Re: [Validation] ignore non containment References [message #1806034 is a reply to message #1806010] |
Wed, 01 May 2019 07:15 |
Ed Merks Messages: 33216 Registered: July 2009 |
No there is no such option. Even containment references can involve proxy resolution if the model has proxy resolving containment references. And of course most of the constraints being checked, i.e., EOBJECT__EVERY_REFERENCE_IS_CONTAINED, EOBJECT__EVERY_PROXY_RESOLVES, potentially EOBJECT__EVERY_KEY_UNIQUE (if the references is proxy resolving), EOBJECT__EVERY_MAP_ENTRY_UNIQUE (if the key is a proxy resolving reference), EOBJECT__NO_CIRCULAR_CONTAINMENT (if any containment reference is proxy resolving), and generally EOBJECT__EVERY_BIDIRECTIONAL_REFERENCE_IS_PAIRED (if the references are proxy resolving), may/must resolve proxies, so that doesn't leave much to be validated without proxy resolution does it? What do you imagine would be a useful constraint to check? Not much remains other than multiplicity checks , ID uniqueness, and data value conformance...
Ed Merks
FUDForum. Page generated in 0.05766 seconds
