Re: The 'no duplicates' constraint is violated [message #34312 is a reply to message #34246] |
Wed, 17 December 2003 14:45 |
Mike,
You need to provide more detail, like a stack trace. I'm not a mind
reader...
mike wrote:
> I get this error when trying to load an xsd file.
> My question is : is there a workaround?
> A quick and dirty load?
> thanx,
> --mike
Re: The 'no duplicates' constraint is violated [message #34380 is a reply to message #34312] |
Wed, 17 December 2003 15:09 |
Originally posted by: niemaz.xrce.xerox.com
Yep sorry, I wasn't quiet sure my message would be read.
Below is the stacktrace.
Seems to be the BasicEList#add method which catches the xsd incorrectness
and
sends the error.
--mike
java.lang.IllegalArgumentException: The 'no duplicates' constraint is
violated
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 12)
at
org.eclipse.emf.common.util.BasicEList$EListIterator.add(Bas icEList.java:1399)
at
org.eclipse.xsd.impl.XSDNamedComponentImpl.mergeToSortedList (XSDNamedComponentImpl.java:178)
at
org.eclipse.xsd.impl.XSDSchemaImpl.propogateComponents(XSDSc hemaImpl.java:2862)
at
org.eclipse.xsd.impl.XSDSchemaImpl.incorporate(XSDSchemaImpl .java:3027)
at
org.eclipse.xsd.impl.XSDSchemaImpl.included(XSDSchemaImpl.ja va:2946)
at
org.eclipse.xsd.impl.XSDIncludeImpl.handleResolvedSchema(XSD IncludeImpl.java:337)
at
org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchem aDirectiveImpl.java:405)
at
org.eclipse.xsd.impl.XSDIncludeImpl.patch(XSDIncludeImpl.jav a:324)
at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcr eteComponentImpl.java:513)
at
org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1494)
at
org.eclipse.xsd.impl.XSDSchemaImpl.incorporate(XSDSchemaImpl .java:3025)
at
at
at
at
at
at
at
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2240)
at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
at
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
at
org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:233)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 70)
at
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:374)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
at
org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchem aDirectiveImpl.java:380)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
Ed Merks wrote:
> Mike,
> reader...
> > thanx,
> > --mike
Re: The 'no duplicates' constraint is violated [message #34450 is a reply to message #34380] |
Wed, 17 December 2003 15:48 |
Mike,
Hmmm. There's some interesting include stuff going on here. Could you share the schemas that
produce this problem? If I have a working (i.e., failing) test case, I can get to the bottom of it
quickly...
> and
> sends the error.
> --mike
> violated
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Mike,
> > reader...
> > > thanx,
> > > --mike
Re: The 'no duplicates' constraint is violated [message #34484 is a reply to message #34450] |
Wed, 17 December 2003 16:03 |
I'm afraid I can't share this one, but I'll try to isolate the problem and
create a test file from it.
--mike
Ed Merks wrote:
> Mike,
> quickly...
> > and
> > sends the error.
> > --mike
> > violated
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Ed Merks wrote:
> > > Mike,
> > > reader...
> > > > thanx,
> > > > --mike
Re: The 'no duplicates' constraint is violated [message #34517 is a reply to message #34484] |
Wed, 17 December 2003 16:11 |
Mike,
That would be much appreciated. I may be able to fix this for the 2.0 drop later this week if you
act quickly. ;-)
> --mike
> Ed Merks wrote:
> > Mike,
> > quickly...
> > > and
> > > sends the error.
> > > --mike
> > > violated
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Ed Merks wrote:
> > > > Mike,
> > > > reader...
> > > > > thanx,
> > > > > --mike
Re: The 'no duplicates' constraint is violated [message #581885 is a reply to message #34484] |
Ed Merks Messages: 33142 Registered: July 2009 |
Mike,
act quickly. ;-)
> --mike
> Ed Merks wrote:
> > Mike,
> > quickly...
> > > and
> > > sends the error.
> > > --mike
> > > violated
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Ed Merks wrote:
> > > > Mike,
> > > > reader...
> > > > > thanx,
> > > > > --mike
Ed Merks
Re: The 'no duplicates' constraint is violated [message #996702 is a reply to message #996655] |
Wed, 02 January 2013 18:02 |
Max,
I was looking at how to fix it, which isn't hard, so I have a patch ready...
I also looked at the specification and I don't see any constraint that
says it's an error for them memberTypes attribute to specify the same
type more than once. If there were such a constraint, I would have had
a test case for it. So I think the semantic model is just supposed to
ignore duplicates, i.e., filter them out. I suppose it is bad style to
have duplicate, but not wrong, so that's how I'll handle the fix...
On 02/01/2013 5:06 PM, Ed Merks wrote:
> Max,
> The problem stems from duplicate union members:
> <xs:union memberTypes="m:length m:length"/>
> But we should diagnose that as an error not throw an exception. Please
> open a bugzilla and attach the sample zip file.
> I didn't know that at some point duplicate newsgroups were created. :-(
> This is the original one and I didn't know about the other one so I
> have only monitored this one. I've asked that the other one be
> terminated.
> On 01/01/2013 11:21 PM, Max Bureck wrote:
>> Hi,
>> I just found this old post. I have a problem with the same symptoms,
>> and created a post (including an XSD file causing the problem) in a
>> different forum:
>> http://www.eclipse.org/forums/index.php/t/445467/
>> BTW: What is the difference between the forum "Modeling » XSD" and
>> "Eclipse Projects » XML Schema Definition (XSD)"?
>> I hope this helps resolving the issue.
>> Best Regards,
>> Max
Ed Merks
FUDForum. Page generated in 0.03986 seconds
