Re: Builder won't build [message #1817227 is a reply to message #1817178] |
Mon, 18 November 2019 16:40 |
Reinhardt Christiansen Messages: 73 Registered: March 2010 |
Member |
Thank you, both!
It turns out that the "Build Automatically" option was NOT checked. (I'm not sure how that happened; I don't think I've touched that setting in *years*. I couldn't even FIND that setting first because it had been so long since I'd been there!)
Now that the option is checked, my builder translates .scss to .css every time I save an edit to the .scss file.
Thanks again!
By the way, is there any way to copy my SASS builder from one project to another? Several of my projects use scss/css files and there are enough settings and parameters to write that it's a bit tedious to hand-type them in each project so that they match the previous project (aside from minor changes in the path). If I could either share a SASS builder across all projects (with possible local overrides to paths) or easily clone a builder from one project to another, that would be quite convenient. (Otherwise, I suppose I'll just do some screen prints of the relevant panels, put them in a document somewhere, and then imitate them each time I add a SASS builder to the project.)
[Updated on: Mon, 18 November 2019 16:46] Report message to a moderator
Re: Builder won't build [message #1817957 is a reply to message #1817227] |
Tue, 03 December 2019 15:19 |
Mary Jones Messages: 1 Registered: December 2019 |
Reinhardt Christiansen wrote on Mon, 18 November 2019 16:40Thank you, both!
Thanks again!
By the way, is there any way to copy my SASS builder rapidessay from one project to another? Several of my projects use scss/css files and there are enough settings and parameters to write that it's a bit tedious to hand-type them in each project so that they match the previous project (aside from minor changes in the path). If I could either share a SASS builder across all projects (with possible local overrides to paths) or easily clone a builder from one project to another, that would be quite convenient. (Otherwise, I suppose I'll just do some screen prints of the relevant panels, put them in a document somewhere, and then imitate them each time I add a SASS builder to the project.)
Absolutelly agree, I just had the same issues and thanks to this thread I was able to fix it.
[Updated on: Tue, 03 December 2019 15:41] Report message to a moderator
FUDForum. Page generated in 0.11153 seconds
