Home » Eclipse Projects » Oomph » installation.location/eclipse on macOS
installation.location/eclipse on macOS [message #1823512] Fri, 27 March 2020 17:47 Go to next message
I'm trying to create a Product Setup model and make some changes to the installation, which requires knowing where Eclipse is installed. I have a variable declared as
${installation.location|uri}/eclipse
but apparently on Mac this isn't correct: it should be ${installation.location|uri}/Eclipse.app. Is there some variable to get the actual installation folder?
Thanks.
Re: installation.location/eclipse on macOS [message #1823522 is a reply to message #1823512] Sat, 28 March 2020 01:54 Go to previous messageGo to next message
You can use a combination of variables:
<setup:VariableTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    name="installation.full.path"
    value="${installation.location/}${installation.relativeProductFolder}"/>
And then you can use ${installation.full.path|uri} if you need the URI for that.
Another trick is to use "configuration:/" to express a reference to installation's configuration folder. E.g., I use this to copy the vi plugin's license to each installation:
<setup:ResourceCopyTask
    xmi:version="2.0"
    sourceURL="file:/C:/Users/merks/viPlugin2.lic"
    targetURL="configuration:/../"/>
Re: installation.location/eclipse on macOS [message #1823533 is a reply to message #1823522] Sat, 28 March 2020 09:14 Go to previous messageGo to next message
Great, thanks! For future reference, I was wondering if there's somewhere I can find a list of these variables and their properties? The "Eclipse Oomph Authoring" wiki page only has variables starting with "scope." which isn't complete.
Re: installation.location/eclipse on macOS [message #1823563 is a reply to message #1823533] Sat, 28 March 2020 23:50 Go to previous message
The information you were looking for is actually in https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Declaring_and_Using_Variables:
Attribute values of setup tasks with a defined ID. The reference syntax is ${taskID.attributeName}.
What's really missing is a reference of all the setup tasks with all their attributes.
Previous Topic:Simple "Find and Replace" TextModification
Next Topic:Use eclipse.user.password in github project model.
Current Time: Sun Aug 17 18:22:44 EDT 2025
Powered by FUDForum. Page generated in 0.03658 seconds
