Home » Modeling » TMF (Xtext) » XtextSerializationException for cross references to existing objects
XtextSerializationException for cross references to existing objects [message #1810056] Tue, 30 July 2019 03:35 Go to next message
Hi, a customer has designed an Xtext based DSL for a system I now have to maintain. A colleague wrote some code which generates data in that DSL, but also reads in existing files and amends them.
The problem I'm now facing is that when I try to save an object which contains a cross reference to an already existing object from a different resource, I get
org.eclipse.xtext.parsetree.reconstr.XtextSerializationException:
Could not serialize cross reference from
newObject.reference to existingObject
at
o.e.x.parsetree.reconstr.impl.AbstractParseTreeConstructor$AssignmentToken.serializeInternal(AbstractParseTreeConstructor.java:255)
I already checked that the referenced object is loaded successfully and also that it is known by the same ResourceProvider I use to save the new object.
What causes the Exception to be thrown is that the Node of the Token that is about to be written is null, so the Node can not be serialized.
Unfortunately I barely know anything about Xtext, so I don't really know if what I wrote even makes much sense. I also don't know how to find out where the Node for the Token should be set, or if the Node being null is a consequential error of something else I'm not aware of.
I'd be really grateful for any pointers on how to find the cause of that Exception.
The application uses Xtext 2.8.0.v201503090534, if that is important. I know it's old, but so is the whole application and we don't get the budget to update all the dependencies.
Re: XtextSerializationException for cross references to existing objects [message #1810486 is a reply to message #1810056] Mon, 12 August 2019 11:45 Go to previous message
hi, you should debug
String ref = crossRefSerializer.serializeCrossRef(eObjectConsumer.getEObject(),
(CrossReference) element, (EObject) value, node);
and see why the cross reference serializer does not provide a string for your refs. this should work if there is no node too.
Previous Topic:working example connecting monaco editor with a Xtext LSP server
Next Topic:Writing java-style If statements in XText results in an error
Current Time: Mon May 12 05:56:37 EDT 2025
Powered by FUDForum. Page generated in 0.17268 seconds
