| Error fixing window takes a long time to open and other responsiveness problems [message #1821094] |
Wed, 05 February 2020 09:43 |
I have been suggested to post this here instead of the newcomers section
When there is an error in the code (unknown class, unhandled exception etc., for example typing "longt" instead of "long") on the left of the editor there is a light bulb with a red x. When I click it, it takes a few hundred milliseconds to open the window with suggestions to fix the problem (create class, create interface, change to another class etc) and I have to double click one of those suggestions in order for the action to be done.
Another thing is when I click on a variable name, that variable name will be highlighted in all of the code, however that too takes a few hundred ms to happen and it's extremely frustrating
Even right clicking in the editor has a noticeable delay, although it's shorter than the others
Is it normal for the window to open to take so much time? On netbeans it's near instant.
Is it also possible to fix the error using a single click instead of double click?
I am using the 2019-12 version, I tried changing to the classic theme but it had no effect.
FUDForum. Page generated in 0.09011 seconds
