Re: Eclipse modelling IDE and RAP [message #1817347 is a reply to message #1817345] |
Wed, 20 November 2019 18:08 |
Hi Antonio,
since you already have a Modeling IDE then you have EMF Parsley included.
So, even if you do not want to use EMF Parsley, you can anyway follow this tutorial
https://www.eclipse.org/emf-parsley/documentation.html#par23
at least for the steps:
* Installing the RAP Tools (btw, with 2019-09 you will find RAP Tools 3.10 as the last one compatible)
* Setup the EMF Parsley RAP Target Platform
the last step
* Running the Parsley RAP UI Example
can be executed just to prove that you can use latest RAP+EMF
HTH
Vincenzo
Re: Eclipse modelling IDE and RAP [message #1817379 is a reply to message #1817375] |
Thu, 21 November 2019 12:45 |
Hi Antonio,
I'm pretty sure the problem is that our Target Definition file emf-parsely-rap.target (the first step of the tutorial) does non include the RAP e4 plugins and/or features.
But I wouldn't know which should be added.
Re: Eclipse modelling IDE and RAP [message #1817464 is a reply to message #1817462] |
Fri, 22 November 2019 15:37 |
Hi Markus,
thank you for pointing out that the Parsley target platform Example is not up to date: we will fix it.
Anyway we just suggested Antonio to use this example from a Parsley tutorial as a starting point on how to use RAP (e3) and EMF together.
Vincenzo
Re: Eclipse modelling IDE and RAP [message #1817525 is a reply to message #1817524] |
Mon, 25 November 2019 11:39 |
Hi Antonio,
for what I know you cannot use org.eclipse.emf.edit.ui with a RAP platform.
The correspondent for RAP is org.eclipse.emf.rap.edit.ui.
Remember: with RAP all UI parts are not true SWT/JFace, but wrappers that renders on a web interface.
HTH
Vincenzo
FUDForum. Page generated in 0.03478 seconds
