Home » Eclipse Projects » Sirius » Can someone give proper structure of sirius to handle different packages in same ecore?(I am getting exception called class cast exception after creating two packages in ecore.)
Can someone give proper structure of sirius to handle different packages in same ecore? [message #1815804] Fri, 11 October 2019 03:28
I have one package A in which i have a pattern login and now it is not able to add any more elements,so i made one more package with name B and made one more pattern called login1 inside B package,After that i made the same element on UI giving the doman as B for the same element of B when i proceeded in coding it gave me class cast exception saying class not found for B.
Previous Topic:Error clicking on elements in my *.entityrelationshipmetamodel
Next Topic:Constant Pool Limit Reached
Current Time: Sat Nov 08 12:17:02 EST 2025
Powered by FUDForum. Page generated in 0.03061 seconds
