Home » Eclipse Projects » Trace Compass » Multiple instances of trace compas
Multiple instances of trace compas [message #1809382] Mon, 15 July 2019 05:46 Go to next message
I often have two lttng traces which I want to compare. Thus it would be great to run Trace Compas twice, to be able to navigate and compare simultaneously.
However the workspace is locked to ~/.tracecompas and can only be used by one instance.
Anybody have a way to do this.
Re: Multiple instances of trace compas [message #1809467 is a reply to message #1809382] Tue, 16 July 2019 10:00 Go to previous messageGo to next message
You can change the workspace of Trace Compass by setting the environment variable TRACING_RCP_ROOT to another root. That will be 2 completely different workspaces (different projects, different traces, etc)
Also, to navigate and compare traces simultaneously, have you tried the Pin & Clone feature? See the documentation here: https://archive.eclipse.org/tracecompass/doc/stable/org.eclipse.tracecompass.doc.user/Trace-Compass-Main-Features.html#Pin_and_Clone
Geneviève
Re: Multiple instances of trace compas [message #1809502 is a reply to message #1809467] Wed, 17 July 2019 01:19 Go to previous message
Thanks, these are useful hints for my next debugging.
Previous Topic:Trace compass with GDB trace format.
Next Topic:Runnables are not visible in BTF view
Current Time: Sat Jul 19 11:54:58 EDT 2025
Powered by FUDForum. Page generated in 0.08283 seconds
