| Connect Wireless Devices to Kura [message #1804312] |
Fri, 22 March 2019 06:07  |
Hey everybody :)
I have a basic Q about Kura (I'm rather newcomer in IoT and Kura project)
I want to make a Smart Greenhouse using Eclipse Project I read a tutorial at eclipse website but it's not enough
so actually I did this things:
- install Kura on my Raspberry Pi 3 B+
- configure the network (make a access point for LAN and connect to a wifi as WAN
- connect Kura to Kapua as Cloud Server
So now i need to get some data from an arduino which has some sensor connected to it and it is connected to Raspberry using LAN access point which i made it ready using Kura, then I want this data to be produce at Kura gateway and do some thing regarding to a Database (for example send a voice alert if the temperature was upper than 60 centigrade), then i want to send this data to could server to get access to it using Swangger API which is built in Kapua.
actually the most important thing is how to connect edge devices to Kura and use their data.
Sorry for Long Question.
thank you in advance.
| Re: Connect Wireless Devices to Kura [message #1804623 is a reply to message #1804312] |
Fri, 29 March 2019 12:47  |
Hi, usually you connect Kura to Sensors, PLCs and actuators using industrial protocols like modes, opc-ua, etc.
In Kura those are available as Drivers and, using a so called Asset, you can map those elements and make them available in Kura Wires or Java APIs.
Matteo
FUDForum. Page generated in 0.03208 seconds
