| Problem with creating an HTML file ("Unable to start language server") [message #1826734] |
Wed, 29 April 2020 11:27  |
Good morning (or good evening, according to your time zone),
I've started using Eclipse a few weeks ago, using EPIC (I'm a Perl programmer trying to build a web application using Eclipse as an IDE).
Everything worked well for some days until today, when I reached the point where I had to create an HTML file.
I created the file in the file system (Linux Ubuntu), went back to Eclipse and made "refresh" on the right directory. The file appeared in the project explorer but when I doubled click on it to open it in the editor I got a lot of errors in the Workspace log saying:
Message:
Unable to start language server: HTML Language Server: ProcessStreamConnectionProvider [commands=[null, /home/max/.p2/pool/plugins/org.eclipse.wildwebdeveloper_0.5.6.202004101621/language-servers/node_modules/vscode-html-languageserver/dist/htmlServerMain.js, --stdio], workingDir=/home/max]
Exception stack trace:
java.io.IOException: Unable to start language server: HTML Language Server: ProcessStreamConnectionProvider [commands=[null, /home/max/.p2/pool/plugins/org.eclipse.wildwebdeveloper_0.5.6.202004101621/language-servers/node_modules/vscode-html-languageserver/dist/htmlServerMain.js, --stdio], workingDir=/home/max]
at org.eclipse.lsp4e.server.ProcessStreamConnectionProvider.start(ProcessStreamConnectionProvider.java:50)
at org.eclipse.lsp4e.LanguageServerWrapper.start(LanguageServerWrapper.java:213)
at org.eclipse.lsp4e.LanguageServerWrapper.getInitializedServer(LanguageServerWrapper.java:654)
at org.eclipse.lsp4e.LanguageServiceAccessor.lambda$14(LanguageServiceAccessor.java:589)
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
at java.util.Iterator.forEachRemaining(Iterator.java:116)
at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:546)
at java.util.stream.AbstractPipeline.evaluateToArrayNode(AbstractPipeline.java:260)
at java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:505)
at org.eclipse.lsp4e.LanguageServiceAccessor.getLanguageServers(LanguageServiceAccessor.java:602)
at org.eclipse.lsp4e.operations.highlight.HighlightReconcilingStrategy.collectHighlights(HighlightReconcilingStrategy.java:202)
at org.eclipse.lsp4e.operations.highlight.HighlightReconcilingStrategy.lambda$0(HighlightReconcilingStrategy.java:125)
at org.eclipse.core.runtime.jobs.Job$2.run(Job.java:185)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Session data:
eclipse.buildId=4.15.0.I20200305-0155
java.version=1.8.0_252
java.vendor=Private Build
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.javascript.product
Command-line arguments: -data file:/home/max/bin/eclipse/javascript-2020-03/eclipse/eclipse-workspace/ -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.javascript.product
I made a search in Google but I only find something related to C/C++ and was solved in a way that doesn't apply to me.
Every time I write anything in this HTML files one or more new error lines are appended to the log above.
Does anybody can help me out of this?
(I don't even know if this is the right forum to put this support request into. If not, I'm sorry, would you please point me to the right place?).
Thanks.
Ciao,
Max
FUDForum. Page generated in 0.16327 seconds
