Home » Eclipse Projects » EGit / JGit » Errors in Eclipse 2020-03 with latest ADT(Not sure if issue with eclipse or SAP ADT)
Errors in Eclipse 2020-03 with latest ADT [message #1828013] Fri, 29 May 2020 03:24 Go to next message
Hi All,
My eclipse and SAP ADT (ABAP Development Tools) are both updated to the latest version. Not sure what's wrong but, everytime I right click on any object or within any code, while in the ABAP perspective, I get this error (Attached).
In other perspective, like in Java this error is not there.
Couldn't find anything like this online as I googled. So had to ask here.
Tried to uninstall and re-install everything. Even tried removing just the git integration from eclipse, but this error keeps coming back.
Really not sure if it's an error with eclipse or the SAP ADT.
Can anyone please help? This is very annoying.
Re: Errors in Eclipse 2020-03 with latest ADT [message #1828040 is a reply to message #1828013] Fri, 29 May 2020 14:38 Go to previous messageGo to next message
EGit UI cannot load because EGit core cannot load because JGit crashes because the path to your HOME directory is utterly wrong.
You're on Windows. What are the values of the following environment variables:
%HOME%
%HOMEDRIVE%
%HOMEPATH%
%HOMESHARE%
What is the setting in Eclipse of system property user.home (should be shown in the Eclipse About Dialog, click "Installation Details", in the "Configuration" tab)?
Re: Errors in Eclipse 2020-03 with latest ADT [message #1828041 is a reply to message #1828013] Fri, 29 May 2020 14:39 Go to previous messageGo to next message
Please report bug for egit
Re: Errors in Eclipse 2020-03 with latest ADT [message #1828042 is a reply to message #1828041] Fri, 29 May 2020 14:50 Go to previous messageGo to next message
Andrey Loskutov wrote on Fri, 29 May 2020 18:39
No, please don't. It's a problem in JGit, and I've just created bug 563739.
Re: Errors in Eclipse 2020-03 with latest ADT [message #1828078 is a reply to message #1828040] Sun, 31 May 2020 23:14 Go to previous messageGo to next message
Thomas Wolf wrote on Sat, 30 May 2020 02:38
%HOME%
%HOMEDRIVE%
%HOMEPATH%
%HOMESHARE%
Thanks for the reply. Here're the values in my system...
HOME=C:\Program Files\Git;C:\<myfolder>\eclipse;C:\Program Files\Java\jdk-11.0.6\bin;
HOMEDRIVE = C:
HOMEPATH=\Users\<myuser>
I don't have HOMESHARE setup.
In eclipse config, the user.home is set to my user folder C:/Users/<myuser>
PS: I just noticed that my eclipse is stored in "Eclipse" folder, whereas the HOME shows the folder as "eclipse". Do you think this is supposed to be case sensitive? Usually in windows it shouldn't matter, right?
[Updated on: Sun, 31 May 2020 23:16] by Moderator
Re: Errors in Eclipse 2020-03 with latest ADT [message #1828079 is a reply to message #1828042] Sun, 31 May 2020 23:19 Go to previous messageGo to next message
Thomas Wolf wrote on Sat, 30 May 2020 02:50
Thanks.
So a fix for this bug should fix the issue for me?
Re: Errors in Eclipse 2020-03 with latest ADT [message #1828082 is a reply to message #1828079] Mon, 01 June 2020 01:39 Go to previous messageGo to next message
Yes.
Having a list of paths in %HOME% is highly unusual, if not wrong. Did you intend to set %PATH% to that list?
You could also fix it by setting %HOME% to C:\Users\<myuser>.
Re: Errors in Eclipse 2020-03 with latest ADT [message #1828217 is a reply to message #1828082] Thu, 04 June 2020 04:59 Go to previous message
Thomas Wolf wrote on Mon, 01 June 2020 13:39
Wow.. awesome this simple step fixed the issue for me... In fact this also made git recognized in my VS Code, where it always showed as git not found.
Didn't know both the issues, were due to this one HOME path.
Previous Topic:EGit not recognising git repositories downloaded using repo tool
Next Topic:Slow performance of add command
Current Time: Tue Nov 04 08:46:54 EST 2025
Powered by FUDForum. Page generated in 0.04228 seconds
