Issues with Eclipse Modeling [Mars] - regarding marketplace and installation details [message #1807605] |
Tue, 04 June 2019 14:15 |
gilbert groten Messages: 3 Registered: June 2019 |
Hello everyone!
I'm having an issue regarding Eclipse Modeling Tools in Mars release
(I'm working with some legacy tools that have already proven to have issues with alter eclipse editions, so using the latest version is not an easy option)
I can neither open the Marketplace, nor can I open the Installation Details (Help -> About Eclipse -> Installation Details).
This is obviously inconvenient when try to install software the recommended way (or - at all) and checking for already installed software.
An often cited fix is to try other network settings (Window -> Preferences -> General -> Network Connections), but that didn't help.
Neither did i manage to fix it by re-installing the marketplace client through "Help -> Install new Software" or manually downloading it.
Thanks in advance for any Help!
_____________________________________________________________________________________
Further Details:
This is the Error log when trying to open the Marketplace
Message:
Unhandled event loop exception
Exception Stack Trace:
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1327)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
at org.eclipse.swt.widgets.TabFolder.gtk_switch_page(TabFolder.java:490)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1994)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4723)
at org.eclipse.swt.internal.gtk.OS._gtk_widget_show(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_widget_show(OS.java:14720)
at org.eclipse.swt.widgets.TabFolder.createItem(TabFolder.java:274)
at org.eclipse.swt.widgets.TabItem.createWidget(TabItem.java:123)
at org.eclipse.swt.widgets.TabItem.<init>(TabItem.java:75)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage.createTab(MarketplacePage.java:334)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage.createCatalogTab(MarketplacePage.java:328)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage.createControl(MarketplacePage.java:156)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:175)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:705)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:597)
at org.eclipse.jface.window.Window.create(Window.java:430)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at org.eclipse.jface.window.Window.open(Window.java:792)
at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCommand.execute(MarketplaceWizardCommand.java:191)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 38 more
Session Data:
eclipse.buildId=4.5.0.I20150603-2000
java.version=1.7.0_80
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.modeling.product
And this the log when I try to open Installation Details
Message:
ExceptionStackTrace:
at org.eclipse.ui.internal.about.InstallationDialog.createFolderItems(InstallationDialog.java:221)
at org.eclipse.ui.internal.about.InstallationDialog.createDialogArea(InstallationDialog.java:200)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:768)
at org.eclipse.ui.internal.about.InstallationDialog.createContents(InstallationDialog.java:236)
at org.eclipse.ui.internal.dialogs.AboutDialog$1.run(AboutDialog.java:126)
at org.eclipse.ui.internal.dialogs.AboutDialog.buttonPressed(AboutDialog.java:120)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:619)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at org.eclipse.ui.internal.about.AboutHandler.execute(AboutHandler.java:33)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:343)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:160)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
Session Data:
What i actually want to do is to use ATL reactive https://github.com/atlanmod/org.eclipse.atl.reactive to convert a Palladio https://marketplace.eclipse.org/content/palladio-40-eclipse-mars component model into a UML model an Java Code.
I am using Eclipse Mars because Eclipse 2019-03 had even more issues and Eclipse Mars was the latest Edition at the time of ATL reactives last update , and java 7 because Eclipse Mars refused to launch using any other Version.
Also, "The import org.antlr cannot be resolved", and i can't seem to find any other way to install it than the Marketplace, and i'd like to check if it isn't allready preinstalled in Eclipse Mars Modeling Tools and if so, in which version, which i cannot check because of the "Installation Details" issue.
My OS is Linux Mint 19.1
FUDForum. Page generated in 0.03542 seconds
