Home » Eclipse Projects » Eclipse Titan » Eclipse Titan 7.1.0 release announcement
Eclipse Titan 7.1.0 release announcement [message #1828634] Mon, 15 June 2020 08:54 Go to next message
Dear all,
We are glad to announce that version 7.1.0 of Eclipse Titan received approval from the Eclipse foundation.
This release introduces some major new features:
  • Initial support for Object-Oriented Programming extension of the TTCN-3 standard is implemented on the C side of the toolset.
  • The speed of the semantic checks done in the Designer has been improved, by parallelizing the algorithms:
    • We have seen 2-4* faster code quality checks, thanks to the parallelization of Titanium checks.
    • 1.2 - 2* (in synthetic example 3*) faster semantic checks, thanks to the parallelization of the Semantic checks done in the Designer.
    • We have also seen a 20% - 30% reduction in overall processing time in case of large hierarchies, thank to parallelizing syntactic checks while processing project hierarchies.
    (measurements done on laptops with 4 core CPUs)
  • Initial support for JSON encoding/decoding support is implemented in the Java code generator.
Next to some bug fixes, the release also contains some backward incompatible changes:
  • 'omit' matching mechanism is no longer allowed for union fields
  • We had redesigned the placement of type descriptors in the generated Java code to support very large modules (containing thousands of types with encodings).
For the complete list of changes , see: https://www.eclipse.org/downloads/download.php?file=/titan/TITAN_change_log_7.1.pl0.pdf
Best regards
on behalf of the Titan developer team
Kristof
Re: Eclipse Titan 7.1.0 release announcement [message #1828642 is a reply to message #1828634] Mon, 15 June 2020 10:38 Go to previous messageGo to next message
Congratulations for the Team! Great work!
Olaf
Re: Eclipse Titan 7.1.0 release announcement [message #1828659 is a reply to message #1828634] Tue, 16 June 2020 03:04 Go to previous message
Congratulations for the Team.
Everything works fine.
[Updated on: Tue, 16 June 2020 06:11] by Moderator
Previous Topic:Titan for UE testing for 3GPP Release 15 and beyond
Next Topic:Decoding J1939 name fails
Current Time: Wed Apr 23 21:49:24 EDT 2025
Powered by FUDForum. Page generated in 0.03816 seconds
