Home » Newcomers » Newcomers » Problems during coding
Problems during coding [message #1814919] Sun, 22 September 2019 20:57 Go to next message
So basically, I wanted to re-learn Java. I opened Eclipse and began to type the basic instruction: System.out.println(...);
But here's the problem. When you type, usually, you have a box that appears and proposes you different choices. This box appeared, and Eclipse crashed. And every time I try, it crashes. I even installed Eclipse IDE 2019-09, and it did the same thing.
What it does: This box appears when I type .println , and then Eclipse freezes. When I click on it, it turns white and it says that the program is no more responding. I have to close it.
By the way, if it can be helpful in any way, I'm on Windows 7 64 bits, Java 8 (I think). I didn't install anything related to Java since a while.
I really don't know what could make that, since it worked fine months ago.
Re: Problems during coding [message #1814926 is a reply to message #1814919] Mon, 23 September 2019 02:01 Go to previous message
If it's a deadlock, it would be good to have more details as produced by these instructions:
https://wiki.eclipse.org/How_to_report_a_deadlock#Using_jvisualvm
Also it would be good to see what's in the error log. Logged details are recorded in the <workspace>/.metadata/.log and you could attach that file.
Does this same thing happen if you open 2019-09 with a fresh new workspace (as opposed to with a workspace that you've already been using for a while)?
Previous Topic:Requesting Help With CNC Project
Next Topic:Fresh install of 2018-19 for C++ Arduino
Current Time: Thu Nov 06 07:04:48 EST 2025
Powered by FUDForum. Page generated in 0.11548 seconds
