Re: TCP ASPs over TLS [message #1810214 is a reply to message #1810178] |
Mon, 05 August 2019 07:13 |
Hi Olaf,
you should have no problem compiling a project with several TCP ports; that only adds the possibility, and not the obligation, to use SSL/TLS.
Each port instance can be separately parameterized for a specific behaviour; say you have two ports TCP_port1 and TCP_port2:
*.TCP_port1.socket_debugging := "Yes"
*.TCP_port1.server_mode := "No"
*.TCP_port1.use_connection_ASPs := "Yes"
*.TCP_port1.ssl_use_ssl := "Yes"
*.TCP_port2.socket_debugging := "Yes"
*.TCP_port2.server_mode := "Yes"
*.TCP_port2.use_connection_ASPs := "No"
*.TCP_port2.ssl_use_ssl := "No"
port1 will be used in client mode with SSL/TLS, while port2 will be used in server mode , w/o SSL/TLS.
The whole range of parameters is documented in
titan.TestPorts.TCPasp/doc/UG/TCP Socket Test Port for TTCN-3 Toolset with TITAN, Users Guide.adoc
I hope this clarifies it
Best regards
Elemer
FUDForum. Page generated in 0.03689 seconds
