Problems with GDB with Eclipse for C/C++ on Windows [message #1824396] |
Tue, 14 April 2020 17:46 |
Robin Mueller Messages: 6 Registered: April 2020 |
I am trying to debug a very simple Hello World application with Eclipse IDE for C/C++ Developers Version: 2020-03 (4.15.0).
I tried an own Makefile project and the CDT managed build. In both cases
i get the following errors in dthe debugger. Running works without issues:
Thread #1 0 (Suspended: Error: Command Aborted)
Does anyone have an idea why gdb does not work?
I attached the error and the gdb settings.
Kind Regards
Robin
[Updated on: Wed, 15 April 2020 17:59] Report message to a moderator
Re: Problems with GDB with Eclipse for C/C++ on Windows [message #1828288 is a reply to message #1828190] |
Fri, 05 June 2020 21:04 |
Alright , I will look into this.
Running gdb and running the application from the command line the classic way works ,thats what I mean. I can also run the application from eclipse, but there are issues with getting the output from the console as well. (and I dont have that problem from the command line as well).
As you guessed this is not a code specific problem. I get his problem running the most simple C++ program. I suspect it is windows / msys2 related like you said but I am just wondering why I can run gdb from command line and not from eclipse
[Updated on: Fri, 05 June 2020 22:18] Report message to a moderator
FUDForum. Page generated in 0.04114 seconds
