Re: Need help in MARTE [message #1815053 is a reply to message #1814647] |
Tue, 24 September 2019 20:40 |
the link that you mention is part of a generated page that had the same structure for all papyrus components. As far as I know the user guide does not exist.
Did you check-out the MARTE tutorial here?
Re: Need help in MARTE [message #1815214 is a reply to message #1815174] |
Fri, 27 September 2019 09:53 |
Very basic instructions: apply the MARTE (sub-) profiles that you need via apply registered profile.
Working in all papyrus versions: use the property view / profile tab to apply the MARTE stereotypes that you need. Stereotype attribute values can be modified via the property tab as well. Use MARTE VSL syntax depending on the attribute type, e.g. "{value = 10, unit = ms}" for 10ms.
You can control the visibility of stereotypes/stereotype attributes on diagram elements via the appearance tab in the property view.
Please note that the palette that allowed you to directly add stereotyped elements is working until Eclipse oxygen, since the Papyrus Palette customization changed since.
Please also note that we will probably release a new version with better usability for current Papyrus release in the future (can't give a date).
FUDForum. Page generated in 0.04421 seconds
