Home » Eclipse Projects » Eclipse Platform » dynamic ruler column
dynamic ruler column [message #335698] Wed, 22 April 2009 11:45 Go to next message
Hi, I defines a number of Ruler Columns in my application via plugin.xml.
Generally they are all work exactly the same. The difference is only in
dynamic String parameter, that determines where to take a number, shown in
the ruler. Is there a way to define the parameter via plugin.xml and use
the same class for all the rulers? If no, is there any other way to pass
parameter to ruler column? Thanks
Re: dynamic ruler column [message #335712 is a reply to message #335698] Thu, 23 April 2009 02:45 Go to previous messageGo to next message
> plugin.xml. Generally they are all work exactly the same. The
> difference is only in dynamic String parameter, that determines where
> to take a number, shown in the ruler. Is there a way to define the
> parameter via plugin.xml and use the same class for all the rulers? If
> no, is there any other way to pass parameter to ruler column? Thanks
The easiest is to put all logic into an abstract ruler class and then
use concrete rulers that set the parameter(s). Then use the concrete
classes in the plugin.xml.
Dani
Re: dynamic ruler column [message #335713 is a reply to message #335712] Thu, 23 April 2009 03:04 Go to previous message
Thanks for quick reply. I search a way to give to users to configure
dynamically kind of rulers that are displayed. They may edit xml file, but
they will not write java code, compile and release. All the rulers work
the same, there is only one String parameter defining the difference. Also
list of possible parameters is defined dynamically. Any trick to make such
a configuration working? Thanks, Stella
Previous Topic:Editor in background
Next Topic:Best practice: Working on Eclipse CVS stuff
Current Time: Sun Sep 21 17:44:26 EDT 2025
Powered by FUDForum. Page generated in 0.02999 seconds
