Re: Is Eclipse 2019-06 meant to work with Java 9+? [message #1822491 is a reply to message #1822488] |
Sun, 08 March 2020 10:32 |
Ed Merks Messages: 33216 Registered: July 2009 |
The JDT developers will be more likely to see Java specific questions on the JDT forum:
https://www.eclipse.org/forums/index.php/f/13/
But they aren't likely to be able to help with Gradle. Also note that if you're using an older version of the Java IDE that version (which one are you using?) may well not contain the latest Java support and of course will not have the latest bug fixes.
When posting to the JDT forum, It would be good to share enough details that someone else could reproduce the problem that you're seeing even if it's just a screen capture showing the state of the project with the expanded tree of the project. The forum is not so helpful with making it easy to add attachments, but if you do a "Preview Quick Reply" can you see that you can attach files.
Ed Merks
FUDForum. Page generated in 0.04598 seconds
