| Delayed Model Change Job Error Panel In 2020-03 [message #1823305] |
Tue, 24 March 2020 12:03  |
Yesterday (03/24/2020) I applied the 2020-03 updates to my 2019-12 version of Eclipse. Now I'm getting nuisance pop-panels with window title "Multiple Errors Have Occurred", content title "An internal error has occurred.", and several additional lines that say "Delayed model change job" (see attached image).
So far this is only happening when I have the debugger attached. I timed the appearances, and in my current debug session the panel(s) appear about every 5 minutes. Sometimes I get just one panel; other times I'll get a series of two or three in close succession. And they steal keyboard focus from whatever you're doing - meh.
If you click on "Details >>" it says "An internal error has occurred. Index out of bounds".
This particular workspace was rebuilt from scratch i.e it is not an updated 2019-12 workspace, so no lingering data should be in there.
I also updated Eclipse on my home system, and it's doing the same thing. So... it's probably not anything on the machines.
Anybody have any clues regarding what's going on and how to make it stop (other than switching back to 2019-12)?
Rob
| Re: Delayed Model Change Job Error Panel In 2020-03 [message #1823446 is a reply to message #1823317] |
Thu, 26 March 2020 15:11  |
The were quick to mark my bug 561427 as a duplicate of 561338, so the dev team is apparently getting hit over the head with it.
FWIW - and as mentioned somewhere in 561338 - if you jigger around with the thread display filters you can convince it to stop complaining. I can't say exactly what I changed there to make it stop complaining because it seems like the configuration ended up about back where I started. But anyway, if this panel is bugging anybody, try fiddling with those settings and you might get lucky.
FUDForum. Page generated in 0.04912 seconds
