUser_dn() {
return user_dn;
public String getBase_dn() {
return base_dn;
public String getGroup_mapping() {
return group_mapping;
public Integer getCache_groups() {
return cache_groups;
import java.util.Collection;
import java.util.HashSet;
import java.util.Set;
import java.util.concurrent.TimeUnit;
import java.util.stream.Collectors;
import java.util.stream.Stream;
import org.apache.directory.api.ldap.model.entry.Attribute;
import org.apache.directory.api.ldap.model.entry.Entry;
import org.apache.directory.api.ldap.model.exception.LdapException;
import org.apache.directory.api.ldap.model.name.Dn;
import org.apache.directory.ldap.client.api.DefaultLdapConnectionFactory;
import org.apache.directory.ldap.client.api.LdapConnectionPool;
import org.apache.directory.ldap.client.api.ValidatingPoolableLdapConnectionFactory;
import org.apache.directory.ldap.client.template.EntryMapper;
import org.apache.directory.ldap.client.template.LdapConnectionTemplate;
import org.apache.directory.ldap.client.template.exception.PasswordException;
import org.eclipse.scout.rt.platform.ApplicationScoped;
import org.eclipse.scout.rt.platform.cache.CacheRegistryService;
import org.eclipse.scout.rt.platform.cache.ICache;
import org.eclipse.scout.rt.platform.cache.ICacheBuilder;
import org.eclipse.scout.rt.platform.cache.ICacheValueResolver;
import org.eclipse.scout.rt.platform.util.Assertions;
@ApplicationScoped
public class LDAPConnectorMK2 {
private static final XLogger LOG = XLoggerFactory.getXLogger(LDAPConnectorMK2.class);
public static final String GROUP_CACHE_CACHE_ID = LDAPConnectorMK2.class.getName() + ".GROUP_CACHE";
protected final LDAPConnectorProperties p = new LDAPConnectorProperties();
protected LdapConnectionPool pool = null;
protected boolean groupCacheEnabled = false;
public LDAPConnectorMK2() {
LOG.entry();
DefaultLdapConnectionFactory factory = new DefaultLdapConnectionFactory(LDAPUtil.getLdapConnectionConfig(p));
factory.setTimeOut(p.getConn_timeout());
pool = new LdapConnectionPool(new ValidatingPoolableLdapConnectionFactory(factory), LDAPUtil.getLdapPoolConfig(p) );
if (p.getCache_groups() > 0) {
groupCacheEnabled = true;
LOG.exit();
public boolean authenticate(String username, char[] password) {
boolean result = false;
Dn userDn = LDAPUtil.prepareUserDN(username);
if ( validateGroupMembership(userDn) && authenticateWithUsernamePassword(userDn, password) ) {
result = true;
// if LDAP authentication failed, attempt superadmin access
if (!result) {
result = superadminAuthentication(username, password);
protected boolean authenticateWithUsernamePassword(Dn userDn, char[] password) {
LOG.entry(userDn, "***");
Assertions.assertNotNull(userDn);
Assertions.assertNotNullOrEmpty(new String(password));
LdapConnectionTemplate con = new LdapConnectionTemplate(pool);
try {
con.authenticate(userDn, password);
result = true;
} catch (PasswordException e) {
LOG.debug("LDAP authentication unsuccessful for: " + userDn.toString(), e);
protected boolean validateGroupMembership(Dn userDn) {
LOG.entry(userDn);
Set<String> users = getLdapGroupMembers( p.getUser_group() );
if ( users.contains( userDn.getName().toLowerCase() ) ) {
result = true;
protected boolean superadminAuthentication(String username, char[] password) {
LOG.entry();
if ( p.getSuperadmin().equals("1")
&& p.getSuperadmin_login().equals(username)
&& p.getSuperadmin_pass().equals( new String(password) ) ) {
LOG.warn("superadmin access granted");
result = true;
public Set<String> getLdapGroupMembers(String ldapGroup) {
LOG.entry(ldapGroup);
Set<String> result = null;
Assertions.assertNotNull(ldapGroup);
if (groupCacheEnabled) {
LOG.debug("attempting to get values from cache");
result = getCache().get(ldapGroup);
} else {
result = getLdapGroupMembersNoCache(ldapGroup);
result.stream().forEach(x -> LOG.debug("member: {}", x));
public Set<String> getLdapGroupMembersNoCache(String ldapGroup) {
result = con.lookup(LDAPUtil.getDn(ldapGroup), groupMembersEntryMapper);
private final EntryMapper<Set<String>> groupMembersEntryMapper = new EntryMapper<Set<String>>() {
public Set<String> map(Entry entry) throws LdapException {
LOG.entry(entry);
Set<String> result = new HashSet<String>();
// checking groups for attributes: scout.auth.ldap.group_fields=member,uniqueMember,memberUid
// String group_fields = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPGroupFieldsProperty.class);
String group_fields = p.getGroup_fields();
Set<String> group_fields_set = Stream.of(group_fields.split(",")).map(x -> x.toLowerCase()).collect(Collectors.toSet());
group_fields_set.stream().forEach(x -> LOG.debug("group_field: {}", x));
Collection<Attribute> c_attr = entry.getAttributes();
c_attr.stream()
.filter(y -> group_fields_set.contains(y.getId().toLowerCase()))
.forEach(d -> d.forEach(e -> result.add(e.getString())));
result.stream().forEach(x -> LOG.debug("user: {}", x));
private ICache<String, Set<String>> getCache() {
LOG.entry();
ICache<String, Set<String>> result = null;
CacheRegistryService crs = BEANS.get(CacheRegistryService.class);
result = crs.opt(GROUP_CACHE_CACHE_ID);
if (result == null) {
result = createCache();
private ICache<String, Set<String>> createCache() {
LOG.entry();
@SuppressWarnings("unchecked")
ICacheBuilder<String, Set<String>> cacheBuilder = BEANS.get(ICacheBuilder.class);
result = cacheBuilder
.withCacheId(GROUP_CACHE_CACHE_ID)
.withTimeToLive(Long.valueOf(p.getCache_groups()), TimeUnit.MINUTES, false)
.withValueResolver(new ICacheValueResolver<String, Set<String>>() {
public Set<String> resolve(String key) {
LOG.entry(key);
Set<String> result = getLdapGroupMembersNoCache(key);
.withThreadSafe(true)
.build();
[Updated on: Tue, 16 June 2020 06:56] by Moderator
| Re: LDAPAuthenticator - example [message #1828673 is a reply to message #1828672] |
Tue, 16 June 2020 06:57   |
import java.security.KeyStore;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
import javax.net.ssl.KeyManager;
import javax.net.ssl.TrustManager;
import org.apache.commons.collections4.BidiMap;
import org.apache.commons.collections4.bidimap.DualHashBidiMap;
import org.apache.commons.pool2.impl.GenericObjectPoolConfig;
import org.apache.directory.api.ldap.codec.api.DefaultConfigurableBinaryAttributeDetector;
import org.apache.directory.api.ldap.model.exception.LdapInvalidDnException;
import org.apache.directory.ldap.client.api.LdapConnection;
import org.apache.directory.ldap.client.api.LdapConnectionConfig;
import org.eclipse.scout.rt.platform.exception.PlatformException;
import org.eclipse.scout.rt.platform.exception.ProcessingException;
import io.poc.scout.ldap.FullVerificationTrustManager;
public class LDAPUtil {
private static final XLogger LOG = XLoggerFactory.getXLogger(LDAPUtil.class);
public LDAPUtil() {
LOG.entry();
LOG.exit();
public static Dn prepareUserDN(String userId) {
LOG.entry(userId);
Dn result = null;
String user_uid_attr = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPUserUidAttrProperty.class);
String user_DN = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPUserDNProperty.class);
String tmpDN = user_uid_attr + "=" + userId + "," + user_DN;
LOG.debug("tmpDN: {}", tmpDN);
result = getDn(tmpDN);
public static Dn getDn(String stringDn) {
LOG.entry(stringDn);
Dn result = null;
try {
result = new Dn(stringDn);
} catch (LdapInvalidDnException e) {
String msg = "Cannot create Dn for: " + stringDn;
LOG.error(msg, e);
throw new PlatformException(msg, e).withContextInfo("dn", stringDn);
public static BidiMap<String, String> getGroupMappings() {
LOG.entry();
BidiMap<String, String> result = new DualHashBidiMap<String, String>();
String group_mapping = CONFIG.getPropertyValue(LDAPProperties.AuthLDAPGroupMappingProperty.class);
Set<String> x_group_mapping_set = Stream.of(group_mapping.split("\\|")).collect(Collectors.toSet());
x_group_mapping_set.stream().forEach(x -> LOG.debug("mapping: {}", x) );
Pattern pattern = Pattern.compile("([^=]*)=(.*)");
for (String str : x_group_mapping_set) {
LOG.debug("processing: {}", str);
Matcher m = pattern.matcher(str);
if ( m.find() ) {
String group = m.group(1);
String ldap = m.group(2);
LOG.debug("group: {} ldap: {}", group, ldap);
result.put(group, ldap);
} else {
String msg = "Incorrect LDAP group mapping: " + str;
LOG.error(msg);
throw new PlatformException(msg)
.withContextInfo("group mapping", str)
.withContextInfo("system property", LDAPProperties.AUTH_LDAP_GROUP_MAPPING_PROPERTY);
} // for
public static LdapConnectionConfig getLdapConnectionConfig(LDAPConnectorProperties p) {
LOG.entry();
LdapConnectionConfig result = new LdapConnectionConfig();
result.setLdapHost(p.getConn_host());
result.setLdapPort(p.getConn_port());
result.setTimeout(p.getConn_timeout());
result.setName(p.getConn_bind_dn());
result.setCredentials(p.getConn_bind_pass());
String[] enabledCipherSuites = getEnabledCiphers(p.getConn_ciphers());
if (enabledCipherSuites != null) {
result.setEnabledCipherSuites( enabledCipherSuites );
String[] enabledSecurityProtocols = getEnabledProtocols(p.getConn_protocol());
if (enabledSecurityProtocols != null) {
result.setEnabledProtocols( enabledSecurityProtocols );
result.setSslProtocol(enabledSecurityProtocols[0]);
result.setTrustManagers( getTrustManager(p) );
result.setKeyManagers( getKeyManagers(p) );
result.setBinaryAttributeDetector( new DefaultConfigurableBinaryAttributeDetector() );
switch (p.getConn_type()) {
case LDAPProperties.AUTH_LDAP_CONNECTION_TYPE_INSECURE : {
// 0
// insecure
LOG.debug("Preparing insecure connection");
break;
case LDAPProperties.AUTH_LDAP_CONNECTION_TYPE_STARTTLS : {
// 1
// StartTLS
LOG.debug("Preparing StartTLS connection");
result.setUseTls(true);
break;
case LDAPProperties.AUTH_LDAP_CONNECTION_TYPE_LDAPS : {
// 2
// LDAPS
LOG.debug("Preparing LDAPS connection");
result.setUseSsl(true);
break;
default : {
throw new ProcessingException("Unknown value for configuration property: "
+ LDAPProperties.AUTH_LDAP_CONNECTION_TYPE_PROPERTY + " : " + p.getConn_type());
} // switch
protected static String[] getEnabledCiphers(String enabledCiphers) {
LOG.entry(enabledCiphers);
String[] result = null;
Set<String> tmpSet = Stream.of(enabledCiphers.split(",")).collect(Collectors.toSet());
tmpSet.stream().forEach(x -> LOG.debug("enabled cipher: {}", x));
result = tmpSet.stream().toArray(x -> new String[x]);
protected static String[] getEnabledProtocols(String protocols) {
LOG.entry(protocols);
Set<String> tmpSet = Stream.of(protocols.split(",")).collect(Collectors.toSet());
tmpSet.stream().forEach(x -> LOG.debug("enabled protocol: {}", x));
protected static KeyManager[] getKeyManagers(LDAPConnectorProperties p) {
LOG.entry();
KeyManager[] result = null;
KeyStore ks = PKIHelper.getKeystore(p.getKs_type(), p.getKs_provider(), p.getKs_file(), p.getKs_pass());
result = PKIHelper.prepareKeyManagers(ks, p.getKs_pass(), p.getKs_cert_alias(), p.getKs_cert_pass());
protected static TrustManager getTrustManager(LDAPConnectorProperties p) {
LOG.entry();
TrustManager result = null;
KeyStore ts = null;
if (p.getTs_file() != null) {
// open truststore
ts = PKIHelper.getKeystore(p.getTs_type(), p.getTs_provider(), p.getTs_file(), p.getTs_pass());
result = new FullVerificationTrustManager(ts, p.getTs_ocsp(), p.getTs_trustlevel());
// result = new NoVerificationTrustManager();
public static GenericObjectPoolConfig<LdapConnection> getLdapPoolConfig(LDAPConnectorProperties p) {
LOG.entry();
GenericObjectPoolConfig<LdapConnection> result = new GenericObjectPoolConfig<LdapConnection>();
result.setLifo(GenericObjectPoolConfig.DEFAULT_LIFO);
result.setMaxTotal(p.getConn_pool_maxtotal());
result.setMinIdle(p.getConn_pool_minidle());
result.setMaxIdle(GenericObjectPoolConfig.DEFAULT_MAX_IDLE);
result.setMaxWaitMillis(GenericObjectPoolConfig.DEFAULT_MAX_WAIT_MILLIS);
result.setMinEvictableIdleTimeMillis(GenericObjectPoolConfig.DEFAULT_MIN_EVICTABLE_IDLE_TIME_MILLIS);
result.setNumTestsPerEvictionRun(GenericObjectPoolConfig.DEFAULT_NUM_TESTS_PER_EVICTION_RUN);
result.setSoftMinEvictableIdleTimeMillis(GenericObjectPoolConfig.DEFAULT_SOFT_MIN_EVICTABLE_IDLE_TIME_MILLIS);
result.setTestOnBorrow(GenericObjectPoolConfig.DEFAULT_TEST_ON_BORROW);
result.setTestOnReturn(GenericObjectPoolConfig.DEFAULT_TEST_ON_RETURN);
result.setTestWhileIdle(GenericObjectPoolConfig.DEFAULT_TEST_WHILE_IDLE);
result.setTimeBetweenEvictionRunsMillis(GenericObjectPoolConfig.DEFAULT_TIME_BETWEEN_EVICTION_RUNS_MILLIS);
result.setBlockWhenExhausted(GenericObjectPoolConfig.DEFAULT_BLOCK_WHEN_EXHAUSTED);
import java.io.InputStream;
import java.nio.file.Files;
import java.nio.file.Path;
import java.nio.file.Paths;
import java.nio.file.StandardOpenOption;
import java.security.Key;
import java.security.KeyStoreException;
import java.security.NoSuchAlgorithmException;
import java.security.NoSuchProviderException;
import java.security.UnrecoverableKeyException;
import java.security.cert.Certificate;
import java.security.cert.CertificateException;
import java.security.cert.X509Certificate;
import java.util.Enumeration;
import javax.net.ssl.KeyManagerFactory;
public class PKIHelper {
private static final XLogger LOG = XLoggerFactory.getXLogger(PKIHelper.class);
private static PKIHelper instance = null;
public static PKIHelper getInstance() {
LOG.entry();
if (instance == null) {
instance = new PKIHelper();
return LOG.exit(instance);
public PKIHelper() {
LOG.entry();
LOG.exit();
public static KeyManager[] prepareKeyManagers(KeyStore ks, String password, String cert_label, String cert_password) {
LOG.entry(ks, "***", cert_label, "***");
try {
// prepare cert_password
LOG.debug("preparing password");
char[] cert_password_char = null;
if (cert_password != null) {
cert_password_char = cert_password.toCharArray();
} else {
cert_password_char = new char[0];
// get certificate key and chain
LOG.debug("getting key and chain");
if (ks.getCertificate(cert_label) == null) {
throw new UnrecoverableKeyException("No certificate found with alias: " + cert_label);
Certificate[] cert_chain = ks.getCertificateChain(cert_label);
Key cert_priv_key = ks.getKey(cert_label, cert_password_char);
Stream.of(cert_chain).forEach( x -> LOG.debug("cert: {}", ((X509Certificate) x).getSubjectDN() ) );
LOG.debug("priv key alg: {} format: {}", cert_priv_key.getAlgorithm(), cert_priv_key.getFormat());
// create new KeyStore and add extracted certificate and key
LOG.debug("creating new keystore");
KeyStore newKeystore = getKeystore(ks.getType(), ks.getProvider().getName(), null, password);
LOG.debug("adding cert to new keystore");
newKeystore.setKeyEntry(cert_label, cert_priv_key, cert_password_char, cert_chain);
// prepare KeyManagers
LOG.debug("getting default KeyManagerFactory algorithm");
String defaultAlg = KeyManagerFactory.getDefaultAlgorithm();
LOG.debug("default KeyManagerFactory algorithm: {}", defaultAlg);
KeyManagerFactory keyManagerFactory = KeyManagerFactory.getInstance(defaultAlg);
// KeyManagerFactory keyManagerFactory = KeyManagerFactory.getInstance("PKIX");
keyManagerFactory.init(newKeystore, cert_password_char);
result = keyManagerFactory.getKeyManagers();
} catch (KeyStoreException e) {
String msg = "Error preparing KeyManagers";
LOG.error(msg, e);
} catch (UnrecoverableKeyException e) {
LOG.error(msg, e);
} catch (NoSuchAlgorithmException e) {
LOG.error(msg, e);
public static KeyStore getKeystore(String type, String provider, String location, String password) {
LOG.entry(type, provider, location, "***");
KeyStore result = null;
try {
KeyStore ks = null;
if (provider == null) {
// use default provider
ks = KeyStore.getInstance(type);
} else {
// use specified provider
ks = KeyStore.getInstance(type, provider);
if (location != null) {
// we will load keystore from file
Path path = Paths.get(location).normalize().toAbsolutePath();
LOG.debug("keystore absolute normalized path: {}", path.toString());
try (InputStream readStream = Files.newInputStream(path, StandardOpenOption.READ)) {
if (password != null) {
ks.load(readStream, password.toCharArray());
} else {
ks.load(readStream, new char[0]);
LOG.debug("keystore successfully opened");
} else {
// we will create new keystore
ks.load(null, password.toCharArray());
} else {
ks.load(null, null);
LOG.debug("keystore successfully created");
result = ks;
String msg = "Cannot open keystore: " + location;
LOG.error(msg, e);
} catch (NoSuchProviderException e) {
LOG.error(msg, e);
} catch (IOException e) {
LOG.error(msg, e);
LOG.error(msg, e);
} catch (CertificateException e) {
LOG.error(msg, e);
public static boolean isCertificatePresent(X509Certificate cert, KeyStore ks) {
LOG.entry( (cert!=null) ? cert.getSubjectDN() : cert, ks);
if (ks != null && cert != null)
try {
Enumeration<String> aliases = ks.aliases();
while (aliases.hasMoreElements()) {
String alias = aliases.nextElement();
if (ks.isCertificateEntry(alias)) {
X509Certificate tmpCert = (X509Certificate) ks.getCertificate(alias);
LOG.debug("tmpCert: {} signed by: {} sn: {}", tmpCert.getSubjectDN().toString(), tmpCert.getIssuerDN(), tmpCert.getSerialNumber());
if (cert.equals(tmpCert)) {
LOG.debug("found equal certificate");
result = true;
break;
} // if
} // while
LOG.error("Problems", e);
import javax.net.ssl.X509TrustManager;
public class FullVerificationTrustManager implements X509TrustManager {
private static final XLogger LOG = XLoggerFactory.getXLogger(FullVerificationTrustManager.class);
private KeyStore ks = null;
private String ocsp = null;
private String trustlevel = null;
public FullVerificationTrustManager(KeyStore ks, String ocsp, String trustlevel) {
LOG.entry(ks, ocsp, trustlevel);
// if (ks == null)
// throw new IllegalArgumentException("TrustStore cannot be null");
this.ks = ks;
this.ocsp = ocsp;
this.trustlevel = trustlevel;
LOG.exit();
* Method called on the server-side for establishing trust with a client.
public void checkClientTrusted(X509Certificate[] chain, String authType) throws CertificateException {
LOG.entry(chain, authType);
Stream.of(chain).forEach(x -> LOG.debug("client cert: {} issued by: {} sn: {}",
x.getSubjectDN(), x.getIssuerDN(), x.getSerialNumber()) );
LOG.exit();
* Method called on the client-side for establishing trust with a server.
public void checkServerTrusted(X509Certificate[] chain, String authType) throws CertificateException {
for (X509Certificate cert: chain) {
LOG.debug("server cert: {} issued by: {} sn: {}", cert.getSubjectDN(), cert.getIssuerDN(), cert.getSerialNumber());
verifyCertificate(cert);
verifyOCSP(cert);
LOG.exit();
public X509Certificate[] getAcceptedIssuers() {
LOG.entry();
return LOG.exit(null);
private void verifyCertificate(X509Certificate cert) throws CertificateException {
LOG.entry( (cert != null) ? cert.getSubjectDN() : cert);
if (ks != null) {
if (!PKIHelper.isCertificatePresent(cert, ks)) {
String msg = "Certificate not trusted: " + cert.getSubjectDN();
LOG.warn(msg);
throw new CertificateException(msg);
} else {
LOG.debug("Certificate trusted: " + cert.getSubjectDN());
} else {
String msg = "Cannot confirm trust";
LOG.exit();
private void verifyOCSP(X509Certificate cert) throws CertificateException {
switch (ocsp) {
case "0" : {
// do nothing
break;
case "1" : {
// mandatory check
if (!verifyOCSPCertificate(cert)) {
String msg = "OCSP verification failure for certificate: " + cert.getSubjectDN();
LOG.error(msg);
break;
case "2" : {
// check if present in certificate details
break;
default : {
String msg = "Unrecognized ocsp verification mode: " + ocsp;
LOG.error(msg);
} // switch
LOG.exit();
private boolean verifyOCSPCertificate(X509Certificate cert) {
//TODO
result = true;
Current Time: Mon Oct 27 03:57:34 EDT 2025
Powered by FUDForum. Page generated in 0.31438 seconds
