Re: Papyrus SysML Tutorial (version 0.1.3) [message #1826988 is a reply to message #1821831] |
Tue, 05 May 2020 18:50 |
Gerhard Jensen Messages: 7 Registered: January 2020 |
Ben,
Awesome work. Could you add some material on ports and data flows?
I'm trying to learn SysML using Papyrus and am having difficulty with ports and flows. I've used FlowPorts with connectors previously without issue. I noticed in your tutorial you didn't use ports at all but stuck with ItemFlows. Could you add some coverage of ports? Specifically FlowPorts, Ports, FullPorts, and ProxyPorts. I have an older SysML book that covers FlowPorts and (UML) Ports only. If I had some examples then I could tell if what I'm doing is incorrect or if I'm hitting a bug. What few examples exist in the wild pertain to commercial tools.
Thank you!
G. J.
[Updated on: Tue, 05 May 2020 19:35] Report message to a moderator
FUDForum. Page generated in 0.03273 seconds
