Home » Eclipse Projects » Remote Application Platform (RAP) » Problem: Cannot selected row in checkbox tableviewer ?
Problem: Cannot selected row in checkbox tableviewer ? [message #1826270] Wed, 22 April 2020 10:08 Go to next message
I'm using Eclipse RAP 3.12
sorry, cannot provide real code snippet because i have defined a lot of helper functions in my application.
- create CheckboxTableViewer (SWT.CHECK | SWT.VIRTUAL)
- Scrolling down
- cannot "check" the checkbox for those items. Only the preloaded items at the beginning of the table can be "checked".
Whenn the table is not virtual, the problem does not exist.
Sorry, cannot create bug report, because Eclipse.org bugzilla won't let me log in now (grrr).
Re: Problem: Cannot selected row in checkbox tableviewer ? [message #1826314 is a reply to message #1826270] Thu, 23 April 2020 07:34 Go to previous messageGo to next message
in order to reproduce and fix the issue we need a simple self-running snippet that demonstrate the problem.
Ivan
Re: Problem: Cannot selected row in checkbox tableviewer ? [message #1826444 is a reply to message #1826314] Fri, 24 April 2020 18:09 Go to previous message
I confirmed this can be reproduced using the RAP Controls Demo with a slight modification to the code in TableViewerTab to create a CheckboxTableViewer instead. You can see that if you create the viewer as VIRTUAL, then add 100 items, you can't check those items. If the viewer is not virtual it works as expected.
Here is the change I made in TableViewerTab#createViewer:
// viewer = new TableViewer( parent, getStyle() );
viewer = CheckboxTableViewer.newCheckList(parent, getStyle());
If I have some time this weekend or next week, I'll look into it and see if I can find the problem.
Previous Topic:rap GC
Next Topic:RemoteObject-based Custom widget development
Current Time: Mon Nov 03 18:46:54 EST 2025
Powered by FUDForum. Page generated in 0.04405 seconds
