Home » Eclipse Projects » EGit / JGit » After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD
After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823170] Fri, 20 March 2020 17:49 Go to next message
David M. Karr is currently offline David M. KarrFriend
I upgraded to 2020-03 a couple of days ago. Since then, I've seen a couple of cases of files that show up in the "Unstaged changes" list in the "Git Staging View", and when I look at the changes in the file, there are none. I then right-click on it and select "Replace with HEAD revision". This results in ... no change. The file still has no changes, and still says there are unstaged changes, even after replacing it with the HEAD revision. This is happening in two different repos in our projects.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823185 is a reply to message #1823170] Sat, 21 March 2020 15:32 Go to previous messageGo to next message
Thomas Wolf is currently offline Thomas WolfFriend
Without more details it's impossible to investigate this. Please open a bug report an provide a test case that reproduces the problem.
Does it occur in a fresh clone, too?
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823189 is a reply to message #1823185] Sat, 21 March 2020 17:44 Go to previous messageGo to next message
BTW: I remember now that I had a file some months back that showed such symptoms, too.
Turned out the file was using mixed line endings (some lines ending in CR-LF, others in LF only). So check for that and normalize to either CR-LF or LF throughout.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823208 is a reply to message #1823189] Sun, 22 March 2020 17:47 Go to previous messageGo to next message
I just dumped the file with "od -h" and looked at every single line ending in the file. Every single one was a "\r" followed by a "\n", the same as in every other text file I've looked at. I also looked at the file in the BitBucket Server gui, but I don't know what I would look for. I suppose it's possible that if it's stored with inconsistent line endings on the server, when I checked it out it might try to normalize all the lines, making some different from the server and some not, which might make the client think there are differences, but the file display in the BitBucket Server gui doesn't offer the option of showing raw character codes.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823220 is a reply to message #1823208] Mon, 23 March 2020 05:44 Go to previous messageGo to next message
In the worst case, there can even be files with mixed line endings that have been committed to the repository. It's really tricky to determine whether a file has been committed with the wrong line endings on the server and then to commit the changes necessary to correct the problem. Many of the platform repositories had exactly this type of problem.
https://bugs.eclipse.org/bugs/buglist.cgi?list_id=19315402&query_format=advanced&short_desc=%20%09Fix%20files%20that%20have%20ended%20up%20with%20CRLF%20in%20the%20git%20repositor&short_desc_type=allwordssubstr
To fix this type of problem, I wrote a utility that uses JGit. I installed it via the feature "Oomph Git Bash" from https://download.eclipse.org/oomph/updates/milestone/latest and then the context menu of a Repository in the Git Repositories view has additional menu items including "Fix CRLF":
https://git.eclipse.org/c/oomph/org.eclipse.oomph.git/tree/plugins/org.eclipse.oomph.gitbash/src/org/eclipse/oomph/gitbash/repository/FixCRLFAction.java
This action will copy the repository, configure it to not convert LF to CRLF, reset the working the working tree of the copy, and then visit all the non-binary files to convert CRLF to LF. The copy is made visible in the Repositories view. If there are any files with issues, the tree will be dirty, and the fixes can be committed to correct the problem. Of course it's possible but tricky to do this manually too...
Ed Merks
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823261 is a reply to message #1823220] Mon, 23 March 2020 19:34 Go to previous messageGo to next message
Curiously, this problem appears to have gone away. It seems unrelated, but since I made the initial report, I updated the Spring IDE plugin from version 4.5.1 to 4.6.0. I checked the commits in the central repository, and no change was made to that file.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823295 is a reply to message #1823261] Tue, 24 March 2020 13:31 Go to previous messageGo to next message
I spoke too soon. The issue is back with the same file. I'm going to query the rest of my team to see if any of them are seeing the same thing, especially one other person who I know recently upgraded to 2020-03.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823296 is a reply to message #1823295] Tue, 24 March 2020 13:50 Go to previous messageGo to next message
And now I see that this symptom is causing a bigger problem. No matter what I do, it thinks there are changes in that file, so it won't let me switch to another branch. It continually prompts me to discard, stash, or commit the changes. I can't commit the change, and I've tried discard and stash, and also a hard reset. I needed to make a change in that repo on another branch, and I had to ask someone else on the team to make the change.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823302 is a reply to message #1823296] Tue, 24 March 2020 15:40 Go to previous messageGo to next message
1. Does this occur in a fresh clone, too?
2. Does this occur in a fresh clone cloned with core.autocrlf = false in your user git config?
3. Did you check whether the file was committed with mixed line endings?
4. Is this repo publicly accessible so that I could give it a try?
5. If not: can you put together a small public repo that reproduces the problem?
Regarding (3), I think you could get the raw file contents as committed using something like
git cat-file $(git ls-tree HEAD^1 PATH | cut -d' ' -f 2,3 | cut -f 1) > foo.txt
where PATH is the repository-relative path (using forward slashes /) of the file you want to check. The command places the result in file foo.txt; then examine that.
Oh, and one other thing: what's your setting for core.filemode? It should be set to false. Compare this old thread: https://www.eclipse.org/forums/index.php/m/1761332/#msg_1761332 .
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823306 is a reply to message #1823302] Tue, 24 March 2020 16:45 Go to previous messageGo to next message
Yes. In fact, this now shows TWO files with the same symptom.
NO. This seems like it would be a very important point, but I don't know what to make of this.
I don't see any way to determine that. Your command line to extract the "raw file" didn't give me any clues. The file in the original cloned repository appears to show all line endings as "\r\n" (shown in "od -c").
No.
I don't see how. I don't understand why this is happening.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823313 is a reply to message #1823306] Tue, 24 March 2020 18:18 Go to previous messageGo to next message
On the same laptop, I ran an Ubuntu VM, installed the corresponding version of Eclipse, cloned the repository, and I do not see the symptom. This seems to indicate even more that this is a line-ending issue, but I can't figure it out.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823318 is a reply to message #1823313] Tue, 24 March 2020 20:50 Go to previous messageGo to next message
OK, we're getting closer. Can you show me the output of
again with PATH being the repository-relative path of the file, with forward slashes? (If you consider the file path sensitive information, blank it out. I'm only interested in the first six digits, which should be either 100644 or 100755.)
[Updated on: Tue, 24 March 2020 20:55]
Report message to a moderator
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823319 is a reply to message #1823318] Tue, 24 March 2020 21:15 Go to previous messageGo to next message
It's
100755 blob 922791ae4bbe9435f4e26474bcc66838d0f0676a	 ...
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823326 is a reply to message #1823319] Tue, 24 March 2020 23:22 Go to previous messageGo to next message
I though so: the executable bit is set. It's a bug in JGit :-(. I'll fix this tomorrow. The problem should occur since EGit 5.6.0. What was your previous EGit version?
Out of interest: I assume this is a *.bat file. (A shell script with CRLF endings wouldn't work.) Why do you set the executable bit on that? I thought Windows didn't care?
As a work-around, try removing the executable bit (possibly via command-line git). That should resolve it.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823329 is a reply to message #1823326] Wed, 25 March 2020 00:23 Go to previous messageGo to next message
Considering this isn't supposed to be an executable file, removing the bit should be no problem. We do have some shell scripts in git, but I don't typically check out that repository. Is this going to be a problem for those files?
I don't know what the previous version would have been. It would have been the one that went with 2019-12.
So you're suggesting I do a "chmod -x" on the file and commit that? Assuming that's what you mean, I guess I'll have to do this on my Linux VM. Because of this problem, I can't change to a feature branch to make the change, and I can't commit directly to master. It doesn't cause a problem on my Linux VM, so I should be able to do it there.
[Updated on: Wed, 25 March 2020 00:27]
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823330 is a reply to message #1823329] Wed, 25 March 2020 00:31 Go to previous messageGo to next message
Hmm, now that I'm looking at this a little closer, I find it hard to believe this could be the problem. I looked at that particular file, and looked at all the files in the same directory as that file. There are perhaps ten other files there, and ALL of them have the execute bits on. None of them are actually executable files, they are all configuration/property files. I'm seeing the symptom with one or two of these files.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823333 is a reply to message #1823330] Wed, 25 March 2020 08:12 Go to previous messageGo to next message
Then double check the other files. Do they have CR-LF or LF in the committed version? The problem occurs only for executable files where the committed version in the git repository has CR-LF line endings. (Which, if everybody working on Windows has core.autocrlf = true set, should not occur.)
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823337 is a reply to message #1823333] Wed, 25 March 2020 08:57 Go to previous messageGo to next message
See bug 561438.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823374 is a reply to message #1823333] Wed, 25 March 2020 16:06 Go to previous messageGo to next message
Thomas Wolf wrote on Wed, 25 March 2020 01:12
I just went to my Linux VM, and used that "cat-file" example you cited above. The result showed \r\n sequences. This appears to be the abnormal situation you said should not occur. I believe in this case, "should" means "probably should not happen when people are paying attention".
So, it seems like this situation is a combination of a few problems. Our configuration files, which have been mangled in the repository with execute bits they don't need, and the wrong line endings, and your code somehow has trouble dealing with that mess. :)
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823378 is a reply to message #1823374] Wed, 25 March 2020 16:47 Go to previous messageGo to next message
Yes. The combination that triggers the bug is
  1. core.autocrlf=true (or equivalent settings via .gitattributes)
  2. executable bit on the git index version is set
  3. git index version uses CR-LF as line endings
The bug is only triggered if all three conditions are fulfilled.
Which also tells us possible work-arounds:
  1. set core.autocrlf=false (may not be practical)
  2. remove executable bit
  3. change git index version to use LF as line endings
Regarding (2): yes, that's chmod -x. To do so in the git index directly, I think it'd be "git update-index --chmod=-x path/to/file" or maybe (on newer git) "git add --chmod=-x path/to/file", then commit.
Regarding (3): one way of doing that is
  • set core.autocrlf=false
  • change line endings to LF in working tree file
  • commit
  • set core autocrlf=true
  • checkout the file again, or reset
The file should now have LF in the git repository but CR-LF in the working tree again.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823925 is a reply to message #1823378] Fri, 03 April 2020 23:36 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Please retry using the latest nightly build from https://download.eclipse.org/egit/updates-nightly the bug 561438 was fixed
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823957 is a reply to message #1823925] Sat, 04 April 2020 15:02 Go to previous messageGo to next message
Before installing the nightly update, I looked at two repos that were showing one modified file with no obvious changes. After the update, one of them resulted in no changes. After the update, I looked closer at the one that still had one file that stays in the "Unstaged changes" list even though it appears to have no changes. I used the "raw file" example you showed earlier on that file, and also on another file in the same directory that is not showing up in "Unstaged changes". The file that is NOT showing up in unstaged changes shows newlines with just "\n". The file that is still in "Unstaged changes" is showing newlines with "\r\n". Both files have permissions bits of "100644".
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823958 is a reply to message #1823957] Sat, 04 April 2020 15:51 Go to previous messageGo to next message
And what are the crlf settings in git config and gitattributes? What are the line endings in the file system?
Does the problem persist in a fresh clone?
Does the problem persist if you re-build the index? (Delete it and run a git status on the command line afterwards.)
It would be really helpful if you could put together a small demo repo at Github with which one could reproduce your problems. Without this, we're poking around in the dark.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823961 is a reply to message #1823958] Sat, 04 April 2020 17:03 Go to previous messageGo to next message
Thomas Wolf wrote on Sat, 04 April 2020 08:51
I'll answer what I can answer for now, and ask some qualifying questions.
The "System" tab in git configuration shows core.autocrlf = true. This is Windows 10, so standard line endings are \r\n.
Curiously, a fresh clone of the same repository, with the same branch checked out, does not show the symptom.
I don't know how to check "gitattributes". I don't know how to delete the index.
If I run "git status" on the command line, I'll need to be reminded how to run the same git that Eclipse is using. My default command line git is from Cygwin, which I believe might present different results.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823962 is a reply to message #1823961] Sat, 04 April 2020 17:43 Go to previous messageGo to next message
"Deleting the index" would mean deleting the file .git/index. Running git status afterwards re-creates it.
Checking gitattributes: probably you don't use them if you don't know how to check them. Would involve looking through the .gitattribute files for entries that match the file in question.
But anyway, since the problem does not occur in a new clone I consider this resolved.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823963 is a reply to message #1823962] Sat, 04 April 2020 18:22 Go to previous messageGo to next message
The process of deleting the index file and then doing a hard reset seemed to set it a good state, without the unexpected file in unstaged changes. When I first deleted the file from the shell, nothing happened until I tried doing a "fetch", and then it produced a surprising result, seeming to put every file in the repository in the unstaged changes list. That's when I did the hard reset, which cleaned everything up.
It's still curious that the changes in the nightly build fixed the problem immediately in one repository, but not the other.
So, I am now using the nightly build, which I did with "Install new software" and using the nightly update site. If I want to revert back to using the latest release for some reason, what do I have to do?
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1823964 is a reply to message #1823963] Sat, 04 April 2020 19:11 Go to previous messageGo to next message
Revert back to a previous entry in the installation history. If that doesn't work, uninstall EGit and re-install the version you want.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1827498 is a reply to message #1823964] Fri, 15 May 2020 21:46 Go to previous messageGo to next message
Coming back to this, I am still using the nightly build. I noticed a little while ago that one repo was displaying this symptom, thinking a file with no actual changes was modified. I ignored it at the time because I didn't have to do much with that repo recently. Now I have to do something with it, and it's displaying the same symptom. discarding, stashing, or hard reset didn't fix it. I will proceed to delete the index file and see if that fixes it.
Re: After upgrade to 2020-03, egit sees unstaged changes even after replace with HEAD [message #1827501 is a reply to message #1827498] Fri, 15 May 2020 22:49 Go to previous message
I managed to figure out a better workaround. If it's saying that the file has changes, it's easy enough to actually put real changes into it (dummy changes, like an empty comment) and push that. Once I did that, it no longer shows up in unstaged changes.
[Updated on: Fri, 15 May 2020 22:50]
Previous Topic:eGIT is throwing NullPointerException
Next Topic:Attempt to add cert file to staged changes is ignored
Current Time: Sat Jun 10 08:51:14 GMT 2023
Powered by FUDForum. Page generated in 0.03722 seconds
