Home » Language IDEs » C / C++ IDE (CDT) » Qt integration with eclipse
| Qt integration with eclipse [message #1827295] |
Tue, 12 May 2020 09:22  |
Hello all,
I am currently working on a project where we need to integrate Qt into eclipse. I have it mostly figured out. I am able to get intellisense to work with the Qt files. I am even able to successfully compile a Qt project!
I setup my external tools to run Qmake (for convenience because running it from the command line is annoying).
Like I said, I have it mostly working. When I go to create an executable from the project, the linker is called and I get an error: "undefined reference to `vtable for MainFrame'"
Ok, so looking into it some more, and going to stackoverflow, a number of answers basically point to the issue being the MOC. When I add a new class that uses the Q_OBJECT macro, I need to re run QMake.... Ok, So I re run Qmake, generate the build files, an I make sure that my build configuration is using an external makefile for the project.
Everything seems like it should be working.... but it is not. I am still getting the error...
So, has anyone done any work with Qt integration in eclipse? I am a little stumped on this issue and I am looking to get this solved as soon as possible.
Any feedback to greatly appreciated. Please let me know
[Updated on: Wed, 13 May 2020 13:45] by Moderator
| Re: Qt integration with eclipse [message #1827383 is a reply to message #1827366] |
Wed, 13 May 2020 19:44   |
Ok, so here is some information about the simple code that I created:
MainFrame.h
class MainFrame : public QMainWindow
Q_OBJECT
public:
explicit MainFrame(QWidget *parent = 0);
~MainFrame();
private:
//! The menu bar for the main window
The menu bar is kind of like a container where it contains all of the listings of the different
wxMenu classes.
For additional documentation on the wxMenuBar class, refer to the following link:
https://doc.qt.io/qt-5/qmenubar.html
QMenuBar *p_menubar = new QMenuBar();
QMenu *p_menuFile = new QMenu();
QMenu *p_menuEdit = new QMenu();
QMenu *p_menuView = new QMenu();
//! The problem menu for the menu bar
For additional documentation on the wxMenu class, refer to the following link:
http://docs.wxwidgets.org/trunk/classwx_menu.html
QMenu *p_menuProblem = new QMenu;
//! The grid menu for the menu bar
QMenu *p_menuGrid = new QMenu;
//! The properties menu for the menu bar
QMenu *p_menuProperties = new QMenu;
//! The mesh menu for the menu bar
QMenu *p_menuMesh = new QMenu;
//! The analysis menu for the menu bar
QMenu *p_analysisMenu = new QMenu;
//! The help menu for the menu bar
QMenu *p_menuHelp = new QMenu;
/** Menu Actions **/
QAction *p_newAction;
QAction *p_SaveAction;
QAction *p_SaveAsAction;
QAction *p_OpenAction;
QAction *p_ExitAction;
void setupMenuActions();
public slots:
void newActionSlot(bool checked);
void saveActionSlot(bool checked);
void saveAsActionSlot(bool checked);
void openActionSlot(bool checked);
void exitActionSlot(bool checked);
MainFrame.cpp
#include <MainFrame.h>
MainFrame::MainFrame(QWidget *parent) : QMainWindow(parent)
setupMenuActions();
p_menuFile = this->menuBar()->addMenu("File");
p_menuFile->addAction(p_newAction);
p_menuFile->addAction(p_SaveAction);
p_menuFile->addAction(p_SaveAsAction);
p_menuFile->addAction(p_OpenAction);
p_menuFile->addSeparator();
p_menuFile->addAction(p_ExitAction);
p_menuEdit = this->menuBar()->addMenu("Edit");
p_menuView = this->menuBar()->addMenu("View");
p_menuProblem = this->menuBar()->addMenu("Problem");
p_menuGrid = this->menuBar()->addMenu("Grid");
p_menuProperties = this->menuBar()->addMenu("Properties");
p_menuMesh = this->menuBar()->addMenu("Mesh");
p_analysisMenu = this->menuBar()->addMenu("Analysis");
p_menuHelp = this->menuBar()->addMenu("Help");
void MainFrame::setupMenuActions()
p_newAction = new QAction("&New", this);
p_newAction->setShortcut(QKeySequence::New);
connect(p_newAction, SIGNAL(triggered(bool)), this, SLOT(newActionSlot(bool)));
p_SaveAction = new QAction("&Save", this);
p_SaveAction->setShortcut(QKeySequence::Save);
connect(p_SaveAction, SIGNAL(triggered(bool)), this, SLOT(saveActionSlot(bool)));
p_SaveAsAction = new QAction("&Save As", this);
p_SaveAsAction->setShortcut(QKeySequence::SaveAs);
connect(p_SaveAsAction, SIGNAL(triggered(bool)), this, SLOT(saveAsActionSlot(bool)));
p_OpenAction = new QAction("&Open", this);
p_OpenAction->setShortcut(QKeySequence::Open);
connect(p_OpenAction, SIGNAL(triggered(bool)), this, SLOT(openActionSlot(bool)));
p_ExitAction = new QAction("&Open", this);
connect(p_ExitAction, SIGNAL(triggered(bool)), this, SLOT(exitActionSlot(bool)));
MainFrame::~MainFrame()
FileMenu.cpp
void MainFrame::newActionSlot(bool checked)
if(_UIState == systemState::MODEL_DEFINING || _UIState == systemState::PHYSICS_CHOOSING || _UIState == systemState::SIMULATING || _UIState == systemState::VIEWING_RESULTS)
// Create a message box confirming that the user would like to create a new file
if(wxMessageBox("Create New File?", "New File", wxOK | wxCANCEL | wxICON_QUESTION) == wxCANCEL)
return;
enableToolMenuBar(false);
_problemDefinition.defintionClear();
_saveFilePath = "";
if(_UIState == systemState::MODEL_DEFINING)
delete(_model);
createProblemChoosingClient();
void MainFrame::saveActionSlot(bool checked)
if(_saveFilePath != "")
save(_saveFilePath);
else
wxFileDialog saveFileDialog(this, "Save File", "", "", "", wxFD_SAVE | wxFD_OVERWRITE_PROMPT | wxFD_CHANGE_DIR);
if(saveFileDialog.ShowModal() != wxID_CANCEL)
wxString appendedTitle = "Omni-FEM - ";
wxString fileName;
if(saveFileDialog.GetFilename().Contains(wxString(".omniFEM")))
std::string tempFileName = saveFileDialog.GetFilename().ToStdString();
for(int i = 0; i < (tempFileName.length() - 8); i++)
fileName += wxString(tempFileName[i]);
else
fileName = saveFileDialog.GetFilename();
_problemDefinition.setName(fileName);
appendedTitle.append(_problemDefinition.getName());
this->SetTitle(appendedTitle);
_saveFilePath = saveFileDialog.GetPath();
_problemDefinition.setSaveFilePath(saveFileDialog.GetDirectory());
void MainFrame::saveAsActionSlot(bool checked)
wxFileDialog saveFileDialog(this, "Save File As", "", "", "", wxFD_SAVE | wxFD_OVERWRITE_PROMPT | wxFD_CHANGE_DIR);
wxString fileName;
else
void MainFrame::openActionSlot(bool checked)
wxFileDialog openFileDialog(this, "Open File", "", "", "*omniFEM", wxFD_OPEN | wxFD_FILE_MUST_EXIST | wxFD_CHANGE_DIR);
if(openFileDialog.ShowModal() != wxID_CANCEL)
if(_UIState != systemState::MODEL_DEFINING)
createModelDefiningClient();
if(_model)
_model->deleteMesh();
_model->SetSize(this->GetClientSize() - wxSize(12, 12));
wxString fileName;
_problemDefinition.setSaveFilePath(openFileDialog.GetDirectory());
std::string tempFileName = openFileDialog.GetFilename().ToStdString();
appendedTitle.append(fileName.ToStdString());
_saveFilePath = openFileDialog.GetPath();
load(openFileDialog.GetPath().ToStdString());
_model->Refresh(true);
// _model->Update();
// _model->UpdateWindowUI();
void MainFrame::exitActionSlot(bool checked)
Main.cpp
#include <QApplication>
#include "MainFrame.h"
int main(int argc, char *argv[])
QApplication a(argc, argv);
MainFrame mainProgram;
mainProgram.show();
return a.exec();
Here is my .pro file as generated by QMake:
# Automatically generated by qmake (3.1) Tue May 12 19:25:49 2020
TEMPLATE = app
TARGET = QTTest3
INCLUDEPATH += .
# The following define makes your compiler warn you if you use any
# feature of Qt which has been marked as deprecated (the exact warnings
# depend on your compiler). Please consult the documentation of the
# deprecated API in order to know how to port your code away from it.
DEFINES += QT_DEPRECATED_WARNINGS
# You can also make your code fail to compile if you use deprecated APIs.
# In order to do so, uncomment the following line.
# You can also select to disable deprecated APIs only up to a certain version of Qt.
#DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000 # disables all the APIs deprecated before Qt 6.0.0
# Input
HEADERS += MainFrame.h
SOURCES += main.cpp MainFrame.cpp MenuFile.cpp
And here is a copy of the output from a clean build:
19:30:57 **** Build of configuration Debug for project QTTest3 ****
make all
Building file: ../MainFrame.cpp
Invoking: GCC C++ Compiler
g++ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtWidgets -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtGui -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtCore -I/home/name/Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtX11Extras -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtNetwork -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtHelp -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtSql -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/Qt3DInput -O0 -g3 -Wall -c -fmessage-length=0 -fPIC -MMD -MP -MF"MainFrame.d" -MT"MainFrame.o" -o "MainFrame.o" "../MainFrame.cpp"
Finished building: ../MainFrame.cpp
Building file: ../MenuFile.cpp
g++ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtWidgets -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtGui -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtCore -I/home/name/Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtX11Extras -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtNetwork -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtHelp -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtSql -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/Qt3DInput -O0 -g3 -Wall -c -fmessage-length=0 -fPIC -MMD -MP -MF"MenuFile.d" -MT"MenuFile.o" -o "MenuFile.o" "../MenuFile.cpp"
Finished building: ../MenuFile.cpp
Building file: ../main.cpp
g++ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtWidgets -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtGui -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtCore -I/home/name/Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtX11Extras -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtNetwork -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtHelp -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtSql -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/ -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/Qt3DInput -O0 -g3 -Wall -c -fmessage-length=0 -fPIC -MMD -MP -MF"main.d" -MT"main.o" -o "main.o" "../main.cpp"
Finished building: ../main.cpp
Building target: QTTest3
Invoking: GCC C++ Linker
g++ -L/home/name/Qt/5.11.0/gcc_64/lib -L/home/name/Qt5.11.0/5.11.0/gcc_64/lib -o "QTTest3" ./MainFrame.o ./MenuFile.o ./main.o -lQt5Core -lQt5Widgets -lQt5Gui
./MainFrame.o: In function `MainFrame::MainFrame(QWidget*)':
/home/name/eclipse-workspace/QTTest3/Debug/../MainFrame.cpp:10: undefined reference to `vtable for MainFrame'
makefile:44: recipe for target 'QTTest3' failed
./MainFrame.o: In function `MainFrame::~MainFrame()':
/home/name/eclipse-workspace/QTTest3/Debug/../MainFrame.cpp:65: undefined reference to `vtable for MainFrame'
collect2: error: ld returned 1 exit status
make: *** [QTTest3] Error 1
19:31:01 Build Failed. 6 errors, 0 warnings. (took 4s.294ms)
Settings:
C/C++ General->Paths and Symbols For the settings, my "include directories" "includes path" is as follows:
Symbols is none.
Libraries is Qt5Core, Qt5Widgets, Qt5Gui
Library Paths is:
Everything is default.
C/C++ Build: For this, I do have the checkbox checked for Makefiles automatically. Everything is defaults
Settings: Under tool Settings, I made a change. In the miscellaneos section, I added a flag -fPIC. The compiler told me to do this becuase I can't compile without it.
Everything else is defaults.
| Re: Qt integration with eclipse [message #1827461 is a reply to message #1827390] |
Thu, 14 May 2020 20:11   |
David Vavra wrote on Thu, 14 May 2020 04:14Your build output seems to be using the makefile generated by Eclipse.
Why? Isn't the purpose of QMake to generate a makefile?
https://en.m.wikipedia.org/wiki/Qmake
FYI: "undefined reference" means something is missing from the link.
If you used the makefile generated by QMake your problem would likely vanish.
You really want a Makefile project.
Disable the generation of Makefiles by Eclipse.
Also, the build configuration is really the name of the build directory.
It's where Eclipse expects to find the makefile
And it will contain the objects and final executable.
It's doubtful that QMake out-of-the-box knows about Eclipse build configurations.
You don't really need one.
I usually have my makefiles output to an object directory
and put the makefile and executables in the project root.
Needless to say, I write my own makefiles.
I see...... so taking your advice, I went to properties->C/C++ Build/Makefile generation and unchecked the checkbox so the eclipse uses an external makefile. I then change the Build location/Build directory to be in the root folder (one up from the Debug folder, this is where QMake's Makefile is placed)
I also changed the QMake setting so that it generates a Makefile.
I run QMake, then I do a clean build..... Now, all of my statements are giving me issues because it can't find the include file for my Qt libraries. Ok, So for something quick and dirty, I give everything an absolute path. It compiles, mostly.
Now I am getting undefined reference to all of my Qt code such as QMenu, addAction, addMenu, etc. If it uses the Qt library, it is an error.
That sucks, I check my make file settings and everything looks like it is including what it should (Will be posting a cop of my make file in here)
I check my include paths in the project settings and that is also good. Weird, I have a feeling I have a small settings issue that I can't seem to track down.
Anyways, I check the build directory and low and behold, I have my moc files!
Cool, out of a hunch, I decide to switch back to the internal makefile setting. Run the build and boom, it compiled successfully, 0 errors, I go to link and it works! I go to run and it dies because I of a missing a symbol:
I add this command to my .bashrc and restart eclipse:
export LD_LIBRARY_PATH='/home/pe/qtbase/lib':$LD_LIBRARY_PATH;
and low-and-behold, my test program is working!
Awesome, now I need to improve the process! Any suggestions?
(Note: I am trying to add as much detail to these posts so that if 1) Someone else attempts to do the same thing as me, they can follow in my footsteps 2) in case I move my workstation over and forget everything that I did)
Makefile as generated by QMake:
# Makefile for building: QTTest3
# Generated by qmake (3.1) (Qt 5.11.0)
# Project: QTTest3.pro
# Template: app
# Command: /home/name/Qt5.11.0/5.11.0/gcc_64/bin/qmake -o Makefile QTTest3.pro
MAKEFILE = Makefile
####### Compiler, tools and options
CC = gcc
CXX = g++
DEFINES = -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB
CFLAGS = -pipe -O2 -Wall -W -D_REENTRANT -fPIC $(DEFINES)
CXXFLAGS = -pipe -O2 -Wall -W -D_REENTRANT -fPIC $(DEFINES)
INCPATH = -I. -I. -I../../Qt5.11.0/5.11.0/gcc_64/include -I../../Qt5.11.0/5.11.0/gcc_64/include/QtGui -I../../Qt5.11.0/5.11.0/gcc_64/include/QtCore -I. -isystem /usr/include/libdrm -I../../Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++
QMAKE = /home/name/Qt5.11.0/5.11.0/gcc_64/bin/qmake
DEL_FILE = rm -f
CHK_DIR_EXISTS= test -d
MKDIR = mkdir -p
COPY = cp -f
COPY_FILE = cp -f
COPY_DIR = cp -f -R
INSTALL_FILE = install -m 644 -p
INSTALL_PROGRAM = install -m 755 -p
INSTALL_DIR = cp -f -R
QINSTALL = /home/name/Qt5.11.0/5.11.0/gcc_64/bin/qmake -install qinstall
QINSTALL_PROGRAM = /home/name/Qt5.11.0/5.11.0/gcc_64/bin/qmake -install qinstall -exe
DEL_FILE = rm -f
SYMLINK = ln -f -s
DEL_DIR = rmdir
MOVE = mv -f
TAR = tar -cf
COMPRESS = gzip -9f
DISTNAME = QTTest31.0.0
DISTDIR = /home/name/eclipse-workspace/QTTest3/.tmp/QTTest31.0.0
LINK = g++
LFLAGS = -Wl,-O1 -Wl,-rpath,/home/name/Qt5.11.0/5.11.0/gcc_64/lib
LIBS = $(SUBLIBS) -L/home/name/Qt5.11.0/5.11.0/gcc_64/lib -lQt5Gui -lQt5Core -lGL -lpthread
AR = ar cqs
RANLIB =
SED = sed
STRIP = strip
####### Output directory
OBJECTS_DIR = ./
####### Files
SOURCES = main.cpp \
MainFrame.cpp \
MenuFile.cpp moc_MainFrame.cpp
OBJECTS = main.o \
MainFrame.o \
MenuFile.o \
moc_MainFrame.o
DIST = ../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/spec_pre.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/unix.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/linux.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/sanitize.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/gcc-base.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/gcc-base-unix.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/g++-base.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/g++-unix.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/qconfig.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3danimation.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3danimation_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dcore.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dcore_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dextras.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dextras_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dinput.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dinput_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dlogic.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dlogic_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquick.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquick_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickanimation.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickanimation_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickextras.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickextras_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickinput.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickinput_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickrender.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickrender_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickscene2d.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickscene2d_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3drender.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3drender_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_accessibility_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_bluetooth.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_bluetooth_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_bootstrap_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_charts.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_charts_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_concurrent.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_concurrent_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_core.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_core_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_datavisualization.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_datavisualization_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_dbus.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_dbus_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_designer.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_designer_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_designercomponents_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_devicediscovery_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_edid_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_egl_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_eglfs_kms_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_eglfsdeviceintegration_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_eventdispatcher_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_fb_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_fontdatabase_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gamepad.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gamepad_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_glx_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gui.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gui_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_help.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_help_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_input_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_kms_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_linuxaccessibility_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_location.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_location_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimedia.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimedia_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimediagsttools_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimediawidgets.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimediawidgets_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_network.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_network_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_networkauth.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_networkauth_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_nfc.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_nfc_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_opengl.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_opengl_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_openglextensions.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_openglextensions_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_packetprotocol_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_platformcompositor_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioning.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioning_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioningquick.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioningquick_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_printsupport.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_printsupport_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_purchasing.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_purchasing_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qml.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qml_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmldebug_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmldevtools_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmltest.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmltest_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qtmultimediaquicktools_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quick.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quick_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickcontrols2.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickcontrols2_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickparticles_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quicktemplates2_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickwidgets.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickwidgets_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_remoteobjects.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_remoteobjects_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_repparser.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_repparser_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_script.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_script_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scripttools.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scripttools_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scxml.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scxml_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sensors.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sensors_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialbus.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialbus_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialport.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialport_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_service_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sql.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sql_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_svg.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_svg_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_testlib.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_testlib_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_texttospeech.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_texttospeech_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_theme_support_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_uiplugin.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_uitools.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_uitools_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandclient.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandclient_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandcompositor.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandcompositor_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webchannel.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webchannel_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webengine.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webengine_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginecore.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginecore_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginecoreheaders_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginewidgets.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginewidgets_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_websockets.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_websockets_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webview.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webview_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_widgets.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_widgets_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_x11extras.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_x11extras_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xcb_qpa_lib_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xml.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xml_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xmlpatterns.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xmlpatterns_private.pri \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qt_functions.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qt_config.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++/qmake.conf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/spec_post.prf \
.qmake.stash \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/exclusive_builds.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/toolchain.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/default_pre.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/resolve_config.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/default_post.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/warn_on.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qt.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/resources.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/moc.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/unix/opengl.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/unix/thread.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qmake_use.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/file_copies.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/testcase_targets.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/exceptions.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/yacc.prf \
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/lex.prf \
QTTest3.pro MainFrame.h main.cpp \
MainFrame.cpp \
MenuFile.cpp
QMAKE_TARGET = QTTest3
DESTDIR =
TARGET = QTTest3
first: all
####### Build rules
$(TARGET): $(OBJECTS)
$(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJCOMP) $(LIBS)
Makefile: QTTest3.pro ../../Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++/qmake.conf ../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/spec_pre.prf \
.qmake.stash \
QTTest3.pro \
../../Qt5.11.0/5.11.0/gcc_64/lib/libQt5Gui.prl \
../../Qt5.11.0/5.11.0/gcc_64/lib/libQt5Core.prl
$(QMAKE) -o Makefile QTTest3.pro
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/spec_pre.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/unix.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/linux.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/sanitize.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/gcc-base.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/gcc-base-unix.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/g++-base.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/common/g++-unix.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/qconfig.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3danimation.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3danimation_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dcore.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dcore_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dextras.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dextras_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dinput.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dinput_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dlogic.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dlogic_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquick.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquick_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickanimation.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickanimation_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickextras.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickextras_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickinput.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickinput_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickrender.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickrender_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickscene2d.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3dquickscene2d_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3drender.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_3drender_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_accessibility_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_bluetooth.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_bluetooth_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_bootstrap_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_charts.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_charts_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_concurrent.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_concurrent_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_core.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_core_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_datavisualization.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_datavisualization_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_dbus.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_dbus_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_designer.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_designer_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_designercomponents_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_devicediscovery_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_edid_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_egl_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_eglfs_kms_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_eglfsdeviceintegration_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_eventdispatcher_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_fb_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_fontdatabase_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gamepad.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gamepad_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_glx_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gui.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_gui_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_help.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_help_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_input_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_kms_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_linuxaccessibility_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_location.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_location_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimedia.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimedia_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimediagsttools_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimediawidgets.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_multimediawidgets_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_network.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_network_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_networkauth.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_networkauth_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_nfc.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_nfc_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_opengl.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_opengl_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_openglextensions.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_openglextensions_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_packetprotocol_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_platformcompositor_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioning.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioning_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioningquick.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_positioningquick_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_printsupport.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_printsupport_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_purchasing.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_purchasing_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qml.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qml_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmldebug_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmldevtools_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmltest.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qmltest_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_qtmultimediaquicktools_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quick.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quick_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickcontrols2.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickcontrols2_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickparticles_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quicktemplates2_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickwidgets.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_quickwidgets_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_remoteobjects.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_remoteobjects_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_repparser.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_repparser_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_script.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_script_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scripttools.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scripttools_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scxml.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_scxml_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sensors.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sensors_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialbus.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialbus_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialport.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_serialport_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_service_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sql.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_sql_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_svg.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_svg_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_testlib.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_testlib_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_texttospeech.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_texttospeech_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_theme_support_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_uiplugin.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_uitools.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_uitools_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandclient.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandclient_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandcompositor.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_waylandcompositor_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webchannel.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webchannel_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webengine.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webengine_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginecore.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginecore_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginecoreheaders_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginewidgets.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webenginewidgets_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_websockets.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_websockets_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webview.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_webview_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_widgets.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_widgets_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_x11extras.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_x11extras_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xcb_qpa_lib_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xml.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xml_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xmlpatterns.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/modules/qt_lib_xmlpatterns_private.pri:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qt_functions.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qt_config.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++/qmake.conf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/spec_post.prf:
.qmake.stash:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/exclusive_builds.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/toolchain.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/default_pre.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/resolve_config.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/default_post.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/warn_on.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qt.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/resources.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/moc.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/unix/opengl.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/unix/thread.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/qmake_use.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/file_copies.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/testcase_targets.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/exceptions.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/yacc.prf:
../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/lex.prf:
QTTest3.pro:
../../Qt5.11.0/5.11.0/gcc_64/lib/libQt5Gui.prl:
../../Qt5.11.0/5.11.0/gcc_64/lib/libQt5Core.prl:
qmake: FORCE
@$(QMAKE) -o Makefile QTTest3.pro
qmake_all: FORCE
all: Makefile $(TARGET)
dist: distdir FORCE
(cd `dirname $(DISTDIR)` && $(TAR) $(DISTNAME).tar $(DISTNAME) && $(COMPRESS) $(DISTNAME).tar) && $(MOVE) `dirname $(DISTDIR)`/$(DISTNAME).tar.gz . && $(DEL_FILE) -r $(DISTDIR)
distdir: FORCE
@test -d $(DISTDIR) || mkdir -p $(DISTDIR)
$(COPY_FILE) --parents $(DIST) $(DISTDIR)/
$(COPY_FILE) --parents ../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/data/dummy.cpp $(DISTDIR)/
$(COPY_FILE) --parents MainFrame.h $(DISTDIR)/
$(COPY_FILE) --parents main.cpp MainFrame.cpp MenuFile.cpp $(DISTDIR)/
clean: compiler_clean
-$(DEL_FILE) $(OBJECTS)
-$(DEL_FILE) *~ core *.core
distclean: clean
-$(DEL_FILE) $(TARGET)
-$(DEL_FILE) .qmake.stash
-$(DEL_FILE) Makefile
####### Sub-libraries
mocclean: compiler_moc_header_clean compiler_moc_objc_header_clean compiler_moc_source_clean
mocables: compiler_moc_header_make_all compiler_moc_objc_header_make_all compiler_moc_source_make_all
check: first
benchmark: first
compiler_rcc_make_all:
compiler_rcc_clean:
compiler_moc_predefs_make_all: moc_predefs.h
compiler_moc_predefs_clean:
-$(DEL_FILE) moc_predefs.h
moc_predefs.h: ../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/data/dummy.cpp
g++ -pipe -O2 -Wall -W -dM -E -o moc_predefs.h ../../Qt5.11.0/5.11.0/gcc_64/mkspecs/features/data/dummy.cpp
compiler_moc_header_make_all: moc_MainFrame.cpp
compiler_moc_header_clean:
-$(DEL_FILE) moc_MainFrame.cpp
moc_MainFrame.cpp: /home/name/Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/QMainWindow \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qmainwindow.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qtwidgetsglobal.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qtguiglobal.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qglobal.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qconfig-bootstrapped.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qconfig.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qtcore-config.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qsystemdetection.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qprocessordetection.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qcompilerdetection.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qtypeinfo.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qsysinfo.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qlogging.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qflags.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qatomic.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qbasicatomic.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qatomic_bootstrap.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qgenericatomic.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qatomic_cxx11.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qglobalstatic.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qmutex.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qnumeric.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qversiontagging.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qtgui-config.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qtwidgets-config.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qwidget.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qwindowdefs.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qobjectdefs.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qnamespace.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qobjectdefs_impl.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qwindowdefs_win.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qobject.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qstring.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qchar.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qbytearray.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qrefcount.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qarraydata.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qstringliteral.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qstringalgorithms.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qstringview.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qstringbuilder.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qlist.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qalgorithms.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qiterator.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qhashfunctions.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qpair.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qbytearraylist.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qstringlist.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qregexp.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qstringmatcher.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qcoreevent.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qscopedpointer.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qmetatype.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qvarlengtharray.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qcontainerfwd.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qobject_impl.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qmargins.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qpaintdevice.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qrect.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qsize.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qpoint.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qpalette.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qcolor.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qrgb.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qrgba64.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qbrush.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qvector.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qmatrix.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qpolygon.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qregion.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qdatastream.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qiodevice.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qline.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qtransform.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qpainterpath.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qimage.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qpixelformat.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qpixmap.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qsharedpointer.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qshareddata.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qhash.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qsharedpointer_impl.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qfont.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qfontmetrics.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qfontinfo.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qsizepolicy.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qcursor.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qkeysequence.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qevent.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qvariant.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qmap.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qdebug.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qtextstream.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qlocale.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qset.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qcontiguouscache.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qurl.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qurlquery.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qfile.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qfiledevice.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qvector2d.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qtouchdevice.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qtabwidget.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qicon.h \
/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/QMenu \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qmenu.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qaction.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qactiongroup.h \
/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/QMenuBar \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qmenubar.h \
MainFrame.h \
moc_predefs.h \
../../Qt5.11.0/5.11.0/gcc_64/bin/moc
/home/name/Qt5.11.0/5.11.0/gcc_64/bin/moc $(DEFINES) --include ./moc_predefs.h -I/home/name/Qt5.11.0/5.11.0/gcc_64/mkspecs/linux-g++ -I/home/name/eclipse-workspace/QTTest3 -I/home/name/eclipse-workspace/QTTest3 -I/home/name/Qt5.11.0/5.11.0/gcc_64/include -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtGui -I/home/name/Qt5.11.0/5.11.0/gcc_64/include/QtCore -I/usr/include/c++/7 -I/usr/include/x86_64-linux-gnu/c++/7 -I/usr/include/c++/7/backward -I/usr/lib/gcc/x86_64-linux-gnu/7/include -I/usr/local/include -I/usr/lib/gcc/x86_64-linux-gnu/7/include-fixed -I/usr/include/x86_64-linux-gnu -I/usr/include MainFrame.h -o moc_MainFrame.cpp
compiler_moc_objc_header_make_all:
compiler_moc_objc_header_clean:
compiler_moc_source_make_all:
compiler_moc_source_clean:
compiler_yacc_decl_make_all:
compiler_yacc_decl_clean:
compiler_yacc_impl_make_all:
compiler_yacc_impl_clean:
compiler_lex_make_all:
compiler_lex_clean:
compiler_clean: compiler_moc_predefs_clean compiler_moc_header_clean
####### Compile
main.o: main.cpp /home/name/Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/QApplication \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qapplication.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qcoreapplication.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtCore/qeventloop.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtWidgets/qdesktopwidget.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qguiapplication.h \
../../Qt5.11.0/5.11.0/gcc_64/include/QtGui/qinputmethod.h \
MainFrame.h \
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o main.o main.cpp
MainFrame.o: MainFrame.cpp /home/name/eclipse-workspace/QTTest3/MainFrame.h \
../../Qt5.11.0/5.
| Re: Qt integration with eclipse [message #1827700 is a reply to message #1827464] |
Wed, 20 May 2020 22:27  |
Hey guys just want to give a quick update. I got it working at least the build part. Just want to post my steps on how I did it so that if some unfortunate soul decides to do what I did, this will help them out.
1) First, you need to create 3 external tools. All three will be referencing the location of qmake. So find that first. Again, there will be 3 external tools that we create with slightly different settings, their names will be qmake, QMake (.pro file), QMake (makefile)
qmake:
a) For this, set location to the location of qmake.
b) Working directory will be the top level source directory
c) Under the refresh tab, you want to refresh the specific resource which is this project. Check the Recursively include sub-folders options
d) under the Build tab, you want to build the specific project you are working with and to include referenced projects
e) Under Common tab, in the Display in favourites menu check external tools
QMake (.pro file)
a) Set location of qmake
b) Set the working directory to be the top level (I think it is fine if the .pro file is in the same folder as source)
c) Under arguments set
d) Uncheck the Refresh resources upon completion
e) Uncheck build before launch
f) Do same as e above
QMake (makefile)
b) Set the working directory to be the location that you want your build files to be located in
c) Set the arguments to be /location/to/.pro/file.pro -r
f) Do same as e in qmake heading
2) Now that we have our external tools configured, we will need to edit the build settings. Right click on the project in the Project Viewer of eclipse and go to Properties. Click on C/C++ Build option and go to the Builder Settings tab.
2a) Uncheck the Generate Makefiles automatically.
2b) Under Build Location, set the path to be the location of where you want your build files to be located.
2c) At this time, I have everything left as default. Although, I will probably change the Build Command to be something that will allow me to parallel build.
3) I am not sure if this is required, but I would recommend to set up your include paths and libraries under the C/C++ General->Paths and Symbols. For me the makefile is missing some libraries. I need to manually add them in. But it seems to catch some of the libraries in there. Not sure why it does that. Again, I am not sure if this step is necessary but it is at least good practice.
4) Now, we need to change the directory of the C/C++ Application. To do this, click the down arrow that is next to the run button in your tool bar. A window should come up with your project already ready to go. Under C/C++Application, change the folder location to be the location that you set your build directory.
Now that we have everything set up, the procedure to run everything is as follows:
1) Create your .pro file
2) Create the makefile
3) Right-click on the project in the project viewer and click build (or clean if you want to do a clean build)
4) Click on run
Note: There might be an additional step in there. Like for me I need to edit the makefile because it forgets to add in some libraries. I am still working on this issue.
Well, I hope that this post was informative to some people here on the forum. Happy coding.
Current Time: Sun Nov 09 22:26:04 EST 2025
Powered by FUDForum. Page generated in 0.05066 seconds
