How to open model file in text editor programmatically [message #1807259] |
Mon, 27 May 2019 02:19  |
I want to open a xtext model file in text editor in some conditions.
File ->OpenWith works fine, but I want to achieve this programmatically.
When user double clicks on the file. I want to check some condition and if true, I want to open that file in text editor.
How can I achieve this ?
Thanks and regards,
Virag Purnam
Re: How to open model file in text editor programmatically [message #1807314 is a reply to message #1807283] |
Tue, 28 May 2019 00:25   |
Hi Mr. Christian Dietrich,
I have created a sample Xtext project for the same.
Grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals hidden(WS, ML_COMMENT, SL_COMMENT, TEST_STMT)
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
conts+=Cont* procs+=Proc*;
Cont:
'Cont' name=ID '{' items+=Item* '}' ;
Item: 'Item' name=ID;
Proc:
'Link' item1=[Item|ID] 'OF' con1=[Cont|ID] 'TO' item2=[Item|ID] 'OF' con2=[Cont|ID]
//Test statement
terminal TEST_STMT : 'FreeText: ' -> '.';
Plugin.xml :
<?xml version="1.0" encoding="windows-1252"?>
<?eclipse version="3.0"?>
<plugin>
<extension
point="org.eclipse.ui.editors">
<editor
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.XtextEditor"
contributorClass="org.eclipse.ui.editors.text.TextEditorActionContributor"
default="true"
extensions="mydsl"
id="org.xtext.example.mydsl.MyDsl"
name="MyDsl Editor">
</editor>
</extension>
<extension
point="org.eclipse.ui.handlers">
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.hyperlinking.OpenDeclarationHandler"
commandId="org.eclipse.xtext.ui.editor.hyperlinking.OpenDeclaration">
<activeWhen>
<reference
definitionId="org.xtext.example.mydsl.MyDsl.Editor.opened">
</reference>
</activeWhen>
</handler>
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.handler.ValidateActionHandler"
commandId="org.xtext.example.mydsl.MyDsl.validate">
<activeWhen>
<reference
</reference>
</activeWhen>
</handler>
<!-- copy qualified name -->
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedNameHandler"
commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedName">
<activeWhen>
<reference definitionId="org.xtext.example.mydsl.MyDsl.Editor.opened" />
</activeWhen>
</handler>
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedNameHandler"
commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedName">
<activeWhen>
<and>
<reference definitionId="org.xtext.example.mydsl.MyDsl.XtextEditor.opened" />
<iterate>
<adapt type="org.eclipse.xtext.ui.editor.outline.IOutlineNode" />
</iterate>
</and>
</activeWhen>
</handler>
</extension>
<extension point="org.eclipse.core.expressions.definitions">
<definition id="org.xtext.example.mydsl.MyDsl.Editor.opened">
<and>
<reference definitionId="isActiveEditorAnInstanceOfXtextEditor"/>
<with variable="activeEditor">
<test property="org.eclipse.xtext.ui.editor.XtextEditor.languageName"
value="org.xtext.example.mydsl.MyDsl"
forcePluginActivation="true"/>
</with>
</and>
</definition>
<definition id="org.xtext.example.mydsl.MyDsl.XtextEditor.opened">
<and>
<reference definitionId="isXtextEditorActive"/>
</with>
</and>
</definition>
</extension>
<extension
point="org.eclipse.ui.preferencePages">
<page
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.preferences.LanguageRootPreferencePage"
name="MyDsl">
<keywordReference id="org.xtext.example.mydsl.ui.keyword_MyDsl"/>
</page>
<page
category="org.xtext.example.mydsl.MyDsl"
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.syntaxcoloring.SyntaxColoringPreferencePage"
id="org.xtext.example.mydsl.MyDsl.coloring"
name="Syntax Coloring">
</page>
<page
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.templates.XtextTemplatePreferencePage"
id="org.xtext.example.mydsl.MyDsl.templates"
name="Templates">
</page>
</extension>
<extension
point="org.eclipse.ui.propertyPages">
<page
name="MyDsl">
<enabledWhen>
<adapt type="org.eclipse.core.resources.IProject"/>
</enabledWhen>
<filter name="projectNature" value="org.eclipse.xtext.ui.shared.xtextNature"/>
</page>
</extension>
<extension
point="org.eclipse.ui.keywords">
<keyword
label="MyDsl"/>
</extension>
<extension
point="org.eclipse.ui.commands">
<command
description="Trigger expensive validation"
id="org.xtext.example.mydsl.MyDsl.validate"
name="Validate">
</command>
<command
id="org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedName"
categoryId="org.eclipse.ui.category.edit"
description="Copy the qualified name for the selected element"
name="Copy Qualified Name">
</command>
<command
id="org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedName"
</command>
</extension>
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:#TextEditorContext?after=group.edit">
<command
style="push"
tooltip="Trigger expensive validation">
<visibleWhen checkEnabled="false">
<reference
</reference>
</visibleWhen>
</command>
</menuContribution>
<menuContribution locationURI="popup:#TextEditorContext?after=copy">
<command commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.EditorCopyQualifiedName"
style="push" tooltip="Copy Qualified Name">
</visibleWhen>
</command>
</menuContribution>
<menuContribution locationURI="menu:edit?after=copy">
</visibleWhen>
</command>
</menuContribution>
<menuContribution locationURI="popup:org.eclipse.xtext.ui.outline?after=additions">
<command commandId="org.eclipse.xtext.ui.editor.copyqualifiedname.OutlineCopyQualifiedName"
<and>
<iterate>
</iterate>
</and>
</visibleWhen>
</command>
</menuContribution>
</extension>
<menuContribution locationURI="popup:#TextEditorContext?endof=group.find">
<command commandId="org.eclipse.xtext.ui.editor.FindReferences">
<reference definitionId="org.xtext.example.mydsl.MyDsl.Editor.opened">
</reference>
</visibleWhen>
</command>
</menuContribution>
</extension>
<extension point="org.eclipse.ui.handlers">
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.findrefs.FindReferencesHandler"
<activeWhen>
<reference
</reference>
</activeWhen>
</handler>
</extension>
<extension point="org.eclipse.core.contenttype.contentTypes">
<content-type
base-type="org.eclipse.core.runtime.text"
file-extensions="mydsl"
id="org.xtext.example.mydsl.MyDsl.contenttype"
name="MyDsl File"
priority="normal">
</content-type>
</extension>
<!-- adding resource factories -->
<extension
point="org.eclipse.emf.ecore.extension_parser">
<parser
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.resource.IResourceFactory"
type="mydsl">
</parser>
</extension>
<extension point="org.eclipse.xtext.extension_resourceServiceProvider">
<resourceServiceProvider
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.resource.IResourceUIServiceProvider"
uriExtension="mydsl">
</resourceServiceProvider>
</extension>
<!-- marker definitions for org.xtext.example.mydsl.MyDsl -->
<extension
id="mydsl.check.fast"
name="MyDsl Problem"
point="org.eclipse.core.resources.markers">
<super type="org.eclipse.xtext.ui.check.fast"/>
<persistent value="true"/>
</extension>
<extension
id="mydsl.check.normal"
<super type="org.eclipse.xtext.ui.check.normal"/>
</extension>
<extension
id="mydsl.check.expensive"
<super type="org.eclipse.xtext.ui.check.expensive"/>
</extension>
<extension point="org.eclipse.ui.preferencePages">
<page
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.validation.ValidatorPreferencePage"
id="org.xtext.example.mydsl.MyDsl.validator.preferencePage"
name="Errors/Warnings">
</page>
</extension>
<extension point="org.eclipse.xtext.builder.participant">
<participant
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.builder.IXtextBuilderParticipant"
fileExtensions="mydsl"/>
</extension>
<page
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.builder.preferences.BuilderPreferencePage"
id="org.xtext.example.mydsl.MyDsl.compiler.preferencePage"
name="Compiler">
</page>
</extension>
<extension point="org.eclipse.ui.propertyPages">
<page
id="org.xtext.example.mydsl.MyDsl.compiler.propertyPage"
name="Compiler">
<enabledWhen>
</enabledWhen>
</page>
</extension>
<menuContribution locationURI="popup:#TextEditorContext?after=xtext.ui.openDeclaration">
<command
commandId="org.eclipse.xtext.ui.OpenGeneratedFileCommand"
id="org.xtext.example.mydsl.MyDsl.OpenGeneratedCode"
style="push">
</visibleWhen>
</command>
</menuContribution>
</extension>
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.generator.trace.OpenGeneratedFileHandler"
commandId="org.eclipse.xtext.ui.OpenGeneratedFileCommand">
<activeWhen>
</activeWhen>
</handler>
</extension>
<!-- Quick Outline -->
<extension
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.outline.quickoutline.ShowQuickOutlineActionHandler"
commandId="org.eclipse.xtext.ui.editor.outline.QuickOutline">
<activeWhen>
<reference
</reference>
</activeWhen>
</handler>
</extension>
<extension
<command
description="Open the quick outline."
id="org.eclipse.xtext.ui.editor.outline.QuickOutline"
name="Quick Outline">
</command>
</extension>
<menuContribution
locationURI="popup:#TextEditorContext?after=group.open">
<command commandId="org.eclipse.xtext.ui.editor.outline.QuickOutline"
style="push"
tooltip="Open Quick Outline">
<reference definitionId="org.xtext.example.mydsl.MyDsl.Editor.opened"/>
</visibleWhen>
</command>
</menuContribution>
</extension>
<!-- quickfix marker resolution generator for org.xtext.example.mydsl.MyDsl -->
<extension
point="org.eclipse.ui.ide.markerResolution">
<markerResolutionGenerator
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.quickfix.MarkerResolutionGenerator"
markerType="org.xtext.example.mydsl.ui.mydsl.check.fast">
<attribute
name="FIXABLE_KEY"
value="true">
</attribute>
</markerResolutionGenerator>
markerType="org.xtext.example.mydsl.ui.mydsl.check.normal">
<attribute
name="FIXABLE_KEY"
value="true">
</attribute>
markerType="org.xtext.example.mydsl.ui.mydsl.check.expensive">
<attribute
name="FIXABLE_KEY"
value="true">
</attribute>
</extension>
<!-- Rename Refactoring -->
<handler
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.refactoring.ui.DefaultRenameElementHandler"
commandId="org.eclipse.xtext.ui.refactoring.RenameElement">
<activeWhen>
<reference
</reference>
</activeWhen>
</handler>
</extension>
<menuContribution
<command commandId="org.eclipse.xtext.ui.refactoring.RenameElement"
style="push">
<reference
</reference>
</visibleWhen>
</command>
</menuContribution>
</extension>
<page
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.refactoring.ui.RefactoringPreferencePage"
id="org.xtext.example.mydsl.MyDsl.refactoring"
name="Refactoring">
</page>
</extension>
<extension point="org.eclipse.compare.contentViewers">
<viewer id="org.xtext.example.mydsl.MyDsl.compare.contentViewers"
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.compare.InjectableViewerCreator"
extensions="mydsl">
</viewer>
<contentTypeBinding
contentTypeId="org.xtext.example.mydsl.MyDsl.contenttype"
contentViewerId="org.xtext.example.mydsl.MyDsl.compare.contentViewers" />
</extension>
<extension point="org.eclipse.compare.contentMergeViewers">
<viewer id="org.xtext.example.mydsl.MyDsl.compare.contentMergeViewers"
extensions="mydsl" label="MyDsl Compare">
</viewer>
<contentTypeBinding
contentMergeViewerId="org.xtext.example.mydsl.MyDsl.compare.contentMergeViewers" />
</extension>
<extension point="org.eclipse.ui.editors.documentProviders">
<provider id="org.xtext.example.mydsl.MyDsl.editors.documentProviders"
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.ui.editor.model.XtextDocumentProvider"
extensions="mydsl">
</provider>
</extension>
<extension point="org.eclipse.team.core.fileTypes">
<fileTypes
extension="mydsl"
type="text">
</fileTypes>
</extension>
<extension
point="org.eclipse.ui.ide.editorAssociationOverride">
<editorAssociationOverride
class="org.xtext.example.mydsl.ui.CustomEditorAssociationOverride"
id="org.xtext.example.mydsl.ui.customEditorAssociationOverride">
</editorAssociationOverride>
</extension>
</plugin>
CustomEditorAssociationOverride.java
package org.xtext.example.mydsl.ui;
import org.eclipse.core.runtime.content.IContentType;
import org.eclipse.ui.IEditorDescriptor;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.ide.IEditorAssociationOverride;
public class CustomEditorAssociationOverride implements IEditorAssociationOverride {
public CustomEditorAssociationOverride() {
// TODO Auto-generated constructor stub
public IEditorDescriptor[] overrideEditors(IEditorInput editorInput, IContentType contentType,
IEditorDescriptor[] editorDescriptors) {
// TODO Auto-generated method stub
return editorDescriptors;
public IEditorDescriptor[] overrideEditors(String fileName, IContentType contentType,
public IEditorDescriptor overrideDefaultEditor(IEditorInput editorInput, IContentType contentType,
IEditorDescriptor editorDescriptor) {
return editorDescriptor;
public IEditorDescriptor overrideDefaultEditor(String fileName, IContentType contentType,
Model file:
Cont container1 {
Item item1
Cont container2 {
Item item2
Link item1 OF container1 TO item2 OF container2
Thanks for your continuous help.
Thanks and regards,
Virag Purnam
FUDForum. Page generated in 0.07722 seconds
