Home » Archived » Jubula » importing (xml) project in Jubula 8.7.1
importing (xml) project in Jubula 8.7.1 [message #1807427] Wed, 29 May 2019 13:42 Go to next message
Hello
I exported my project to an xml file from 8.1.0 Jubula and now I am trying to import back onto a brand new installed (in a brand new machine) 8.7.1 version.
Unfortunatelly I can't find a way to do that as the only file type import option is for .jub files.
Any workaround ?
thank you
Re: importing (xml) project in Jubula 8.7.1 [message #1807878 is a reply to message #1807427] Tue, 11 June 2019 08:46 Go to previous message
You can use eclipse neon[1] to import it and export it as jub file. Keep in mind even this might work, it is the possibility that you must fix some tests.
best regards
Marvin Mueller
[1]https://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/neon/3/eclipse-testing-neon-3-win32.zip
Previous Topic:how to download older version
Next Topic:Error Replace_Test
Current Time: Mon Oct 27 12:06:02 EDT 2025
Powered by FUDForum. Page generated in 0.04503 seconds
