| Create Java Project programmatically [message #1816348] |
Mon, 28 October 2019 04:57  |
I´am working on a wizard for creating a Java Project where also Xtext Nature and libraries (xtend and an own library as well) should be added.
Now my Problem: After creating a few projects and restarting the runtime, the project I created at last is closed and I have to open it (right click on project > Open Project). For example I create three projects p1, p2, p3 first, close the runtime then, after a restart p3 would be close.
Here is the program sequence (I summarized it a little for a better overview and removed try catch statements as well):
NullProgressMonitor monitor = new NullProgressMonitor();
project = ResourcesPlugin.getWorkspace().getRoot().getProject(projectName);
projectLocation = project.getFullPath().toString();
if (!project.exists())
project.create(monitor);
project.open(monitor);
// add project natures
int numberOfNewNatures = 2;
final String XTEXT_NATURE = "org.eclipse.xtext.ui.shared.xtextNature";
IProjectDescription desc = project.getDescription();
String[] prevNatures = desc.getNatureIds();
String[] newNatures = new String[prevNatures.length + numberOfNewNatures];
System.arraycopy(prevNatures, 0, newNatures, 0, prevNatures.length);
newNatures[newNatures.length - 1] = XTEXT_NATURE;
newNatures[newNatures.length - numberOfNewNatures] = JavaCore.NATURE_ID;
desc.setNatureIds(newNatures);
project.setDescription(desc, new NullProgressMonitor());
//now create Java Project
javaProject = JavaCore.create(project);
//add bin folder (somehow somtimes it already exists and sometimes not...)
IFolder binFolder = javaProject.getProject().getFolder("bin");
if (!binFolder.exists())
binFolder.create(false, true, null);
javaProject.setOutputLocation(binFolder.getFullPath(), null);
// add JRE System Library to classpath
IClasspathEntry[] jcp = org.eclipse.jdt.ui.PreferenceConstants.getDefaultJRELibrary();
setClasspath(jcp);
//add Xtend Library to classpath
XtendLibClasspathAdder xLibAdder = new XtendLibClasspathAdder();
xLibAdder.addLibsToClasspath(javaProject, new NullProgressMonitor());
// add OWN Library
IClasspathEntry[] ownClasspathEntry = new IClasspathEntry[]{JavaCore.newContainerEntry(OWNClasspathContainerInitializer.OWN_LIBRARY_PATH)};
setClasspath(ownClasspathEntry);
//add src folder to class path (ugly workaround to prevent ArrayIndexOutOfBoundsException when src folder already exists)
IFolder sourceFolder = project.getFolder("src");
sourceFolder.create(false, true, null);
IPackageFragmentRoot root = javaProject.getPackageFragmentRoot(sourceFolder);
IClasspathEntry[] oldEntries = javaProject.getRawClasspath();
IClasspathEntry[] newEntries = null;
IClasspathEntry[] oldEntryWithoutSrc = new IClasspathEntry[oldEntries.length-1];
boolean srcRemoved = false;
for (int i = 0; i < oldEntries.length; i++)
if (oldEntries[i].getPath().equals(javaProject.getPath()))
List <IClasspathEntry> entryList = new ArrayList <IClasspathEntry> (Arrays.asList(oldEntries));
entryList.remove(i);
entryList.toArray(oldEntryWithoutSrc);
newEntries = new IClasspathEntry[oldEntries.length];
System.arraycopy(oldEntryWithoutSrc, 0, newEntries, 0, oldEntryWithoutSrc.length);
newEntries[oldEntryWithoutSrc.length] = JavaCore.newSourceEntry(root.getPath());
srcRemoved = true;
break;
if (!srcRemoved)
newEntries = new IClasspathEntry[oldEntries.length + 1];
System.arraycopy(oldEntries, 0, newEntries, 0, oldEntries.length);
newEntries[oldEntries.length + 1] = JavaCore.newSourceEntry(root.getPath());
javaProject.setRawClasspath(newEntries, null);
project.refreshLocal(IResource.DEPTH_INFINITE, monitor);
Maybe somone can has a clue what I did wrong? Any help would be appreciated.
Miriam
| Re: Create Java Project programmatically [message #1816478 is a reply to message #1816412] |
Tue, 29 October 2019 18:01  |
thank you both for you helpful suggestions!
I finally found a solution for my problem:
I had to put the code above as an IWorkspaceRunnable.run() implementation and now projects stay open. I followed the hint regarding to give eclipse more time as well and it seems that the strange behavior (concerning building) disappeared.
Thank you once again,
Miriam
FUDForum. Page generated in 0.04854 seconds
