| Error clicking on elements in my *.entityrelationshipmetamodel [message #1815629] |
Mon, 07 October 2019 09:12  |
Hey,
So I've been implementing an editor for Entity-Relationship-Diagrams using Sirius. I started out with a metamodel (see entityrelationshipmetamodel.jpg), generated its code and ran the *.editor project as a Eclipse Application.
In the new runtime-Application I created a new Sirius Project and defined my *.odesign(following the tutorials).
When I now create a new Entity-Relationship Modeling Project using my specifications, I receive an error when opening up my *.entityrelationshipmetamodel and clicking on the root element (Schema) or any of its children(see error.png). I also can solely add elements to the diagram using the graphical editor.
I am using Eclipse-Java-2019-03 and according to the market place all my plugins are on the latest version.
Here's a list of the errors when launching the *.editor(I never had any problems so I ignored them):
Quote:SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://887.fwk1403704789:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://887.fwk1403704789:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [ch.qos.logback.classic.util.ContextSelectorStaticBinder]
!SESSION 2019-10-07 15:03:44.377 -----------------------------------------------
eclipse.buildId=4.11.0.I20190307-0500
java.version=11.0.3
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data C:\Users\timru\eclipse-workspace/../runtime-EclipseApplication -dev file:C:/Users/timru/eclipse-workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.egit.core 1 0 2019-10-07 15:03:51.986
!MESSAGE Using Apache MINA sshd as ssh client.
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2019-10-07 15:03:52.427
!MESSAGE
!STACK 0
java.net.MalformedURLException
at java.base/java.net.URL.<init>(URL.java:661)
at java.base/java.net.URL.<init>(URL.java:523)
at java.base/java.net.URL.<init>(URL.java:470)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.parseStyleSheet(AbstractCSSEngine.java:213)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.setTheme(ThemeEngine.java:463)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.setTheme(ThemeEngine.java:424)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.restore(ThemeEngine.java:585)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.setCSSTheme(PartRenderingEngine.java:1442)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.initializeStyling(PartRenderingEngine.java:1349)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1066)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:661)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1476)
at org.eclipse.equinox.launcher.Main.main(Main.java:1449)
Caused by: java.lang.NullPointerException
at java.base/java.net.URL.<init>(URL.java:567)
... 30 more
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2019-10-07 15:03:52.491
!MESSAGE
!STACK 0
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.resetCurrentTheme(ThemeEngine.java:628)
at com.genuitec.eclipse.core.theme.SplashScreenFix.apply(SplashScreenFix.java:49)
at com.genuitec.eclipse.core.theme.SplashScreenFix.handleEvent(SplashScreenFix.java:31)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:132)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.sendThemeChangeEvent(ThemeEngine.java:515)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.setTheme(ThemeEngine.java:494)
... 43 more
!ENTRY com.genuitec.eclipse.theming.ui 1 0 2019-10-07 15:03:52.687
!MESSAGE A DevStyle Theme is being activated on this workspace; preparing colors and configuration
!ENTRY com.genuitec.eclipse.theming.ui 1 0 2019-10-07 15:03:53.390
!MESSAGE DevStyle has archived current color configurations to alternate preferences - will be restored when switching out of the DevStyle Theme
!ENTRY com.genuitec.eclipse.theming.core 4 0 2019-10-07 15:03:53.442
!MESSAGE devstylePreferenceFilter
!STACK 0
java.lang.NoSuchFieldException: devstylePreferenceFilter
at java.base/java.lang.Class.getDeclaredField(Class.java:2412)
at com.genuitec.eclipse.theming.ui.internal.DevStyleThemeActivationTracker.prepareOomphExclusions(DevStyleThemeActivationTracker.java:882)
at com.genuitec.eclipse.theming.ui.internal.DevStyleThemeActivationTracker.applyCssForTargetTheme(DevStyleThemeActivationTracker.java:784)
at com.genuitec.eclipse.theming.ui.internal.DevStyleThemeActivationTracker.handleEvent(DevStyleThemeActivationTracker.java:520)
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2019-10-07 15:03:53.459
!MESSAGE
!STACK 0
at com.genuitec.eclipse.theming.ui.internal.DevStyleThemeActivationTracker.applyCssForTargetTheme(DevStyleThemeActivationTracker.java:795)
... 56 more
!ENTRY com.genuitec.eclipse.theming.ui 1 0 2019-10-07 15:03:53.656
!ENTRY com.genuitec.eclipse.theming.ui 1 0 2019-10-07 15:03:53.680
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2019-10-07 15:03:53.715
!MESSAGE
!STACK 0
... 43 more
!ENTRY org.eclipse.egit.ui 2 0 2019-10-07 15:04:01.682
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\timru'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY com.genuitec.eclipse.webclipse.evergreen 4 0 2019-10-07 15:04:01.943
!MESSAGE Cannot perform evergreen update as the installation profile cannot be found.
And here's the exception thrown when clicking on the element:
Quote:!ENTRY org.eclipse.jface 4 2 2019-10-07 15:06:08.202
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
at org.eclipse.emf.edit.ui.provider.ComposedImageDescriptor.getSize(ExtendedImageRegistry.java:407)
at org.eclipse.jface.resource.CompositeImageDescriptor.getImageData(CompositeImageDescriptor.java:369)
at org.eclipse.swt.internal.DPIUtil.validateAndGetImageDataAtZoom(DPIUtil.java:404)
at org.eclipse.swt.graphics.Image.<init>(Image.java:732)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:293)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:242)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:220)
at org.eclipse.emf.edit.ui.provider.ExtendedImageRegistry.getImage(ExtendedImageRegistry.java:185)
at org.eclipse.emf.edit.ui.provider.ExtendedImageRegistry.getImageDescriptor(ExtendedImageRegistry.java:205)
at org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction.objectToImageDescriptor(StaticSelectionCommandAction.java:245)
at org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction.configureAction(StaticSelectionCommandAction.java:173)
at org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:47)
at org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:57)
at entityrelationshipmetamodel.presentation.EntityrelationshipmetamodelActionBarContributor.generateCreateChildActions(EntityrelationshipmetamodelActionBarContributor.java)
at entityrelationshipmetamodel.presentation.EntityrelationshipmetamodelActionBarContributor.selectionChanged(EntityrelationshipmetamodelActionBarContributor.java)
at entityrelationshipmetamodel.presentation.EntityrelationshipmetamodelEditor.setSelection(EntityrelationshipmetamodelEditor.java)
at entityrelationshipmetamodel.presentation.EntityrelationshipmetamodelEditor$6.selectionChanged(EntityrelationshipmetamodelEditor.java)
at org.eclipse.jface.viewers.Viewer$1.run(Viewer.java:151)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.ui.internal.JFaceUtil.lambda$0(JFaceUtil.java:47)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:176)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:148)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2181)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1225)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1254)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:244)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:404)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4131)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3547)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
I haven't found any solutions for the problems online. I just saw a suggestion of running Eclipse with the '-clean' option but that didn't help.
Hopefully, You can help me figure out what I did wrong or which plug-in is acting up.
Tim
FUDForum. Page generated in 0.04747 seconds
