Home » Newcomers » Newcomers » Windows installation problem(Can not install eclipse on windows 10 64x)
Windows installation problem [message #1828467] |
Wed, 10 June 2020 10:42 |
Vincent Li Messages: 1 Registered: June 2020 |
I attempted multiply times for installation, in the beginning, it failed due to internet disturbance, however, in the latter attempt it directed reported error. I tried to restart the computer and the error still occurred.
Can someone help me with this problem, thank you so much.
below is the error log where the error occurred:
2020-06-10 18:36:50] Collected 1 artifacts for http://download.eclipse.org/technology/epp/packages/neon in 0.635s
[2020-06-10 18:36:50] An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
[2020-06-10 18:36:50] ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while collecting items to be installed
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:547)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:729)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3305)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3233)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3214)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3114)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.installPerform(SimpleVariablePage.java:1271)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.access$31(SimpleVariablePage.java:1148)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage$20.run(SimpleVariablePage.java:1093)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_Vincent Li_eclipse_java-neon_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
ERROR: org.eclipse.equinox.p2.artifact.repository code=4 Multiple problems occurred while downloading.
ERROR: org.eclipse.equinox.p2.artifact.repository code=4 Result of processing steps.
OK: unknown code=0 OK
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Unpack facility not configured. The locations searched for unpack200 are: C:\Program Files\Java\jdk-14.0.1/bin/unpack200, unpack200,
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.p2.core,1.16.0.v20200405-0717.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: 34b3a9367e7ce2464c41321a9c89331b and found 00ce6b15b57a7170fde146ec89b326ba.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.p2.doc,1.11.0.v20200204-0711.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: 1e28c2fbbb53386f03af45640df62a91 and found 338a7e8c2ce93cc8c43d4d7790deb94a.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.p2.ui,1.13.0.v20200226-1838.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: 44e45f559f5b6ddac62ee26a50af50c5 and found a4541a13e4e77124a468bd344f081777.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.resources,1.13.0.v20200409-0806.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: eeb9ae2ab440b3a7108348840cbcc6f7 and found 62c5162b871c711eb86d55ce14901e6b.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.setup.doc,1.11.0.v20200204-0711.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: 4cac73af459f8015f2a3033fff618f32 and found 26cf2da2090d34230c75e23b0f483693.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.setup.sync,1.12.0.v20200203-0955.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: 874af7916da35d53e1c1e07dbb98e78a and found d30ac8bed22712544815ee101e464917.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.setup.ui.questionnaire,1.11.0.v20200407-0508.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: 13ce8e0e4db67592a0a0e28c66653fa9 and found 2d627290960eb9c69fd6539ce8cb305d.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.util,1.14.0.v20200319-1415.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: 4c5f93b467644baee3c348706c61e487 and found 938848d8da9130503f1e1474e51d0b3c.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: osgi.bundle,org.eclipse.oomph.workingsets.editor,1.11.0.v20190929-1544.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 MD5 hash is not as expected. Expected: adc21a9309294d5f073bbba821f21dfb and found 8113ec3b705cc8c20c771799e39d3c2c.
Current Time: Fri Apr 26 01:41:16 GMT 2024
Powered by FUDForum. Page generated in 0.08798 seconds
