Home » Newcomers » Newcomers » falling at the first hurdle
falling at the first hurdle [message #1806334] Tue, 07 May 2019 16:17 Go to next message
I am trying to do the helloworld tutorial, and there is an error as soon as I create a java project:
Errors occurred during the build.
Errors running builder 'Java Builder' on project 'HelloWorld'.
According to similar posts, I should also paste the error log:
at org.eclipse.jdt.internal.core.builder.ClasspathJrt.addRequired(ClasspathJrt.java:326)
at org.eclipse.jdt.internal.core.builder.ClasspathJrt.selectModules(ClasspathJrt.java:320)
at org.eclipse.jdt.internal.core.builder.ClasspathJrtWithReleaseOption.getModuleNames(ClasspathJrtWithReleaseOption.java:347)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.collectModuleEntries(NameEnvironment.java:397)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.computeClasspathLocations(NameEnvironment.java:319)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.<init>(NameEnvironment.java:62)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.initializeBuilder(JavaBuilder.java:629)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(JavaBuilder.java:174)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:833)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:220)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:263)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:316)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:319)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:371)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:392)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:154)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:244)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Re: falling at the first hurdle [message #1806348 is a reply to message #1806334] Wed, 08 May 2019 00:02 Go to previous messageGo to next message
Which version of Eclipse did you install? Which version of Java is being used in Window -> Preferences... -> Java -> Installed JREs?
I ask because these bugs sound related:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=546338
https://bugs.eclipse.org/bugs/show_bug.cgi?id=545558
You'll see in the first bug that the developers are having trouble reproducing the problem, but that they've attempted to fix it in the current development stream of JDT (aimed for the upcoming 2019-06 release)...
Re: falling at the first hurdle [message #1806751 is a reply to message #1806348] Tue, 14 May 2019 12:24 Go to previous messageGo to next message
I am having the same issue. I have installed JAVA JDK 12 and am running Eclipse 2019-03. Is there a way I can fix this?
Re: falling at the first hurdle [message #1806786 is a reply to message #1806751] Wed, 15 May 2019 03:23 Go to previous messageGo to next message
At this point, I think the only fix is to update to the unreleased 2019-06 version using this update site: http://download.eclipse.org/releases/2019-06
Re: falling at the first hurdle [message #1858074 is a reply to message #1806334] Tue, 14 March 2023 15:06 Go to previous messageGo to next message
I am using Eclipse Version: 2022-12 (4.26.0) Build id: 20221201-1913.
All of a sudden, Eclipse started showing this error message:
'Building has encountered a problem.
'proj'
Index 1 out of bounds for length 1
Is there any hope to fix this problem? Is there any way I can locate its source?
It is incredibly annoying, it pops up every time I build the project.
Re: falling at the first hurdle [message #1858081 is a reply to message #1858074] Wed, 15 March 2023 02:30 Go to previous messageGo to next message
If you shared a stack trace, we'd have more of a clue of where this is happening. The 2022-03 release is later today, so you could try updating in about 8 hours.
Re: falling at the first hurdle [message #1858090 is a reply to message #1858081] Wed, 15 March 2023 10:42 Go to previous messageGo to next message
There is no stack trace. I looked for one, but the only thing I can add is a line in the "Problems" section:
Internal compiler error: java.lang.ArrayIndexOutOfBoundsException: Index 1 out of bounds for length 1 at org.eclipse.jdt.internal.compiler.ast.ReferenceExpression.sIsMoreSpecific(ReferenceExpression.java:1290) Reader.java /NewApp/src/project/Reader line 0 Java Problem
Re: falling at the first hurdle [message #1858092 is a reply to message #1858090] Wed, 15 March 2023 11:00 Go to previous message
Sorry, I should have suggested to use the Error Log view; click search/magnifying glass is upper right and type Error to open it. These types of failure will generally log a stack trace here. If you double click and item in that view, you can copy it and paste it.
Previous Topic:Transactions not working in eclipselink
Next Topic:Linux Default Plugins?
Current Time: Mon Nov 10 06:52:34 EST 2025
Powered by FUDForum. Page generated in 0.09647 seconds
