Home » Eclipse Projects » Eclipse Platform » copy-paste now quotes the copied text . How to stop that?
copy-paste now quotes the copied text . How to stop that? [message #1816979] Wed, 13 November 2019 05:11 Go to next message
After switching to the new version, copy-past via clipboard now quotes the copied text. So, if I copy part of a String literal including a surrounding double quote (i.e., text") the entered value is different (text\"). How to disable that?
Version: 2019-09 R (4.13.0)
Build id: 20190917-1200
Re: copy-paste now quotes the copied text . How to stop that? [message #1817898 is a reply to message #1816979] Mon, 02 December 2019 09:20 Go to previous message
You can disable this escaping by:
1. In the preferences menu deselect: Java > Editor > Typing > Escape text when pasting into a string literal
2. Disable smart insert mode: Edit > Smart Insert Mode [Ctrl+Shift+Insert]
See also https://bugs.eclipse.org/bugs/show_bug.cgi?id=522218
Previous Topic:Replacement for Action Set Part Association ?
Next Topic:how to get an open file's project name inside Eclipse
Current Time: Fri Sep 12 01:52:18 EDT 2025
Powered by FUDForum. Page generated in 0.04289 seconds
