Getting SSL cert error trying to install plugins from two different sites [message #1823472] |
Fri, 27 March 2020 05:08 |
David M. Karr Messages: 802 Registered: July 2009 |
In recent versions of Eclipse, I'm having trouble installing two different plugins. The two plugin names are "Bash Editor" and "Emacs+". For both of these, when I try to connect to the update site, I get "unable to find valid certification path to requested target".
The typical solution to this is to download the site certificate as a ".cer" file, and install it into the "cacerts" file with keytool, in the JDK being used to run Eclipse. I have DONE this for both certificates.
Initially, I was running Eclipse with Java 12, even though my code is compiled with Java 8. Today I tried upgrading the "running" jdk to Java 14, and reimporting the certs into that JDK. No change.
I'm running Windows 10 1809, if that matters.
FUDForum. Page generated in 0.09410 seconds
