Home » Polarsys » M2Doc » How to install M2Doc into Capella(How to install M2Doc into Capella)
How to install M2Doc into Capella [message #1828015] Fri, 29 May 2020 04:17 Go to next message
I have Capella 1.4.1 and M2Doc 3.0.0. I have been through the installation apparently successfully but M2Doc cannot be found in the "show view". How to get Capella to recognize M2Doc?
Re: How to install M2Doc into Capella [message #1828019 is a reply to message #1828015] Fri, 29 May 2020 04:59 Go to previous messageGo to next message
Hi Chris,
(I think there is no "show view"...)
have a look at the M2Doc-site how to generate a document:
https://www.m2doc.org/capella/
https://www.m2doc.org/ref-doc/nightly/index.html#generating-a-document
Re: How to install M2Doc into Capella [message #1828030 is a reply to message #1828019] Fri, 29 May 2020 09:55 Go to previous messageGo to next message
Yes and Capella 1.4.1 is not out so I am not 100% sure M2Doc already work with dev versions of Capella 1.4.1
Re: How to install M2Doc into Capella [message #1828035 is a reply to message #1828030] Fri, 29 May 2020 11:58 Go to previous message
If the installation has succeeded, it's a good news. But no tests has been performed on Capella 1.4.1 so far, so you might come across some issues.
Let us know if you have any issue.
Previous Topic:The 'NewTemplate" wizard is missing
Next Topic:Is Capella cleared for D0-178C and certification of architectures?
Current Time: Wed Oct 22 21:22:13 EDT 2025
Powered by FUDForum. Page generated in 0.03463 seconds
