Home » Eclipse Projects » Eclipse 4 » The Future - ARM CPU's(Eclipse support if Mac's switch from Intel )
Re: The Future - ARM CPU's [message #1827474 is a reply to message #1827463] |
Fri, 15 May 2020 09:15 |
Rolf Theunissen Messages: 260 Registered: April 2012 |
The majority of the Eclipse code is written in Java. As such, that code should run on any platform without modification.
Native code is used for some (core) parts, for instance SWT. There are currently different implementations for Linux/GTK, Windows and Mac OS, other platforms have been supported in the past. Also different CPU architectures are supported, currently x86 64-bit and Power 64-bit LE, other architectures have been supported in the past. For the current overview look at https://www.eclipse.org/projects/project-plan.php?planurl=http://www.eclipse.org/eclipse/development/plans/eclipse_project_plan_4_15.xml#target_environments
I expect that all major OSes on major Architectures will be supported by Eclipse.
Third parties can provide compiled binaries/ports for other platforms/architectures, such as Fedora does for ARM. When the target environment is close to the Eclipse supported platforms, porting should be easy, otherwise it is more involved.
Re: The Future - ARM CPU's [message #1842620 is a reply to message #1842612] |
Fri, 25 June 2021 15:45 |
Mykola Makhin Messages: 50 Registered: July 2018 |
Member |
Rolf Theunissen wrote on Fri, 25 June 2021 14:26Check the SWT FAQ: https://www.eclipse.org/swt/faq.php#howbuildjar
First thing I did.
It says precisely "NOTE: These instructions require you to use Eclipse"
And of course it's very vague. For example, how to figure out what this means:
"2. Compile the project. This will create a folder called bin under the org.eclipse.swt project."
Compile the project? How? Ant, Maven? Both build.xml and pom.xml are present, none work of course - build fails from cli for these.
Probably they mean to compile it in Eclipse. Which is again, a weird requirement to have (why would one even build SWT if they already have one bundled with Eclipse?)
Rolf Theunissen wrote on Fri, 25 June 2021 14:26Also the current thread on platform-dev mailing list about building the full Eclipse SDK from source on a unsupported platform: https://www.eclipse.org/lists/platform-dev/msg03037.html
I'm sorry, but I find mailing lists to be unusable. The forum is much, much better platform for communication.
[Updated on: Fri, 25 June 2021 15:47] Report message to a moderator
Re: The Future - ARM CPU's [message #1842632 is a reply to message #1842631] |
Fri, 25 June 2021 21:22 |
Member |
Ok, now I'm getting somewhere myself
Turns out one has to build from binaries repo anyway. At least it seems so to me at this point
I'm not sure which dependencies are needed for build, so far I've got these, but some of them may be irrelevant:
sudo apt install libswt-gtk-4-java libswt-cairo-gtk-4-jni
sudo apt install libequinox-osgi-java
sudo apt install maven ant
sudo apt install make gcc
sudo apt install libwebkit2gtk-4.0-dev
I've cloned source and binaries repo to /home/pi/tmp:
git clone https://git.eclipse.org/r/platform/eclipse.platform.swt.git
git clone https://git.eclipse.org/r/platform/eclipse.platform.swt.binaries.git
Next I took these steps:
1. In /home/pi/tmp/eclipse.platform.swt.binaries/bundles
copy org.eclipse.swt.gtk.linux.aarch64
to org.eclipse.swt.gtk.linux.armv7l
2. in org.eclipse.swt.gtk.linux.armv7l
grep -r "aarch64" . -l | xargs -I FN sed -i "s/aarch64/armv7l/g" FN
3. export JAVA_HOME=/usr/lib/jvm/java-1.11.0-openjdk-armhf
Do this or build will fail with inability to import jni.h
4. Run
ant -f ./eclipse.platform.swt.binaries/bundles/org.eclipse.swt.gtk.linux.armv7l/build.xml build_libraries
This works, but compilation fails so far because of long type for pointers, that apparently has to be changed to int. I'm figuring out now how to change that.
[Updated on: Fri, 25 June 2021 21:39] Report message to a moderator
Re: The Future - ARM CPU's [message #1842634 is a reply to message #1842632] |
Fri, 25 June 2021 21:43 |
Member |
Fixed pointer sizes in c.c file in source repo - bundles/org.eclipse.swt/Eclipse SWT PI/common/library/c.c
diff --git a/bundles/org.eclipse.swt/Eclipse SWT PI/common/library/c.c b/bundles/org.eclipse.swt/Eclipse SWT PI/common/library/c.c
index b626890a69..4a29874471 100644
--- a/bundles/org.eclipse.swt/Eclipse SWT PI/common/library/c.c
+++ b/bundles/org.eclipse.swt/Eclipse SWT PI/common/library/c.c
@@ -37,7 +37,7 @@ JNIEXPORT jint JNICALL C_NATIVE(PTR_1sizeof)
#ifndef NO_free
JNIEXPORT void JNICALL C_NATIVE(free)
- (JNIEnv *env, jclass that, jlong arg0)
+ (JNIEnv *env, jclass that, jint arg0)
C_NATIVE_ENTER(env, that, free_FUNC);
free((void *)arg0);
@@ -46,14 +46,14 @@ JNIEXPORT void JNICALL C_NATIVE(free)
#endif
#ifndef NO_getenv
-JNIEXPORT jlong JNICALL C_NATIVE(getenv)
+JNIEXPORT jint JNICALL C_NATIVE(getenv)
(JNIEnv *env, jclass that, jbyteArray arg0)
jbyte *lparg0=NULL;
- jlong rc = 0;
+ jint rc = 0;
C_NATIVE_ENTER(env, that, getenv_FUNC);
if (arg0) if ((lparg0 = (*env)->GetByteArrayElements(env, arg0, NULL)) == NULL) goto fail;
- rc = (jlong)getenv((const char *)lparg0);
+ rc = (jint)getenv((const char *)lparg0);
fail:
if (arg0 && lparg0) (*env)->ReleaseByteArrayElements(env, arg0, lparg0, 0);
C_NATIVE_EXIT(env, that, getenv_FUNC);
@@ -62,12 +62,12 @@ fail:
#endif
#ifndef NO_malloc
-JNIEXPORT jlong JNICALL C_NATIVE(malloc)
+JNIEXPORT jint JNICALL C_NATIVE(malloc)
- jlong rc = 0;
+ jint rc = 0;
C_NATIVE_ENTER(env, that, malloc_FUNC);
- rc = (jlong)malloc(arg0);
+ rc = (jint)malloc(arg0);
C_NATIVE_EXIT(env, that, malloc_FUNC);
return rc;
@@ -75,7 +75,7 @@ JNIEXPORT jlong JNICALL C_NATIVE(malloc)
#ifndef NO_memmove__JJJ
JNIEXPORT void JNICALL C_NATIVE(memmove__JJJ)
- (JNIEnv *env, jclass that, jlong arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jint arg1, jlong arg2)
C_NATIVE_ENTER(env, that, memmove__JJJ_FUNC);
memmove((void *)arg0, (const void *)arg1, (size_t)arg2);
@@ -85,7 +85,7 @@ JNIEXPORT void JNICALL C_NATIVE(memmove__JJJ)
#ifndef NO_memmove__J_3BJ
JNIEXPORT void JNICALL C_NATIVE(memmove__J_3BJ)
- (JNIEnv *env, jclass that, jlong arg0, jbyteArray arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jbyteArray arg1, jlong arg2)
jbyte *lparg1=NULL;
C_NATIVE_ENTER(env, that, memmove__J_3BJ_FUNC);
@@ -99,7 +99,7 @@ fail:
#ifndef NO_memmove__J_3CJ
JNIEXPORT void JNICALL C_NATIVE(memmove__J_3CJ)
- (JNIEnv *env, jclass that, jlong arg0, jcharArray arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jcharArray arg1, jlong arg2)
jchar *lparg1=NULL;
C_NATIVE_ENTER(env, that, memmove__J_3CJ_FUNC);
@@ -113,7 +113,7 @@ fail:
#ifndef NO_memmove__J_3DJ
JNIEXPORT void JNICALL C_NATIVE(memmove__J_3DJ)
- (JNIEnv *env, jclass that, jlong arg0, jdoubleArray arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jdoubleArray arg1, jlong arg2)
jdouble *lparg1=NULL;
C_NATIVE_ENTER(env, that, memmove__J_3DJ_FUNC);
@@ -127,7 +127,7 @@ fail:
#ifndef NO_memmove__J_3FJ
JNIEXPORT void JNICALL C_NATIVE(memmove__J_3FJ)
- (JNIEnv *env, jclass that, jlong arg0, jfloatArray arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jfloatArray arg1, jlong arg2)
jfloat *lparg1=NULL;
C_NATIVE_ENTER(env, that, memmove__J_3FJ_FUNC);
@@ -141,7 +141,7 @@ fail:
#ifndef NO_memmove__J_3IJ
JNIEXPORT void JNICALL C_NATIVE(memmove__J_3IJ)
- (JNIEnv *env, jclass that, jlong arg0, jintArray arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jintArray arg1, jlong arg2)
jint *lparg1=NULL;
C_NATIVE_ENTER(env, that, memmove__J_3IJ_FUNC);
@@ -155,7 +155,7 @@ fail:
#ifndef NO_memmove__J_3JJ
JNIEXPORT void JNICALL C_NATIVE(memmove__J_3JJ)
- (JNIEnv *env, jclass that, jlong arg0, jlongArray arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jlongArray arg1, jlong arg2)
jlong *lparg1=NULL;
C_NATIVE_ENTER(env, that, memmove__J_3JJ_FUNC);
@@ -169,7 +169,7 @@ fail:
#ifndef NO_memmove__J_3SJ
JNIEXPORT void JNICALL C_NATIVE(memmove__J_3SJ)
- (JNIEnv *env, jclass that, jlong arg0, jshortArray arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jint arg0, jshortArray arg1, jlong arg2)
jshort *lparg1=NULL;
C_NATIVE_ENTER(env, that, memmove__J_3SJ_FUNC);
@@ -183,7 +183,7 @@ fail:
#ifndef NO_memmove___3BJJ
JNIEXPORT void JNICALL C_NATIVE(memmove___3BJJ)
- (JNIEnv *env, jclass that, jbyteArray arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jbyteArray arg0, jint arg1, jlong arg2)
jbyte *lparg0=NULL;
C_NATIVE_ENTER(env, that, memmove___3BJJ_FUNC);
@@ -214,7 +214,7 @@ fail:
#ifndef NO_memmove___3CJJ
JNIEXPORT void JNICALL C_NATIVE(memmove___3CJJ)
- (JNIEnv *env, jclass that, jcharArray arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jcharArray arg0, jint arg1, jlong arg2)
jchar *lparg0=NULL;
C_NATIVE_ENTER(env, that, memmove___3CJJ_FUNC);
@@ -228,7 +228,7 @@ fail:
#ifndef NO_memmove___3DJJ
JNIEXPORT void JNICALL C_NATIVE(memmove___3DJJ)
- (JNIEnv *env, jclass that, jdoubleArray arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jdoubleArray arg0, jint arg1, jlong arg2)
jdouble *lparg0=NULL;
C_NATIVE_ENTER(env, that, memmove___3DJJ_FUNC);
@@ -242,7 +242,7 @@ fail:
#ifndef NO_memmove___3FJJ
JNIEXPORT void JNICALL C_NATIVE(memmove___3FJJ)
- (JNIEnv *env, jclass that, jfloatArray arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jfloatArray arg0, jint arg1, jlong arg2)
jfloat *lparg0=NULL;
C_NATIVE_ENTER(env, that, memmove___3FJJ_FUNC);
@@ -256,7 +256,7 @@ fail:
#ifndef NO_memmove___3IJJ
JNIEXPORT void JNICALL C_NATIVE(memmove___3IJJ)
- (JNIEnv *env, jclass that, jintArray arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jintArray arg0, jint arg1, jlong arg2)
jint *lparg0=NULL;
C_NATIVE_ENTER(env, that, memmove___3IJJ_FUNC);
@@ -287,9 +287,9 @@ fail:
#ifndef NO_memmove___3JJJ
JNIEXPORT void JNICALL C_NATIVE(memmove___3JJJ)
- (JNIEnv *env, jclass that, jlongArray arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jlongArray arg0, jint arg1, jlong arg2)
- jlong *lparg0=NULL;
+ jint *lparg0=NULL;
C_NATIVE_ENTER(env, that, memmove___3JJJ_FUNC);
if (arg0) if ((lparg0 = (*env)->GetPrimitiveArrayCritical(env, arg0, NULL)) == NULL) goto fail;
memmove((void *)lparg0, (const void *)arg1, (size_t)arg2);
@@ -301,7 +301,7 @@ fail:
#ifndef NO_memmove___3SJJ
JNIEXPORT void JNICALL C_NATIVE(memmove___3SJJ)
- (JNIEnv *env, jclass that, jshortArray arg0, jlong arg1, jlong arg2)
+ (JNIEnv *env, jclass that, jshortArray arg0, jint arg1, jlong arg2)
jshort *lparg0=NULL;
C_NATIVE_ENTER(env, that, memmove___3SJJ_FUNC);
@@ -314,12 +314,12 @@ fail:
#endif
#ifndef NO_memset
-JNIEXPORT jlong JNICALL C_NATIVE(memset)
- (JNIEnv *env, jclass that, jlong arg0, jint arg1, jlong arg2)
+JNIEXPORT jint JNICALL C_NATIVE(memset)
- jlong rc = 0;
+ jint rc = 0;
C_NATIVE_ENTER(env, that, memset_FUNC);
- rc = (jlong)memset((void *)arg0, arg1, (size_t)arg2);
+ rc = (jint)memset((void *)arg0, arg1, (size_t)arg2);
C_NATIVE_EXIT(env, that, memset_FUNC);
return rc;
@@ -346,7 +346,7 @@ fail:
#ifndef NO_strlen
JNIEXPORT jint JNICALL C_NATIVE(strlen)
jint rc = 0;
C_NATIVE_ENTER(env, that, strlen_FUNC);
Re: The Future - ARM CPU's [message #1842635 is a reply to message #1842634] |
Fri, 25 June 2021 21:59 |
Member |
Next is making callback.c to compile - so far it worked with this barbaric method:
sed -i 's/jlong/jint/g' "./eclipse.platform.swt/bundles/org.eclipse.swt/Eclipse SWT/common/library/callback.c"
+ fixing jint back to jlong in
jlong *elements = (*env)->GetLongArrayElements(env, argsArray, NULL);
at line 1934
Now I get a bunch of jlong/jint errors in os.c
Looks like way too many to fix for me though
Guess this is where I'm stuck now
[Updated on: Fri, 25 June 2021 22:04] Report message to a moderator
Current Time: Fri Apr 26 23:17:44 GMT 2024
Powered by FUDForum. Page generated in 0.04718 seconds
