Home » Newcomers » Newcomers » Installing one plugin gets certificate error
Installing one plugin gets certificate error [message #1821709] Tue, 18 February 2020 18:34 Go to next message
I'm running Eclipse Java 2019-12 with Java 13 on Windows 10.
I have many plugins installed, and I update them with new versions relatively often.
I am attempting to install the "Bash Editor" from the Marketplace client. Every time I attempt this, it fails with this error:
Unable to read repository at https://dl.bintray.com/de-jcup/basheditor/content.xml.
PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I've seen this error in other circumstances, and it's obviously related to the TLS certificate. I've posted an issue for that particular plugin, and the author says that many other people have successfully installed it recently.
Re: Installing one plugin gets certificate error [message #1821714 is a reply to message #1821709] Tue, 18 February 2020 23:37 Go to previous messageGo to next message
This stack trace generally is the result of the Java installation's certificate store not containing the root certificate of the site's certificate chain. You can try to add it. Google "java add certificate to cacerts" to find some ways to doing that. It's quite complex and painful. You might also avoid the problem by trying http: instead of https for the site's URL.
Re: Installing one plugin gets certificate error [message #1821760 is a reply to message #1821714] Wed, 19 February 2020 12:39 Go to previous messageGo to next message
Adding the update site as "http" instead of "https" worked.
So, examining the root cause, considering that the author said that many people have successfully installed the plugin lately, I'm going to guess they were using versions older than Java 13. Are there root certificates honored in versions older than 13 that are now revoked?
Re: Installing one plugin gets certificate error [message #1821771 is a reply to message #1821760] Wed, 19 February 2020 17:17 Go to previous messageGo to next message
I tried exporting the cert for bintray.com, importing that into the cacerts file in the JDK that Eclipse is running with, then restarting Eclipse and trying to install again, and it failed with the same error.
Re: Installing one plugin gets certificate error [message #1821776 is a reply to message #1821771] Thu, 20 February 2020 00:12 Go to previous message
At a customer site recently I had endless problems like this. We finally got the network settings to communicate through the proxy (using manual settings) to make update sites accessible, but then EGit/JGit failed with exactly these same low level stack traces until I switched back to native settings... Here too we had to manually add the certificates (for the Git repository's site, and for some reason there were 3 we had to add) to Java's certificate store (and did so correctly), but via manual network settings (to use the proxy server), these somehow didn't work for JGit. I've also had problems like this testing all the marketplace listings locally on my machine, but it worked better on the build server. And yes, I think it's possible for root certificates to be removed but of course it's just so much voodoo...
Previous Topic:IProgressMonitor accessible from more one module
Next Topic:Changes in source don't have any effect
Current Time: Wed Sep 24 14:58:57 EDT 2025
Powered by FUDForum. Page generated in 0.09094 seconds
