Home » Newcomers » Newcomers » Fonts in Eclipse(How to set all the fonts in the Eclipse Interface)
Fonts in Eclipse [message #1824511] Thu, 16 April 2020 12:27 Go to next message
New to eclipse. Using 2020_03 on a 2K monitor, and fonts are small.
Searches found settings in Window>> preferences>>basic>>textFont and that changes alot. And found a Header Font somewhere that helps too.
But the tree to the left - Package Explorer, and the Properties panels are still very small - 9pt? I need about 12pt. I've searched the whole list and can't find it.
Any pointers to where these fonts are set so I can stop squinting? ;)
The whole interface is awesomely functional. Great job folks.
I'm beginning to learn WindowBuilder layouts. Moving here after years of Qt and finally gave up on their Deployment or Non-Deployment in favor of Java for Windows / Linux.
Thanks.
Re: Fonts in Eclipse [message #1824530 is a reply to message #1824511] Fri, 17 April 2020 00:35 Go to previous messageGo to next message
I have a feeling there is no control over this font. The Tree widget is a native widget and will use the same font (by default) as is used everywhere else on the OS. So on Windows, for example, you can choose to show larger fonts in general and the font used by the Windows Explorer is the same one used by the Package Explorer view.
Re: Bad Fonts in Eclipse [message #1829613 is a reply to message #1824511] Tue, 07 July 2020 11:53 Go to previous messageGo to next message
I have a bizarre issue too: the fonts are lost after opening any modal dialog in eclipse (i.e. Project Properties Dialog).
This happens recently since the Windows 10 build 20161.
How can we fix it?
PS: it is not related to eclipse version ... I tried with many eclipse versions: 2020-06, 2019-09, Oxygen, Mars 3 ... all have the same bad behavior ... as well as the TortoiseSVN.
Please help !!!
  • Attachment: bad.fonts.png
    (Size: 164.18KB, Downloaded 137 times)
Re: Bad Fonts in Eclipse [message #1829631 is a reply to message #1829613] Wed, 08 July 2020 00:05 Go to previous messageGo to next message
It sounds a bit similar to this issue:
https://www.eclipse.org/forums/index.php/mv/msg/1103388/1829613/#msg_1829613
But I think you posted on that thread already. Didn't that setting help? Or are the bold fonts the results after?
Re: Bad Fonts in Eclipse [message #1829640 is a reply to message #1829631] Wed, 08 July 2020 03:57 Go to previous message
Hi Ed,
Thank you for your msg. Nope, the setting didn't change anything.
It always happens when open an eclipse Dialog, tried on many eclipse versions, as I described in the below bug.
So, I opened the bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=565025
I think in the last preview build 20161 of the Windows 10, they removed a font, and all the eclipse versions, plus tortoise svn, do have that hardcoded somewhere.
Waiting for a better version of eclipse :)
/S
[Updated on: Wed, 08 July 2020 04:14] by Moderator
Previous Topic:Failed to create the Java Virtual Machine on Mac
Next Topic:Crashed after Installation of EclipseWebTool Platform
Current Time: Sat Oct 25 06:45:35 EDT 2025
Powered by FUDForum. Page generated in 0.10986 seconds
