Home » Language IDEs » ServerTools (WTP) » Server Tomcat v9.0 Server at localhost failed to start(only works with new projects)
| Server Tomcat v9.0 Server at localhost failed to start [message #1826995] |
Tue, 05 May 2020 18:08  |
Hi guys,
I have re-installed eclipse. When I tried to import my previous projects, they showed up on the "project explorer"... however, I get this message: "
Server Tomcat v9.0 Server at localhost failed to start"
The tomcat server seem working fine with new projects. But when I try to run a project from the imported ones, the server won't start !
I tried many tutorial on how to import projects properly with no luck!
Help me please :)
Adel
| Re: Server Tomcat v9.0 Server at localhost failed to start [message #1827083 is a reply to message #1827071] |
Wed, 06 May 2020 16:21   |
Before ,, when not project is added :
May 06, 2020 11:17:58 PM org.apache.catalina.core.AprLifecycleListener init
WARNING: The APR based Apache Tomcat Native library failed to load. The error reported was [C:\Program Files (x86)\Apache Software Foundation\Tomcat 9.0\bin\tcnative-1.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform]
java.lang.UnsatisfiedLinkError: C:\Program Files (x86)\Apache Software Foundation\Tomcat 9.0\bin\tcnative-1.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform
at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method)
at java.base/java.lang.ClassLoader$NativeLibrary.load(ClassLoader.java:2452)
at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(ClassLoader.java:2508)
at java.base/java.lang.ClassLoader.loadLibrary0(ClassLoader.java:2704)
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2637)
at java.base/java.lang.Runtime.load0(Runtime.java:745)
at java.base/java.lang.System.load(System.java:1871)
at org.apache.tomcat.jni.Library.<init>(Library.java:42)
at org.apache.tomcat.jni.Library.initialize(Library.java:206)
at org.apache.catalina.core.AprLifecycleListener.init(AprLifecycleListener.java:198)
at org.apache.catalina.core.AprLifecycleListener.isAprAvailable(AprLifecycleListener.java:107)
at org.apache.catalina.connector.Connector.<init>(Connector.java:83)
at org.apache.catalina.startup.ConnectorCreateRule.begin(ConnectorCreateRule.java:64)
at org.apache.tomcat.util.digester.Digester.startElement(Digester.java:1220)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:518)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:183)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1386)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2725)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:605)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:541)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:888)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:824)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1224)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:635)
at org.apache.tomcat.util.digester.Digester.parse(Digester.java:1478)
at org.apache.catalina.startup.Catalina.load(Catalina.java:566)
at org.apache.catalina.startup.Catalina.load(Catalina.java:607)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:303)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473)
May 06, 2020 11:17:58 PM org.apache.catalina.startup.VersionLoggerListener log
INFO: Server version name: Apache Tomcat/9.0.34
INFO: Server built: Apr 3 2020 12:02:52 UTC
INFO: Server version number: 9.0.34.0
INFO: OS Name: Windows 10
INFO: OS Version: 10.0
INFO: Architecture: amd64
INFO: Java Home: C:\Program Files\Java\jdk-14
INFO: JVM Version: 14+36-1461
INFO: JVM Vendor: Oracle Corporation
INFO: CATALINA_BASE: C:\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0
INFO: CATALINA_HOME: C:\Program Files (x86)\Apache Software Foundation\Tomcat 9.0
INFO: Command line argument: -Dcatalina.base=C:\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0
INFO: Command line argument: -Dcatalina.home=C:\Program Files (x86)\Apache Software Foundation\Tomcat 9.0
INFO: Command line argument: -Dwtp.deploy=C:\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps
INFO: Command line argument: -Dfile.encoding=Cp1252
May 06, 2020 11:17:58 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-nio-8080"]
May 06, 2020 11:17:58 PM org.apache.catalina.startup.Catalina load
INFO: Server initialization in [489] milliseconds
May 06, 2020 11:17:58 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service [Catalina]
May 06, 2020 11:17:58 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet engine: [Apache Tomcat/9.0.34]
May 06, 2020 11:17:58 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-nio-8080"]
May 06, 2020 11:17:58 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in [264] milliseconds
| Re: Server Tomcat v9.0 Server at localhost failed to start [message #1827084 is a reply to message #1827083] |
Wed, 06 May 2020 16:23   |
After trying running the project on server (run on server) :
May 06, 2020 11:21:24 PM org.apache.catalina.core.AprLifecycleListener init
May 06, 2020 11:21:24 PM org.apache.catalina.startup.VersionLoggerListener log
May 06, 2020 11:21:24 PM org.apache.coyote.AbstractProtocol init
May 06, 2020 11:21:24 PM org.apache.catalina.startup.Catalina load
INFO: Server initialization in [482] milliseconds
May 06, 2020 11:21:24 PM org.apache.catalina.core.StandardService startInternal
May 06, 2020 11:21:24 PM org.apache.catalina.core.StandardEngine startInternal
May 06, 2020 11:21:25 PM org.apache.catalina.core.ContainerBase startInternal
SEVERE: A child container failed during start
java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/S13_Web_App_with_JDBC]]
at java.base/java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.base/java.util.concurrent.FutureTask.get(FutureTask.java:191)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:916)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:841)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1384)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1374)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:909)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:421)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:930)
at org.apache.catalina.startup.Catalina.start(Catalina.java:633)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:343)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:474)
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/S13_Web_App_with_JDBC]]
at org.apache.catalina.util.LifecycleBase.handleSubClassException(LifecycleBase.java:440)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:198)
... 21 more
Caused by: java.lang.IllegalArgumentException: Invalid method resource injection annotation.
at org.apache.catalina.startup.WebAnnotationSet.loadMethodsAnnotation(WebAnnotationSet.java:291)
at org.apache.catalina.startup.WebAnnotationSet.loadApplicationServletAnnotations(WebAnnotationSet.java:138)
at org.apache.catalina.startup.WebAnnotationSet.loadApplicationAnnotations(WebAnnotationSet.java:69)
at org.apache.catalina.startup.ContextConfig.applicationAnnotationsConfig(ContextConfig.java:330)
at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:777)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:301)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5056)
... 27 more
java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: A child container failed during start
Caused by: org.apache.catalina.LifecycleException: A child container failed during start
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:928)
... 13 more
Caused by: java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/S13_Web_App_with_JDBC]]
... 21 more
... 21 more
... 27 more
May 06, 2020 11:21:25 PM org.apache.catalina.startup.Catalina start
SEVERE: The required Server component failed to start so Tomcat is unable to start.
Caused by: java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: A child container failed during start
... 13 more
... 13 more
... 21 more
... 21 more
... 27 more
May 06, 2020 11:21:25 PM org.apache.coyote.AbstractProtocol pause
INFO: Pausing ProtocolHandler ["http-nio-8080"]
May 06, 2020 11:21:25 PM org.apache.catalina.core.StandardService stopInternal
INFO: Stopping service [Catalina]
May 06, 2020 11:21:25 PM org.apache.coyote.AbstractProtocol destroy
INFO: Destroying ProtocolHandler ["http-nio-8080"]
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.apache.catalina.loader.WebappClassLoaderBase (file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation/Tomcat%209.0/lib/catalina.jar) to field java.io.ObjectStreamClass$Caches.localDescs
WARNING: Please consider reporting this to the maintainers of org.apache.catalina.loader.WebappClassLoaderBase
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
May 06, 2020 11:21:25 PM org.apache.catalina.deploy.NamingResourcesImpl cleanUp
WARNING: Failed to retrieve JNDI naming context for container [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/S13_Web_App_with_JDBC]] so no cleanup was performed for that container
javax.naming.NamingException: No naming context bound to this class loader
at org.apache.naming.ContextBindings.getClassLoader(ContextBindings.java:268)
at org.apache.catalina.deploy.NamingResourcesImpl.cleanUp(NamingResourcesImpl.java:1020)
at org.apache.catalina.deploy.NamingResourcesImpl.stopInternal(NamingResourcesImpl.java:1003)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:257)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5415)
at org.apache.catalina.util.LifecycleBase.destroy(LifecycleBase.java:293)
at org.apache.catalina.core.ContainerBase.removeChild(ContainerBase.java:817)
at org.apache.catalina.core.ContainerBase.destroyInternal(ContainerBase.java:1023)
at org.apache.catalina.util.LifecycleBase.destroy(LifecycleBase.java:321)
at org.apache.catalina.core.StandardService.destroyInternal(StandardService.java:556)
at org.apache.catalina.core.StandardServer.destroyInternal(StandardServer.java:1065)
at org.apache.catalina.startup.Catalina.start(Catalina.java:637)
Current Time: Sun Nov 02 21:34:06 EST 2025
Powered by FUDForum. Page generated in 0.05282 seconds
