Home » Modeling » Papyrus » Papyrus and CDO(Papyrus working with CDO repositories)
Re: Papyrus and CDO [message #1805422 is a reply to message #1804947] |
Mon, 15 April 2019 08:33 |
Hello Simon,
1. Papyrus server is not really different of CDO Server; It is preconfigured to work with an H2 database.
2. If you display the categories in the Eclipse installation dialog, the feature "Papyrus CDO Models" is under a category called "CDO native version of metamodel". Maybe this name is not yet enough clear.
CDO works with standard metamodel based on EMF Object (legacy mode), but it is more performing on EMF metamodel adapted for it (native mode).
So this feature provides UML2 and a GMF Notation (Diagram) version dedicated to CDO to use the native mode. These versions are fully compatible with standart ones.
Re: Papyrus and CDO [message #1814038 is a reply to message #1811093] |
Mon, 02 September 2019 09:44 |
Hi Nicola, hum...
I have no more idea. Here, the system seems to be installing all CDO features... Did you tried to install all CDO features ?
In this case, as I wrote previously, don't install CDO. The update site is just required to install Papyrus -CDO and the system will download itself the required feature in the CDO update site.
Vincent Lorenzo
Re: Papyrus and CDO [message #1814153 is a reply to message #1814038] |
Wed, 04 September 2019 21:25 |
Nicola Mazzacane Messages: 21 Registered: September 2014 |
Hi Vincent,
I have retried with a clean installation, but I have met the same following errors:
Cannot complete the install because one or more required items could not be found.
Software being installed: CDO Model Repository Examples 4.3.0.v20180529-1130 (org.eclipse.emf.cdo.examples.feature.group 4.3.0.v20180529-1130)
Missing requirement: CDO Electronic Restaurant Example RCP 4.1.500.v20180529-1130 (org.gastro.rcp 4.1.500.v20180529-1130) requires 'osgi.bundle; org.eclipse.nebula.widgets.gallery [1.0.0,2.0.0)' but it could not be found
Cannot satisfy dependency:
From: CDO Model Repository Examples 4.3.0.v20180529-1130 (org.eclipse.emf.cdo.examples.feature.group 4.3.0.v20180529-1130)
To: org.eclipse.equinox.p2.iu; org.gastro.rcp [4.1.500.v20180529-1130,4.1.500.v20180529-1130]
Here I summarize my steps:
1) from https://www.eclipse.org/papyrus/download.html I have download papyrus-2019-03-4.3.0-win64.zip
2) Help->Install New Software... I have selected Add... button and I have added the repository https://download.eclipse.org/modeling/emf/cdo/drops/R20180613-0111/
3) I have required to install all packages, but the following packages has not been installed (see former errors):
CDO Model Repository All Source
CDO Model Repository Repository Server DB4O
CDO Model Repository Sever Hibernate
CDO Model Repository Tests
4) I have continued installation and I waited for the eclipse restart
5) I Have created a loca CDO repository, and a Online Transactional Checkout
6) It was NOT possible to create a Papyrus Model, only Folder, MOdel Resource, Binary File, Text File
Where is my mistake?
Is there a (past or future) Papyrus distribution that has already installed Payrus CDO?
Thank you,
Nicola
Re: CDO Papyrus: impot into repository fails [message #1814945 is a reply to message #1814846] |
Mon, 23 September 2019 09:35 |
Hi Nicola,
1. please could you attach a screenshot showing the import menu you used ?
2. Is it possible for you to share with us a model (with stereotypes according to your problem) to reproduce this bug ?
3. Please you fill us a bug wtih attached models to reproduce it ?
This problem requires investigations from us, because we probably never checked this feature provided by CDO (afaik).
Vincent Lorenzo
Current Time: Wed Sep 25 20:41:55 GMT 2024
Powered by FUDForum. Page generated in 0.05998 seconds
