Re: Generating code with Acceleo from Sirius digram model [message #1828571 is a reply to message #1828569] |
Fri, 12 June 2020 15:41 |
Hi Sel ma,
You should take a look to this tutorial about how to built an update site containing your modeler: https://wiki.eclipse.org/Sirius/Tutorials/UpdateSiteTutorial, we your Acceleo project will be ready you will have the possibility to add the corresponding plugins or feature to the update site. You final user will have the possibility to install your dsl and modeler in their environment, there is then no need to launch a runtime to use it.
Your diagrams are currently saved the workspace used by your runtime (more precisely, in the .aird file of your project).
Regarding the creation/initialization/test of the Acceleo project, it should be possible to create directly in the workspace in which you have your DSL project. I think that as soon as you put the correct dependencies between the plugin project, the completion/validation in template editors will be correct.
You will have the possibility to test your generator and or launch actions from the runtime on the files or elements of the model on which you enable the generation.
You might also import your acceleo project in the runtime workspace to ease the first tests as you this will allows to have the metamodel plugins deployed and some sample models directly accessible.
Maxime Porhel - Obeo
FUDForum. Page generated in 0.03040 seconds
