| Breakpoints stop working with JUnits/Mockito mid-development [message #1810896] |
Wed, 21 August 2019 08:49  |
I've been using Eclipse for decades, and sure, after using an install for a while stuff eventually stops working correctly. But this install is less than 4 months old.
I'm running JUnit tests (and sometimes Cucumber tests hooked in) with the debug icon in the toolbar. They've worked until yesterday.
I started using Mockito spy(..) because one class is too complex and started getting the "Unable to install breakpoint in...$MockitoMock$.. due to missing line number attributes. Modify compiler options.."
But then it continued running, showed the message a couple more times, and finally went to the debugger.
Well, all those pop-ups are annoying, but after clicking "Don't show this message again" on the dialog, the Debugger perspective never comes up again. Even in a new workspace.
Let me say that again: now the debugger never appears and execution never stops. "Debug" is working exactly like "Run".
I've:
A) gone into the debugger Perspective and tried deleting all breakpoints and creating new ones.
B) gone to the breakpoint pane, right-clicked, and tried removing all triggers - there are none
C) after running the project as a JUnit stopped debugging, I tried debugging the file itself - same failure.
D) restarted the Eclipse
E) restarted the laptop
F) created a new workspace for the git project - both created/downloaded in new disk locations.
G) Preferences > Java > Compiler, "Add line number attributes..." is still checked.
No change in getting the debugger to appear during execution.
Oddly, after creating the new workspace that pop-up error only appears once when debugging the tests, but it should hit that breakpoint twice from different tests methods, like it did before it stopped working...
This is STS4/Eclipse Platform 4.11.0.v20190307-0500 running on Windows 10.
So who can tell me: what is the secret setting which got corrupted?
Or is a re-install/nuke the HD from orbit the only possible solution?
Thanks!
FUDForum. Page generated in 0.03901 seconds
