Home » Language IDEs » C / C++ IDE (CDT) » My HelloWorld project won't compile
My HelloWorld project won't compile [message #1823503] Fri, 27 March 2020 13:15 Go to next message
As a newbe to Eclipse, I'm trying to get my HelloWorld project to compile, but the system keeps on compiling my 'LANG2' project instead. How can I get Eclipse to understand which project I want to compile?
Re: My HelloWorld project won't compile [message #1823516 is a reply to message #1823503] Fri, 27 March 2020 18:46 Go to previous message
Generally by using Project --> Build Project if an editing file within the project is the active window.
OR, select the project in the Project View then <right click> --> Build Project
https://help.eclipse.org/2020-03/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Fgetting_started%2Fcdt_w_build.htm
If that's not working, you'll have to be more specific about what you are doing,
which version of Eclipse you have along with the version of CDT you are using,
the OS and what plugins (if any) you are using.
Previous Topic:Debugger problem
Next Topic:Problem with Arduino Download Manager
Current Time: Thu Nov 06 07:48:31 EST 2025
Powered by FUDForum. Page generated in 0.04277 seconds
