| No viewpoint available? [message #1822801] |
Fri, 13 March 2020 11:47  |
Hello, I have completed the example of basicfamily. It was successful, but after I created the domain model myself, the created viewpoint specification project showed that there were no available viewpoints. During the creation of the viewpoint specification project, there was no prompt for Ctr + space in the Domian class. What could be going wrong there? Thanks.
I have solved the problem. Thank you!
[Updated on: Sun, 15 March 2020 22:48] by Moderator
| Re: No viewpoint available? [message #1822880 is a reply to message #1822801] |
Mon, 16 March 2020 06:13   |
In your Viewpoint Specification Project, when you select a Viewpoint, in the properties view, there is a field "Model File Extension". You should check that this field is set with the extension of the semantic model you created. Once this is properly set, when you create a Modeling project with the semantic model in it, the viewpoint will be available.
Furthermore, if it is not working for some reason (name conflict, metamodel not deployed...), in your Viewpoint Specification Project, when you select a Representation Description, in the properties view there is a "Metamodel" tab. This allows you to directly select the metamodel to use from the registry or workspace.
Once one of these solution is properly set, you will have the completion in the Viewpoint Specification Project, and the viewpoint will be available in your Modeling project.
Steve
| Re: No viewpoint available? [message #1823278 is a reply to message #1823175] |
Tue, 24 March 2020 06:14  |
Regarding the elements I listed in my previous answer, did you fill the "Model File Extension" and the "Metamodel" fields? Also, did you install the basicfamily plugins or do you have it in your workspace and have the Viewpoint Specification Project (the one with the .odesign file) in an Eclipse runtime?
Steve
FUDForum. Page generated in 0.03288 seconds
